Dobri stari ARJ za DOS...
Cowboy6 ::
zanima me, če se še kdo spomne, kaj je treba napisati, da ti npr. eno datoteko ki je na disku spravimo na več disket z ARJ za DOS. in pol kako se to naredi še obratno.
Tukaj naj bi bil moj podpis.
  • premaknilo: bastadu ()
Trupl0 ::
se mi zdi da nekaj tkole:
arj a -y "ime fajla" " ime novega fajla"
al namest -y -v???? DOS je že malo star...jst pa tut:D
If you are going through Hell, keep going !
Cowboy6 ::
ok bom poskusu, tnx
Cowboy6 ::
hja, veš pa ne dela. vem da treba napisat npr.
ARJ a -(TUKAJ NE VEM KAJ NAPISAT) a:\krneki.arj krneki.mp3. Da vidimo če se še kdo spomne te mitologije, kr jst se je bol slabo :D
V-i-p ::
ARCHIVE:
C:\TF> arj
C:\THOMAS\TEMP>arj
ARJ 2.50a SHAREWARE Copyright (c) 1990-95 ARJ Software. Dec 12 1995
*** This SHAREWARE program is NOT REGISTERED for use in a business, commercial,
*** government, or institutional environment except for evaluation purposes.
List of frequently used commands and switches. Type ARJ -? for more help.
Usage: ARJ [- [-...]] [...]
Examples: ARJ a -e archive, ARJ e archive, ARJ l archive *.doc
a: Add files to archive m: Move files to archive
d: Delete files from archive t: Test integrity of archive
e: Extract files from archive u: Update files to archive
f: Freshen files in archive v: Verbosely list contents of archive
l: List contents of archive x: eXtract files with full pathname
c: skip time-stamp Check r: Recurse subdirectories
e: Exclude paths from names s: set archive time-Stamp to newest
f: Freshen existing files u: Update files (new and newer)
g: Garble with password v: enable multiple Volumes
i: with no progress Indicator w: assign Work directory
m: with Method 0, 1, 2, 3, 4 x: eXclude selected files
n: only New files (not exist) y: assume Yes on all queries
DE-ARCHIVING:
C:\>arj command -options archivefile files...
Where command is the main command that you want to execute (ie compress, extract, list), options denotes add-on capability that you can add to command, archivefile is the name of the archive file and files represents the name of the files you want to compress and archive.
For a quick reference to the commonly used commands and options you can simply run ARJ without any arguments as follows:
C:\TF> arj
C:\THOMAS\TEMP>arj
Ti to kaj pomaga :\ :\ ?
Gandalfar ::
arj a -va
za extract pa mislim
arj x -va
se mi zdi.. arj pa preberi help :)
the_unborn ::
tocno tako, sem pogledal v moj prastari zvezek, kjer mam vse napisano, tudi kode za lemmings1 in podobno saro:D
ABX ::
Če se ne motim winace zna odpirat stare arj file (in verjetno še kak drugi program.
arj x file.arj -va
ToniT ::
arj a a:imeARJ *.* -va naredi arj na disketo v odvisnosti od placa
arj a imeARJ *.* -v1440 naredi arhive velikosti diskete (na disk)
če daš na koncu -r, doda direktorije
arj x imeARJ razpakira arhiva z poddirektoriji, kot so bili arhivirani
arj e imeARJ razpakira arhiv brez drevesne strukture itd...
Če želiš dobiti arhiv z več disket nazaj, lahko razpakiraš vsako posebej z ukazom arj x imeARJ.ARJ (.a01, .a02 itd) in bo zadeva delovala. Samo te bo vprašal ali želiš datoteko prilepiti k obstoječi (tam, kjer je končal).
Če pa daš na koncu -y , pa bo naredil vse avtomatsko.
  • spremenil: ToniT ()
Tr0n ::
winrar, winace, winarj, to vse odpre .arj
Dead_Eye ::
powerarchiver tudi
The one and only
Blue3D ::
Za stisnit na vec 1.44 disket
arj a -v1440 -y spricer.arj
Za odstisnit:
arj e -v1440 -y spricer.arj
vse datoteke morajo biti v enem direktoriju
the_unborn ::
se pomnite pkzip in pkunzip?:)
Cowboy6 ::
pkzip pa pkunzip, ej če ga rabiš, ti ga lahk pošljem?! :D nekateri še mamo stare kište nekje v kotih, pa to še vse prov pride. aja, pa pjebi hvala za pomoč.
gumby ::
un|verse: pomnimo? jaz ga še uporabljam... verzija 2.5+ podpira dolga imena, stvar je zelo uporabna v skriptah za razne backup-e:)
winzip-a pa sploh nimam instaliranega, ker ga ne rabim.
aja... novejši dos-ovski arj tudi podpira dolga imena, vendar je zip le nekakšen standard...
  • spremenil: gumby ()
frudi ::
če že pakiraš na več disket, potem je dobro uporabiti še -w switch, da ti najprej ustvari datoteko na disku in jo šele končano posname na disketo; precej pripomore k hitrosti v primerjavi s pakiranjem direkt na disketo. torej:
arj a -va -r -wc:\ a:\arhiv *.*
kaka je razlika, v primerjavi z uporabo -v1457000 switcha? to, da zgornja metoda preveri, koliko prostora je na disketi in automatsko ustvari pravilno velik arhiv.
  • spremenilo: frudi ()
MS-DOS Elektronček Blagajna
Oddelek: Programska oprema
183136 (2674) _vrag_
Kopiranje večje datoteke na diskete v DOS-u
182030 (1796) Azrael
Kako v dosu spraviti 2,5 mb na disketo 1,44 mb
121819 (1482) mojsterleo
Programček, ki razdeli datoteko na več delov
162262 (2142) schurda
Kako razstavit file?
182416 (2217) andrej
