[VBScript] Izpisovanje podatkov strojne opreme
aljaz92 ::
Zdravo, zanima me kako pravilno zapisat VBScript v dokument ga shranit v ime.vbs in ga potem zagnat s pomočjo CMD-ja, da izpiše pravilne podatke.
Naloga je izpisati podatke o matični plošči:
Proizvajalec: Gigabyte Technology Co., Ltd.
Naziv: Z68X-UD3H-B3
Verzija: x.x
Moja koda:
On Error Resume Next
strComputer = "."
Set objWMIService = GetObject("winmgmts:\\" & strComputer & "\root\cimv2")
Set colItems = objWMIService.ExecQuery("Select * from Win32_MotherboardDevice",,48)
For Each objItem in colItems
		Wscript.Echo "Proizvajalec: " & objItem.Manufacturer
	   Wscript.Echo "Naziv: " & objItem.Name
Next
Matic1911 ::
Naloga pri OAR a ne :)
No v glavnem poglej si to kodo. Nato jo zaženi ter pobriši nepotrebne podatke.
strComputer = "."
Set colItems = objWMIService.ExecQuery("Select * from Win32_BaseBoard",,48)
    Wscript.Echo "Caption: " & objItem.Caption
    Wscript.Echo "ConfigOptions: " & objItem.ConfigOptions
    Wscript.Echo "CreationClassName: " & objItem.CreationClassName
    Wscript.Echo "Depth: " & objItem.Depth
    Wscript.Echo "Description: " & objItem.Description
    Wscript.Echo "Height: " & objItem.Height
    Wscript.Echo "HostingBoard: " & objItem.HostingBoard
    Wscript.Echo "HotSwappable: " & objItem.HotSwappable
    Wscript.Echo "InstallDate: " & objItem.InstallDate
    Wscript.Echo "Manufacturer: " & objItem.Manufacturer
    Wscript.Echo "Model: " & objItem.Model
    Wscript.Echo "Name: " & objItem.Name
    Wscript.Echo "OtherIdentifyingInfo: " & objItem.OtherIdentifyingInfo
    Wscript.Echo "PartNumber: " & objItem.PartNumber
    Wscript.Echo "PoweredOn: " & objItem.PoweredOn
    Wscript.Echo "Product: " & objItem.Product
    Wscript.Echo "Removable: " & objItem.Removable
    Wscript.Echo "Replaceable: " & objItem.Replaceable
    Wscript.Echo "RequirementsDescription: " & objItem.RequirementsDescription
    Wscript.Echo "RequiresDaughterBoard: " & objItem.RequiresDaughterBoard
    Wscript.Echo "SerialNumber: " & objItem.SerialNumber
    Wscript.Echo "SKU: " & objItem.SKU
    Wscript.Echo "SlotLayout: " & objItem.SlotLayout
    Wscript.Echo "SpecialRequirements: " & objItem.SpecialRequirements
    Wscript.Echo "Status: " & objItem.Status
    Wscript.Echo "Tag: " & objItem.Tag
    Wscript.Echo "Version: " & objItem.Version
    Wscript.Echo "Weight: " & objItem.Weight
    Wscript.Echo "Width: " & objItem.Width
Next
aljaz92 ::
Ja oar je je in se še matra z nalogo 5 in 6, ter pri četrti nalogi nevem kako izpisat Velikost prostega pomnilnika, to iščem podatke za fizični pomnilnik .
Potem pa še imam navodilo za 5 nalogo: Izpišite vse mrežne adapterje, ki imajo MAC naslov. Za te naprave izpišite naziv, MAC naslov, proizvajalca in hitrost. Na koncu seznama izpišite, koliko od vseh mrežnih adapterjev ima MAC naslov. Primer:
Naziv: Realtek PCIe GBE Family Controller
MAC naslov: 40:B2:58:BC:BB:A3
Proizvajalec: Realtek
Hitrost: 100000000
ter 6 naloga: Izpišite seznam procesov, katerih naziv vsebuje iskalni niz, ki ga podamo kot vhodni parameter ob zagonu. Iskalni niz je poljubne dolžine in neodvisen od velikosti znakov. Za vsak najden proces izpišite njegovo identifikacijsko številko (ID) in naziv. Na dnu seznama izpišite število najdenih in število vseh procesov. Izpišite vse najdene procese, neglede na velikost znakov. Primer za iskalni niz "srv" (s primerom zagona).
Hvala za pomoč pri matični plošči. :)
Matic1911 ::
Naloga 4:
http://stackoverflow.com/questions/1134...
Naloga 5:
http://www.activexperts.com/network-mon...
tu uporabi še IF stavek
Naloga 6:
Na googlu napiši
- VBscript process
- VBscript process list
- VBscript process ID
Evo to je kar rabiš za te naloge. Malo preglej primere na linkih ter poglej if stavek.
Upam, da ti bo to kaj v pomoč :)
aljaz92 ::
hvala za pomoč, bo moglo pomagat če ne bom pa še zagnjavu kej :)
[C] izris trikotnika v konzoli
Oddelek: Programiranje
134694 (2969) darkkk
VBS skripta za IP nastavitve
374480 (3994) Malajlo
Preprosta *.bat skripta
81531 (1313) lopov
En majhen trik za vse
62009 (1605) Trubar
Kako bi napisal .bat file, da bi ...
232295 (1741) AtaStrumf
