I5 3570K vs FX-8120 vs FX-8320
fr4nc ::
@dogo: Odvisno kje... v sintetiki je tu pa tam malo več :P.
Drugače pa ja... itak se ne splača za BD ali PD kupit kaj več kot 1600MHZ - kar sem tudi sam naredil ;).
Lep pozdrav,
Fr4nc
camx ::
fr4nc: a veš kaka je razlika med FX-3820 in 3850 (razen 30€)? A imata enak navijalski potencial?
fr4nc ::
30€ in stock frekvenca... Navijalski potencial je isti oz. je pač odvisen od primerka - vsaj kolikor je meni znano.
Sicer pa če tudi ni tako na zraku verjetno ni neke razlike, razen če se ti gre za LN2...
Lep pozdrav
vaščan ::
Halfdead987 ::
i7 je malo boljši in prav tako skoraj 2x dražji.Nič zanimivega.
filip007 ::
Ja podobno ugotovitev so ugotovili na TechPowerUp.
i7 ni dvojno hitrejši, je pa dvojno dražji.
http://www.techpowerup.com/reviews/AMD/...
Zero games, zero talk.
vaščan ::
After adding up the parts used in today's benchmark analysis, the Intel-based system crested $1,900, while the AMD platform ran us $1,724, both without cases, peripherals, or operating systems. If we wanted to call both setups "complete" solutions, we could add an $80 chassis to give us $1,984 and $1,804 machines, respectively. Since we're adding cost to both boxes, AMD's overall $180 cost savings becomes a smaller percentage of the total price tag. In other words, the other pieces that go into a nice high-end PC serve to diminish AMD's value leadership.
The only way we can make AMD's FX-8350 look like a better gaming value than Intel's Core i7-3770K (specifically in the games and at the settings we used to test) is if the rest of the system is free. Because the rest of the system is never free, the FX-8350 never serves up better high-end gaming value.
Buggy ::
ne vem zakaj ta razprava se zmeraj poteka. Jasno je bilo prikazano, da ob high end grafiki procesor ne igra bistvene vloge v vecini spilov, ce res nisi benchmark freak, ne razumem tega hypa. Doma imam i7 2600k@4.4Ghz + GTX580 stock ter FX8120@4.2ghz + 7850@1130Gpu pa v spilih kot opazam ni nobenih bistvenih razlik! S tem da je AMD sistem dosti tisji in dosti cenejsi.
Povsod so nastavitve malce pod ultra in vse tece vec kot krasno...ce nebi i7 konfiguracije dobil takorekoc pol zastojn je nikoli zavestno nebi kupil.
ABX ::
Your point?
rossekdj ::
eno vprasanje. Je mozno , da mi amd fx 8320 bremza saphhire 7970 na battlefield 3 mp 64 palayerov mi gpu usage na 60% pada single dela normalno skoz na 99% .
KTr1sk ::
koliko imaš pa kaj fpsjev pri multiplayer pri 60% delovanja kartice?
SuperVeloce ::
rossekdj je izjavil:
Čisto možno, čeprav je MP dobro multithreaded, še vseeno poleg vseh ostalih rabi 2 zelo požrešna threada. Že pri i3 pade fps precej, 2 jederni inteli brez HT so pri 64 že krepko na meji igralnosti (min fps pada tudi pod 30), zna cukat.
Vendar pri fx8320 dvomim, da postane igra zatikajoča, čeprav je cpu tisti ki zavira... Bi rekel, da 60fps sploh ni problem tudi pri AA in HBAO vključenem)
Pro_moted ::
Hmm, probaj malo navit procesor pa boš videl če bo kakšna razlika. Pri meni z 7950 na 1000/6000 je vseeno ali imam procesor FX 8120 na stock 3,1 Ghz ali sedaj na overclock 3,8 Ghz. Vedno je izkoriščenost GPUja 99%.Tako da mislim da mislim da nimaš problema s CPU jem, seveda ni pa izključeno.
AMD FX8120;GB 990FXA-UD3
SuperVeloce ::
Če so grafične nastavitve dovolj, da obremeni grafično bolj kot CPU, potem itak ni važno... kot sem rekel, 8320 bi načeloma naj bil dovolj za 60fps vsync pri uravnoteženih grafičnih nastavitvah. AA in SSAO zraven dodatno obremenita tudi CPU, vsaj pri AMD grafičnih vem da je tako
MP cpu test v nemškem jeziku
rossekdj ::
pri 60 % imam od 45 do 55 fps zdaj bom navil in bom videl ce bo kaj bolse .
ABX ::
Odpreš task manager in vidiš na koliko je CPU. BF3 je požrešna v mp ampak tudi izkorišča bilo kateri CPU, tako da ga boš imel na 100% če ni dovolj hiter.
rossekdj ::
cpu je uporabljen okoli 60 %
Pro_moted ::
Katere driverje za grafično uporabljaš?
Halfdead987 ::
rossekdj zakaj si sploh menjal 680 za 7970? pripravi se na bleme z driverji.
Pro_moted ::
Z driverji ni nič narobe, vsaj novimi ne. Tam od 12.1 naprej.
TOP ::
Halfdead987 je izjavil:
To ti misliš.
Naj proba 13.2 beta 5 gonilnike.
SuperVeloce ::
Naj raje poskusi kakšno drugo grafično zahtevno igro... če je tam poln utilization, potem niso driverji...
rossekdj ::
v farcry3 mi pada procesor na 60% zanima me ce je preslab napajalnik corsair tx650w je pa res da imam navit procesor in grafično . drivere imam 13.2 beta
  • spremenilo: rossekdj ()
Koliko imaš FPS v FarCry 3 in GPU usage? In na kateri resoluciji igraš? Ali je igra tekoča?
Xserces ::
napajalnik je dovolj močen edino če ni hin.
rossekdj ::
na ultra 30 usage 60% 1920x1080 ni tekoča igra
CPU in GPU frekvence daj na default in poročaj.
rossekdj ::
sem dal na stock in se je slabse gpu usage 50% sumim napajalnik .
Sposodi si ga preden greš v nakup.
TOP ::
Pomoje ni napajalnik,ker bi bil tole zelo redek primer,da se tole dogaja sumim na proc.Ker sem že bral o podobnem primeru in tole z grafo GTX680,ko je dal grafo na I7 proc je poletela.Probaj pa poročaj.Pa če maš možnost probaj grafo na kakem drugem procu.
Ne verjamem. Nekaj drugega mora biti.
rossekdj ::
probal sem na bratovem i7 2600 in je bilo malo bolse ne pa kaj dosti .
TOP: tuji jaz ko sem svojo gtx680 na i5 3570k dal je poletela pred tem pa sem imel amd fx 6100 in je bila katastrofa isto kod zdaj .
Pa maš srečo, da se samo tebi dogaja to :))
Halfdead987 ::
Defektna radeonka?
Ne verjamem, da bi bila defektna grafična.
Xserces ::
se požene grafično zahteven test in se prec vidi. Nevem kaj se toliko komplicira... Zažen FURMARK bech ali pa unigine bench in se primerja.
rossekdj ::
test :
Pro_moted ::
Je možno da Afterburner kaže narobe ? Bral sem da so imeli eni s tem probleme. Še preverjaš GPU izkoriščenost s katerim drugim programom ?
rossekdj ::
se obstaja kaksen program za gpu usage ?
particle ::
GPU-Z, MSI Afterburner...
rossekdj ::
gpuz - igral sem battlefield 3 mp 64 player
freesty ::
Probaj druge driverje. Pa v msi afterburnerju daj power na +20%. Pa porocaj.
http://www.youtube.com/watch?v=5hfYJsQAhl0
Xserces ::
kaj je s frekvencam GPUja? Če so to 3D frekvence potem je neki narobe ali pač? vidim pa da zravn piše AVG
  • spremenil: Xserces ()
Pro_moted ::
Jaz sem sedaj dal na 13.2B driverje, pa sem pognal Unigine 4.0 in mi tudi skače GPU load od 65% do 99%. Tako da verjetno so driverji. Ker prej (12.8) je bilo na istih frekvencah in nastavitvah load 98%-99%.Dobro bi bilo da tudi drugi poročajo če se jim to dogaja in s katerimi driverji.
vaščan ::
Men dela ok 98-99% 13.2b
Meni tudi 13.2b 99%
rossekdj ::
probleme sem imel z driveri na 12.8 stoji 99% na vseh mapah na 64 playerov bf3 ampak so fpsji slabi :S
fr4nc ::
Procesor navij na (vsaj) 4GHz, grafično pusti na stock pa poročaj!
Glede na to, da naj bi BF3 izkoristil 6 jeder - če sem pravi slišal...
Lep pozdrav,
Fr4nc
12 / 19
FX-8320 & 7850 - record! (strani: 1 2 )
Oddelek: Navijanje
9753333 (49100) fr4nc
Nakup novega(gamer) namiznega računalnika (strani: 1 2 )
5517024 (15913) DrYuri
