Forum » Operacijski sistemi » Debian server problem
Hexx ::
Pozdravljeni,
na mojem Debian strežniku se mi je zgodilo da sem ob ustvarjanju spletne strani pobral zbuggan plugin za CMS, ki je pognal čuden sql klic kar je v trenutku zafilalo disk in ustavilo mysql strežnik.
Df -h /
Filesystem Size Used Avail Use% Mounted on
/dev/vzfs 20G 6.8G 1.1G 87% /
Odstranil sem nekaj logov in backup datotek tako da sem dobil nekaj prostora, da lahko sploh mysql strežnik spet zaženem in vidim da je disk zaseden le 7/20GB piše pa 87% use.
Po tutorialih na netu sem še zagnel tole, kar pomeni da je apache ustvaril veliko neizbrisanih datotek, kaj lahko naredim da dobim nazaj celoten prostor?
lsof | grep "(deleted)"
apache2 645 root mem REG 145,19 2154817209 (deleted)/dev/zero (stat: No such file or directory)
apache2 645 root mem REG 145,19 2154817250 (deleted)/dev/zero (stat: No such file or directory)
apache2 645 root mem REG 145,19 2154817252 (deleted)/dev/zero (stat: No such file or directory)
apache2 645 root mem REG 145,19 2154817196 (deleted)/dev/zero (stat: No such file or directory)
apache2 645 root mem REG 145,19 2154817040 (deleted)/dev/zero (stat: No such file or directory)
apache2 645 root 20w REG 145,10 0 34088908 (deleted)/var/run/apache2/ssl_mutex
sshd 1141 root mem REG 145,19 2154917967 (deleted)/dev/zero (stat: No such file or directory)
sshd 1141 root mem REG 145,19 2154913890 (deleted)/dev/zero (stat: No such file or directory)
sshd 1143 alec mem REG 145,19 2154917967 (deleted)/dev/zero (stat: No such file or directory)
sshd 1143 alec mem REG 145,19 2154913890 (deleted)/dev/zero (stat: No such file or directory)
apache2 1177 www-data mem REG 145,19 2154817209 (deleted)/dev/zero (stat: No such file or directory)
apache2 1177 www-data mem REG 145,19 2154817250 (deleted)/dev/zero (stat: No such file or directory)
apache2 1177 www-data mem REG 145,19 2154817252 (deleted)/dev/zero (stat: No such file or directory)
apache2 1177 www-data mem REG 145,19 2154817196 (deleted)/dev/zero (stat: No such file or directory)
itd...
Hvala!!
Df -h /
itd...
Hvala!!
- spremenil: Hexx ()
| » | [Linux] Ubuntu serveOddelek: Operacijski sistemi | 1520 (1332) | tx-z |
| » | [Debian] Po dveh dneh uporabe sem ga sesul :SOddelek: Operacijski sistemi | 2446 (2193) | Ice-Heki |
| » | oscommerce v slo (strani: 1 2 )Oddelek: Izdelava spletišč | 9431 (8246) | gregy |
| » | EZ portal problem!Oddelek: Izdelava spletišč | 1782 (1702) | roli |
| » | Kako inštalirati program v linuxih ??Oddelek: Programska oprema | 1898 (1764) | Gandalfar |
