Forum » Programiranje » android send mail
android send mail
boss-tech ::
Nekje sem našel tutorial za mail send preko android aplikacije.
Potegnil sem še jar, ampak mogoče ni tapravi, saj dobim exception:
V eclipsu ta class sicer najdem... kakšna ideja?
Mail send izgleda takole:
11-05 16:55:42.578: E/AndroidRuntime(18730): Caused by: java.lang.NoClassDefFoundError: javax.mail.internet.MimeMultipart
11-05 17:17:51.028: W/dalvikvm(19141): Unable to resolve superclass of Lsi/test/MailSender; (499)
11-05 17:17:51.028: W/dalvikvm(19141): Link of class 'Lsi/test/MailSender;' failed
11-05 17:17:51.028: E/dalvikvm(19141): Could not find class 'si.test.MailSender', referenced from method si.test.MainActivity.sendMail
package si.test;
import java.util.Date;
import java.util.Properties;
import javax.activation.CommandMap;
import javax.activation.DataHandler;
import javax.activation.DataSource;
import javax.activation.FileDataSource;
import javax.activation.MailcapCommandMap;
import javax.mail.BodyPart;
import javax.mail.Multipart;
import javax.mail.PasswordAuthentication;
import javax.mail.Session;
import javax.mail.Transport;
import javax.mail.internet.InternetAddress;
import javax.mail.internet.MimeBodyPart;
import javax.mail.internet.MimeMessage;
import javax.mail.internet.MimeMultipart;
public class MailSender extends javax.mail.Authenticator {
private String _user;
private String _pass;
private String[] _to;
private String _from;
private String _port;
private String _sport;
private String _host;
private String _subject;
private String _body;
private boolean _auth;
private boolean _debuggable;
private Multipart _multipart;
public MailSender() {
_host = "smtp.gmail.com"; // default smtp server
_port = "465"; // default smtp port
_sport = "465"; // default socketfactory port
_user = ""; // username
_pass = ""; // password
_from = ""; // email sent from
_subject = ""; // email subject
_body = ""; // email body
_debuggable = false; // debug mode on or off - default off
_auth = true; // smtp authentication - default on
_multipart = new MimeMultipart();
// There is something wrong with MailCap, javamail can not find a
// handler for the multipart/mixed part, so this bit needs to be added.
MailcapCommandMap mc = (MailcapCommandMap) CommandMap.getDefaultCommandMap();
mc.addMailcap("text/html;; x-java-content-handler=com.sun.mail.handlers.text_html");
mc.addMailcap("text/xml;; x-java-content-handler=com.sun.mail.handlers.text_xml");
mc.addMailcap("text/plain;; x-java-content-handler=com.sun.mail.handlers.text_plain");
mc.addMailcap("multipart/*;; x-java-content-handler=com.sun.mail.handlers.multipart_mixed");
mc.addMailcap("message/rfc822;; x-java-content-handler=com.sun.mail.handlers.message_rfc822");
CommandMap.setDefaultCommandMap(mc);
public MailSender(String user, String pass) {
this();
_user = user;
_pass = pass;
public boolean send() throws Exception {
Properties props = _setProperties();
if (!_user.equals("") && !_pass.equals("") && _to.length > 0 && !_from.equals("") && !_subject.equals("")
&& !_body.equals("")) {
Session session = Session.getInstance(props, this);
MimeMessage msg = new MimeMessage(session);
msg.setFrom(new InternetAddress(_from));
InternetAddress[] addressTo = new InternetAddress[_to.length];
for (int i = 0; i < _to.length; i++) {
addressTo[i] = new InternetAddress(_to[i]);
msg.setRecipients(MimeMessage.RecipientType.TO, addressTo);
msg.setSubject(_subject);
msg.setSentDate(new Date());
// setup message body
BodyPart messageBodyPart = new MimeBodyPart();
messageBodyPart.setText(_body);
_multipart.addBodyPart(messageBodyPart);
// Put parts in message
msg.setContent(_multipart);
// send email
Transport.send(msg);
return true;
} else {
return false;
public void addAttachment(String filename) throws Exception {
DataSource source = new FileDataSource(filename);
messageBodyPart.setDataHandler(new DataHandler(source));
messageBodyPart.setFileName(filename);
@Override
public PasswordAuthentication getPasswordAuthentication() {
return new PasswordAuthentication(_user, _pass);
private Properties _setProperties() {
Properties props = new Properties();
props.put("mail.smtp.host", _host);
if (_debuggable) {
props.put("mail.debug", "true");
if (_auth) {
props.put("mail.smtp.auth", "true");
props.put("mail.smtp.port", _port);
props.put("mail.smtp.socketFactory.port", _sport);
props.put("mail.smtp.socketFactory.class", "javax.net.ssl.SSLSocketFactory");
props.put("mail.smtp.socketFactory.fallback", "false");
return props;
// the getters and setters
public String getBody() {
return _body;
public void setBody(String _body) {
this._body = _body;
public void setTo(String[] toArr) {
_to = toArr;
public void setFrom(String fromString) {
_from = fromString;
public void setSubject(String sub) {
_subject = sub;
- spremenil: boss-tech ()
| » | [JAVA] HTTPS clientOddelek: Programiranje | 3691 (2421) | peterv6i |
| » | [Java] Prevajanje in šumniki v ubuntuOddelek: Programiranje | 3155 (2772) | mmaestro |
| » | [Java] Ne zažene appletaOddelek: Programiranje | 1638 (1571) | iggy |
| » | [java] Kako v memoriji pretvoriti String objekt v File objekt ? - neka metoda ga zahtOddelek: Programiranje | 2745 (2745) | infiniteLoop |
| » | tomcat - problem z encodingomOddelek: Programiranje | 2692 (2606) | kopernik |
