Izrael : Palestina že n-tič
Mislim da bodo ZDA kmalu odgovorile sploh po novici ki je ravnokar prišla ven:
UPDATE: Two dozen American military personnel were wounded last week in a series of drone attacks at American bases in Iraq and Syria, U.S. Central Command told NBC News
Two dozen American military personnel were wounded last week in a series of drone attacks at American bases in Iraq and Syria, U.S. Central Command told NBC News on Tuesday.
The Pentagon confirmed the attacks last week, but the number of U.S. casualties has not been previously disclosed.
Twenty American personnel sustained minor injuries on Oct. 18 when at least two one-way attack drones targeted al-Tanf military base in southern Syria, CENTCOM said.
One of the drones was shot down. All of the wounded personnel were returned to duty, CENTCOM said, and there was no damage to any military installations.
https://www.nbcnews.com/politics/nation...
WHITE HOUSE EYES $50B DOMESTIC, $100B FOREIGN AID PACKAGE :WAPO
Se pravi najprej je bilo rečeno 106 milijard, zdaj naj bi bilo že 150 milijard.
BREAKING: Pentagon says a squadron of US F-16 fighter jets has arrived in the Middle East, without specifying where in the region.
  • spremenilo: Chalky ()
Bashar al-Assad, sem nekje prebral, da naj bi bil za Putinom, drugi najbogatejši človek na svetu.
Tukaj ju ni.
https://www.forbes.com/billionaires/
RedDrake ::
Saj tudi vodij kartelov ni. Pa to ne pomeni, da niso miljarderji.
Če je pa napisal, da je nekje prebral. Torej bo dal vir.
RedDrake ::
To imaš pa prav. Rekla kazala ni vir, čeprav je ilegalno premoženje izjemno težko dokazovati in so itak vse samo "špekulacije".
Familija na oblasti cirka 50 let, pa ni nabrala za milijardo dolarjev premozenja? Slisi se nemogoce.
RedDrake ::
Ja, eno je miljarda dolarjev, drugo je pa 2. najbogatejšni na svetu (kar implicira stotine miljard).
Ni ravno trivialna razlika ...
Plus kaj je to premoženje - taki članki znajo biti zelo kreativni pri seštevanju premoženja in vključujejo razne razpadajoče "dvorce" in podobno.
Zlahka ima en šlomo tipa Schwarzmann (Black Rock) ali celo njegove oprode več efektivnega premoženja, karkoli že to je. Delujejo pa fantje seveda iz "pozadine".
  • spremenil: Miki N ()
Pri diktatorjih je pač težko rečt kaj je njihovo in kaj ne. Nekaj je njihovo, nekaj je njihovo, ampak napisano na nekoga drugega, nekaj ni njihovo, ampak v resnici s tistim upravljajo in si tudi iz tistega lahko kupijo jahto za 100 mio kadarkoli hočejo.
Je to sploh zares pomembno koliko "imajo"? Vse kar imajo, so ukradli, imajo pa lahko vse kar hočejo.
Sparkxl ::
Včeraj sem zasledil, da so USA prišle na genialno idejo da sankcionirajo, omejijo finance hamasa. Ne morem se spomnit, dajte mi pomagati...kje smo že nazadnje videli kako dobro te sankcije delujejo, da v teoriji sesujejo državo, ko jo odrežejo od usd finančnega toka...
Lep primer je Rusija, ki je polna plina in nafte, ljudje pa zmrzujejo, ker nimajo denarja za ta plin.
dronyx je izjavil:
Kar "povprecen Slovenec" iz slovenskih medijev, ki so izrazito pro-palestinski ne izve, da so ZN Palestinci zaceli upostevati sele, ko so izgubili toliko vojn, da so jim resolucije nenadoma zacele koristiti. Zato tudi tako vztrajajo pri meji iz 1967. Kar je danes seveda popolnoma nerazumna pozicija za pogajanja.
Saj se niso vojskovali Palestinci. Izrael so napadali vsi okoliški Arabci - Egipt, Jordanija, Sirija, Libanon, celo je pomagal Irak. Palestinci so samo zganjali terorizem, kar počno še danes. Ampak če bi res kdaj uničili Izrael, bi se pa potem stepli, kdo dobi to ozemlje. Palestinci so praktično nepomembni v tem sporu in na koncu ne bi dobili nič.
Ja, lapsus. Mislil sem 'Arabci'.
Zidom se je čisto ausglajzalo
https://www.24ur.com/novice/tujina/izra...
Naj se speljejo domov, problem rešen.
  • spremenilo: sbawe64 ()
Veleposlanik je samo poudaril, da Guterres morda ni dovolj brihten za svojo funkcijo. Ker drugace, bi se seveda (na glas) vprasal, ce je izraelsko zatiranje Palestincev potrebno videti v kontekstu vecdesetletnih grozenj, vojn ipd. arabskih sosed. Ce se ze gremo relativizacijo, je potrebno biti konsistenten.
Niso ga zaman dali na to pozicijo>:D
Za tako funkcijo ne potrebuješ biti pameten, drugače za osebke tipa Uršula vdL, Borell, Stoltenberg ne bi niti slišal.
BREAKING -- Erdogan says Hamas isn't a terror group but patriotic organisation that defends its territories and people.
o "They are the warriors (mujahids)" he says. "We aren't indebted to Israel. But the West is."
o "I won't visit Israel"
https://twitter.com/ragipsoylu/status/1...
Erdoganu se spet trga. Po tistih lažeh zadnjič je očitno hitro vse skupaj pometel pod preprogo.
Čez dalje bolj kaže na to da so se voditelji v Iranu opekli in da so računali na to da se bo celoten bližnji vzhod obrnil proti Izraelu predvsem Zalivske države. Včeraj se je odvilo kar nekaj pomembnih dogodkov ki nakazujejo na to da si zalivske države želijo skleniti mirovni sporazum z Izraelom ki je bil tudi glavni razlog po mojem mnenju da je Hamas napadel Izrael. Iran se boji da bi Savdska Arabija končno priznala Izrael in da bi začeli sodelovati na področju, tehnologije, gospodarstva in obrambe.
Bin Salman je včeraj povedal da si želi da se pogovori med Izraelom in SA nadaljujejo ko bo vojne med Hamason in Izraelom konec. Savdska Arabija je prejšnji teden sestrelila raketo ki so jo Houtiji poslali na Izrael. Prav tako naj bi se v ozadju odvijali dogovori med Katarjem in Izraelom glede talcev za kar se je Izrael zahvalil. Poleg tega je včeraj predstavnih UAE-ja povedal da Hamas ne predstavlja Palestincev medtem ko bodo ZDA postavile obrambne sisteme po številnih zalivskih državah.
Iran je računal da bo napad torpediral odnose med Izraelom in SA kot kaže ima pa Bin Salman drugačne načrte. Nekaj časa nazaj je imel neko konferenco pred voditelji držav Bližnjega vzhoda kjer je izjavil da je njegov načrt da spremeni BV v naslednjo Evropo (v gospodarskem smislu). SA trenutno gradi številne infrastrukturne projekte, tako da je njegova prioriteta več kot očitno prosperiranje in povezovanje.
Glede na to, da nismo pozabili, da je Bin Salman morilec, je to zanj pametna strategija.
AtaŠtumf ::
Tak morilec, pa ves čas ga Joe fehta, da mu dela usluge.
Joe malce drugače razume izraz Pariah, kot pa vsi ostali, ali pa je mrbit že pozabil.
Joe ga pac trenutno potrebuje. Ampak v resnici, pa je Joe ornk pritiskal na Savdijce, dokler ni Putin naredil stalo. Zahvali se torej njegovu buddyju v Kremlju.
Ameri Saudijcev itak vec ne potrebujejo zase. Potrebujejo jih predvsem zaradi Evrope.
dronyx ::
Erdogan: Hamas ni teroristična organizacija. To so mudžahedini, ki branijo svoje
Pa saj to ves čas trdi tudi kurdska delavska stranka. :D
AtaŠtumf ::
Aha, nisem vedel, da je Joe tak dobrodelnež do Evrope, da je šel fehtati MBS, da naj več pumpa olje, potem, ko ga v Venezueli niso ravno poslušali.
Sedaj pa čaka njegov minister kot mali kužek, da lahko sploh govori z MBS.
Vmes pa Joe še odpove sestanke po arabski turneji.
Vse samo zaradi Evrope. :D
Severna Amerika nacrpa dovolj nafte, da ni odvisna od nikogar. Evropa pac ne. To so dejstva. Da fehta okoli, je potrebno zaradi zavezniskih drzav. Evropa, Japonska ipd.
AtaŠtumf ::
Ok, a zato so njihove strateške rezerve na rekordnih ravneh?
Sicer je pa zanimivo gledati, kako čedalje več držav ne zanima več, kaj Joe hoče in raje skrbijo za lastne interese.
Ko pisejo o rekordno nizkih ameriskih strateskih rezervah, ti en "detajl" seveda zamolcijo. Da ameriski uvoz surove nafte pada ze od leta 2006. Dejansko so danes polmanjse rezerve po dnevih nadomestnega uvoza, na podobnem nivoju.
dronyx ::
Dokler imajo največje zaloge nafte in zemeljskega plina te države, ki imajo sedaj in dokler smo energetsko odvisni od njih se sploh ne da vodit neodvisne zunanje politike. Vedno je v ozadju nekje vprašanje, kje bomo dobili nafto. :))
dronyx je izjavil:
Ampak samo največji evropski čudaki navijajo, da bi Arabci nehali črpati nafto iz razloga , da bi našim nasprotnikom šlo bolje.
AtaŠtumf ::
dronyx je izjavil:
Eni to ugotovijo prej, drugi kasneje.
Tretji pa sanjajo, da bo zeleni prehod prinesel neodvisno politiko, ko bomo kupovali sončne celice in vozila iz demokratične in človekoljubne prijateljice Kitajske!
Zdaj bos moral pojasniti, zakaj na Norveskem poraba nafte pada. Navkljub rasti prebivalstva. Hvala za pojasnilo.
Saj pa če zadnjih 5 let raste prebivalstvo se poraba nafte ne dvigne isto leto ampak čez 18 ali 20 let...
Kakšno je bilo stanje prebivalstva pred 20 leti? Je tudi rastlo?
Da ti ne bom rabil (spet) razlagati ocitnih zadev, lahko recemo tudi drugace. Stevilo registriranih avtomobilov raste. Tudi stevilo nepremicnin raste.
Scaramouche3 ::
The Norwegian Parliament has decided on a national goal that all new cars sold by 2025 should be zero-emission (electric or hydrogen). By end of 2022, more than 20 percent of registered cars in Norway were battery electric (BEV). Battery electric vehicles held a 79.2 percent market share in 2022. The speed of the transition is closely related to policy instruments and a wide range of incentives.
Imas stare podatke. Stevilo BEV je bilo konec septembra ze preko 23%. Norvezani imajo sedaj nov problem. Pokurijo ze vec kerozina, kot bencina.
Tolk so premozni, da se prevec furajo z letali.
Zdaj, ko smo pojasnili zakaj Joe vec ne pritiska na Saudijce, se lahko vrnemo na temo. Je pa pri geopolitiki vse povezano. Tudi to, da morajo Saudijci pazljivi, da niso prevec odvisni od Indije/Kitajske ipd. Za njih je idealno, da na najvecje trge izvazajo v priblizno enakih delezih.
dronyx ::
Norveška je zgodba zase in izven konkurence. Oni imajo velike zaloge nafte in plina, kar prodajajo drugim, sami pa spodbujajo "čisto energijo" in električne avte. Večina si tega ne more privoščit. Pa to je "dvojna morala".
Da to NI "dvojna morala" smo ze v vecih temah razcistili. Dvojna morala bi bila, ce bi Norvezani spodbujali porabo nafte po svetu. Pa tega ne pocnejo. Ampak pustimo to.
dronyx ::
"Dvojna morala" morda res ni pravi izraz, razumeš pa kaj mislim. Dubaj in Doha gradita najvišje stolpnice in pokrita smučišča z naftnim denarjem, Norvežani pa pač denar nalagajo v državni sklad in se obnašajo "eko". Poanta je, da si vsi tega ne morejo privoščiti.
To razmetavanje naftnega denarja Arabcev je itak neverjetno; zagotovo bi lahko z njim pomagali palestinskim Arabcem:
Savdska Arabija in zimske igre? Da, leta 2029 bo gostila Azijske igre.
Azijskih zimskih iger niso izvedli že od leta 2017, naslednjič pa se bo celinska različica zimskih olimpijskih iger vrnila leta 2029. Gostila jih bo Savdska Arabija v svojem prvem zimsko-športnem letovišču, ki pa ga mora še zgraditi.
Gre za okoli 500 milijard evrov vreden osebni projekt kronskega princa Mohameda bin Salmana, ki želi omenjeno pokrajino spremeniti v turistični kraj.
Sej to je dobro. Namesto, da bi denar zapravljali za kaj koristnega, ga za neumnosti, od katerih čez 30-40 let ne bo več niti nafte niti "smučišč". Vprašanje kolk bo še koz.
Sparkxl je izjavil:
Torej ima Hamas nekje v tujini parkiran denar?
dronyx ::
Gregor P je izjavil:
No, to je pa zadeva, ki jo jaz ne razumem.
Po podatkih OECD je med letom 1994 in 2020 pomoč Palestincem znaša prek 40 MRD USD. Večino pomoči so prispevali: Evropska unija (18,9), ZDA (14,2), Savdska Arabija (9,9), Združeni arabski emirati (5,2), Norveška (4,8), Združeno kraljestvo (4,3), Svetovna banka (3,2) in Japonska (2,9). Torej EU in ZDA prispevajo skoraj eno tretjino pomoči. Irana na tem seznamu ni. Očitno se pomoč v orožju ne šteje.
Kako je možno, da so "neverniki" največji podporniki Palestincev? Narobe svet.
Norveška je unikum v svetu s svojo nafto, tako da je ne dajati za primer. Forsira uporabo zelenih energij, ki jih financira z izvozom nafte.
Tako da tvoje pisanje je nepoznavanje dejanskega stanja pri njih.
Res? A je kje napisal, da ni tako?
Spet se fočkate križem kražem. Naj kar kow odgovori.
  • spremenilo: fikus_ ()
Moj odgovor je, da je vsaka drzava "unikum". Napisal si pac bedarijo. Tudi v Emiratih bi se lahko danes vozili samo z elektricnimi avtomobili. Pa se ne. So pa vsaj jedrsko zgradili (no, korejci), vsaj v tem jih je za pohvaliti. Bodo manj porabili, pa vec izvozili.
Sparkxl ::
Se pa počasi kažejo obrisi kake peechke so izraelci. V gazo ne upajo peš, rajši koljejo civiliste v tisočih iz zraka z izgovorom da ciljajo hamas.
Se pravi pospravijo enega hamasovca, zraven 200 civilistov. Tega hamasovca naslednjo minuto nasledi novi. S pokolom civilistov pa ustvarjajo nove teroriste.
Si predstavljate da ste tam civilist in vam otroka ubijejo? Kako bi reagirali? Jaz za sebe vem da bi mi bil življenski cilj jih pospravit čim več.
A ti bi se ce bi imel pistolo vseeno boril castno z mecem ali bi raje ustrelil?
Ko gre za prezivetje se na moralo odmisli, zal. In tam niti Hamas niti Izrael nimata vec morale.
Sparkxl je izjavil:
Njim je življenski cilj, da postanejo mučeniki. Isti cilj imajo tudi za otroke.
https://palwatch.org/page/32972
Sparkxl ::
Lonsarg je izjavil:
Bingo. Oboji so izrodek civilizacije. Razlika je samo v pakiranju in orožju. Eni so pakirani v demokracijo in se imajo za civilizirane, drugi ne skrivajo kaki so. Eni ubijajo udobno iz oddaljenih naslonjačev in letal, drugi nimajo tega razkošja in morajo it F2F.
Pod črto so isti izrodki, živali. No v bistvu izraelci vodijo...nekje sem zasledil da je ratio 1:26 v mrtvih na dolgi rok
126 / 295
