Blue screen
Blue screen
saguaro ::
On Sat 20.4.2013 19:23:37 GMT your computer crashed
crash dump file: C:\Windows\Minidump\042013-19515-01.dmp
This was probably caused by the following module: ntoskrnl.exe (nt+0x5A240)
Bugcheck code: 0x1A (0x41201, 0xFFFFF68041C11118, 0xF5F000005B28B867, 0xFFFFFA80058EE4B0)
Error: MEMORY_MANAGEMENT
file path: C:\Windows\system32\ntoskrnl.exe
product: Microsoft® Windows® Operating System
company: Microsoft Corporation
description: NT Kernel & System
Bug check description: This indicates that a severe memory management error occurred.
This might be a case of memory corruption. More often memory corruption happens because of software errors in buggy drivers, not because of faulty RAM modules.
The crash took place in the Windows kernel. Possibly this problem is caused by another driver that cannot be identified at this time.
KAKO POPRAVIM TO? hvala vsem. Lp
huek111 ::
Bolj bedno postavljenega vprašanja še nisem videl!
Ali se to dogaja redno ob zagonu nekega programa ali naključno?
Ali se je to zgodilo 1x, 2x, 10x na uro, dan, leto?
Ali je računalnik nov ali star?
Ali si vgrajeval novo strojno opremo?
Ali uporabljaš windows XP, Visto, 7?
Če pa bi zadnji dve vrstici kopiral v google prevajalnik, bi dobil skoraj pol odgovora!
Zalarovsky ::
Pozdravljeni!
Imam težave z Blue screeni, pojavljata se dva.
Pred kratkim sem posodobil svoj hardware, in sicer sem nabavil novo matično, RAM in procesor. Ter na novo inštaliral windowse 7. Računalnik v samih Windowsih deluje normalno, ko pa zaženem kakšno zahtevnejšo igrico ali program pa se mi pojavita 2 blue screena.
1. KERNEL_DATA_INPAGE_ERROR STOP: 0x0000007A
2. *** STOP: 0x0000007e (0xC0000005, 0x81ED2693, 0x805F0650, 0x805F034C)
Glede na to, da je sedaj ves hardware relativno now, mi ni jasno zakaj se to dogaja, poskusil sem poiskati rešitve na določenih forumih vendar nisem našel ustrezne rešitve. Sam sumim na disk, vendar check disk ne najde ničesar, prav tako sem ga spustil skozi HDD Regenerator, ki je popravil tri sektorje in to je bilo to...
Trenutno se mi ne sanja kako to porihtati, zato bi prosil za kakšen pameten nasvet..
Specifikacije sistema so:
- Matična Intel DZ77SL-50K S1155
- Intel core i3-3220 3.30GHz 1155
- 4GB RAM-a corsair
- NVIDIA GeForce GTX 550 Ti (stara 1 leto)
- Disk WD Caviar Green 1 TB, 7200 rpm, 64 MB, SATAII (WD10EARS) (star pribl. 2.5 leti)
ender ::
Jaz sem imel MEMORY_MANAGEMENT BSODe zaradi ASMedia USB3 gonilnika - ko sem ga zamenjal z Microsoftovim, so se problemi nehali.
Windows 10 BSOD memory_management
Oddelek: Operacijski sistemi
93232 (2763) slovo
racunalnik se ne boota
202026 (1608) Echbart
BSOD minidump problem
101275 (1123) ru7
prosim za pomoč- kako odpraviti tole napako...
235104 (4613) Mavrik
Win 7 blue screen in restart
132926 (2665) Duhec
