komptabilnost MBO in RAM
barocco ::
oj.Lahko kdo potrdi ali so komponente komptabilne??
RAM: Crucial Ballistix sport 8GB (2X4) DDR3 PC3-12800 -http://www.newegg.com/Product/Product.a...
Matična ASRock 990FX Extreme3 - http://www.newegg.com/Product/Product.a...
Jutri dobim to plato in nisem prepričan da gresta akupaj ali se motim??
Duhec ::
Teh ramov ni na support listi.
http://www.asrock.com/mb/AMD/990FX%20Ex...
Možno, da bo vseeno delovalo.
barocco ::
če pa stopim na to Crucial stran http://www.crucial.com/store/drammemory...
Vnesem podatke matične ASRock
ASus motherboards
990fx Extreme
pa dobim tole http://www.crucial.com/store/listparts....
barocco ::
http://www.crucial.com/store/partspecs....
Ko pa tu vnesem podatke matične pa mi vrže vn ,da je komptabilno.
Ne vem naj jutri pri sestavljanju probam ali naj grem RAM-e zamenjat(orig.zaprti) -too much! :/
barocco ::
Odgovor iz foruma Tom s Hardware:
If Your mobo supports DDR3, up to 2100 MHz. Crucial is letting you know that the RAM you've chosen is compatible technolog. That is, the RAM is DDR3. That said,
compatability isn't limited to what is published on the manufacturer's website. Rather, the supported memory list is just a list of what was tested and met or exceeded expectations. The only potential problem is that if in the event of your motherboard not POST-ing, any communication to Asrock's tech support could result in them telling you to use RAM that is on the support list.
Laptop se noče bootat v Windows, črni zaslon z napisom
283900 (3408) Mind_Game
MX100: Občasno zatrokiranje, "failed to boot", blue screen - KERNEL_DATA_INPUT_ERROR?
379534 (9009) iloveboobz
rami + napajalnik
191672 (1510) wade
Sestavljam Računalnik, prosim za pomoč !
473554 (2304) barocco
Asrock Z77 Pro4 vs Z77 Extreme4 (strani: 1 2 )
5612830 (11813) fr4nc
