Asrock Z77 Pro4 vs Z77 Extreme4
2
Brainstorm ::
Zanima me, kako je s temi pozlačenimi kondenzatorji, ki so v extreme4 verziji, je to bolj za okras ali so dejansko kaj bolj vzdržljivi kot oni, ki so v pro4 verziji.
Ker ne vem ali čem dati 20€ več za extreme4, ker SLI ne rabim, neke druge razlike pa tako ni, razen LED display, ki javlja napake, še ima extreme4 dodatno.
http://www.asrock.com/mb/overview.asp?M...
Malo pozno... :)
Ja se splaca dat vec. Zakaj? (zgleda, da si bolj slabo prebral specifikacije)
Extreme4:
- Digi Power Design, 8 + 4 Power Phase Design
- Broadcom BCM57781
- Realtek ALC898 Audio Codec
- 2 x Rear USB 3.0 ports by Intel(R) Z77, support USB 1.0/2.0/3.0 up to 5Gb/s
- 2 x Rear USB 3.0 ports by ASMedia ASM1042, support USB 1.0/2.0/3.0 up to 5Gb/s
- 1 x Front USB 3.0 header by Intel(R) Z77 (supports 2 USB 3.0 ports), supports USB 1.0/2.0/3.0 up to 5Gb/s
Pro4:
- Digi Power Design, 4 + 2 Power Phase Design
- Realtek RTL8111E
- Realtek ALC892 Audio Codec
- 2 x Rear USB 3.0 ports, support USB 1.0/2.0/3.0 up to 5Gb/s
- 1 x Front USB 3.0 header (supports 2 USB 3.0 ports), supports USB 1.0/2.0/3.0 up to 5Gb/s
Zdej, ce ti te stvari nic ne pomenijo in se gres raje zapit za 20€, potem uzames Pro4, zame osebno je pa Extreme4 minimum, kar zahtevam od plate. Po mojem mnenju je Extreme4 best buy Z77 plata glede na opremo in ceno.
Pesimist ::
Kaj zaj so Z77 plate za I7 in starejse sploh ni za pogledat vec?
Anyway, bottom line is this.
H67 - Onboard graphics are enabled, while overclocking is disabled
P67 - You need a graphics card for this chipset - onboard graphics is disabled, however overclocking is enabled here
Z68 - You guessed it...best of both worlds. Onboard graphics are enabled, as is overclocking
I guess I need P67 iz tega, razen ce so cene iste za oba chipseta.
Z77 kolko berem wiki nima PCI rez več. Kam si te nej ftaknem mojo PCI opremo.
  • spremenilo: Pesimist ()
Janac ::
vecina plat se ima pci-je
69charger ::
Z77 čipset ne podpira več PCI rež.
Janac ::
ja in?
plate ga se vedno imajo ker so dodale znamke kontroler za pci
A morate se kle morit s tem PCIjem?
Fino bi blo, ce si kaksne specifikacija plat ogledste, predno pridete jokat na forum.
Janac ::
sn si vse ogledo
Ni blo to teb namenjeno.
TheAmunraaa ::
Zdravo! Sem nov na forumu in ravno kupujem nov računalnik (vsaj CPU, plato in RAM).
Nekdo iz interneta mi je že priporočal plato Asrock Z77 Extreme4, ampak je nisem našel v nobeni SLO trgovini.
Kje bi se jo dalo najceneje dobiti (če je le možno preko slovenskega prodajalca)?
Najceneje je pri dinokompu, 142EUR.
Aja, se demise, samo pravijo, da ni prevec zanesljiva stacuna.
  • spremenil: Dr_M ()
TheAmunraaa ::
@mtosev in @Dr M
Hvala! Na dinokomp sploh nisem pomislil, za demise pa po pravici povedano prvič slišim.
KTr1sk ::
torej Digi Power Design, 8 + 4 Power Phase Design
je boljše..zarad napajanja...boljša stabilnost ter bolj za navijanje plata??
in kaj pa
je drugače ok za "nezahtevne upoabnike"?
jaz gledam tole http://www.gigabyte.eu/products/product...
pa ne vem kaj ima, opazil sem da ima samo 4pine za dodatno napajajne, kar pa imajo ponavadi večina 6pinski konektor
KTr1sk ::
Aja pa kako je pri teh z77 platah ki naj bi podpirali ivy...ker piše po cpu support
http://www.gigabyte.eu/support-download...
da od verzije F12 podpira 3570k, ..prejšne verzije so pa F10,11 IN F12, torej kako naj vem če je nadgrajena na f12, kako bo potem zaznalo procesor?
  • spremenil: KTr1sk ()
Janac ::
ne kompliciraj, delalo bo
  • predlagal izbris: 69charger ()
69charger ::
Kaj si ti pameten Janac ne dajaj takšnih brezveznih komentarjev.
V primeru da plošča ne bo imela F12 BIOSa se mogoče pač zadeva ne bo zagnala in boš potreboval nekoga ki bi ti naložil novejši BIOS oz. se sposodiš starejši procesor.
Janac ::
updatat bos mogu bios!
KTr1sk ::
Janac je izjavil:
ja ampak kako pa lahko updejtaš bios če imaš procesor kateri ni podprt dokler se ne updejta
Janac ::
uporabis drug procesar
TOP ::
Janac je tam prav napisal ne kompliciraj V vsakem primeru updejtaš bios,če maš novejši proc se pač sposodiš starejšega,če tole možnost nemaš,se zmeniš z Dinokomp,kateri ti bo tole naredu,še posebej da tam kupiš več komponent.
Janac ::
TOP je izjavil:
se strinjam
KTr1sk ::
Če pogledate na newegg pa spet je kar nekaj ljudi nezadovoljnih z Extreme ploščo :(
http://www.newegg.com/Product/Product.a...
in
Janac ::
Ascrok=crap
Boljse kot gigabyte :))
KTr1sk ::
Dr_M je izjavil:
samo na newegg pa niti niso slabe ocenjene kot asrock, čeprav imam tudi sam trenutno asrock ki še ni težav, ampak ko kupujem in berem komentarje sem kar mal zbegan kaj se naj odločim
Janac ::
ma vzem gigabyte nimas sploh kaj razmisljat, UD3 je zelo dobra plata, vejetno ima vse kar rabis :))
s51as ::
ASUS ovih plošč nihče ne gleda?
It's just me myself and I
Janac ::
niso vredne svojega denarja, konkurenca ponuja vec za isto ceno.
Asuske vsaj delajo uredu, pri gb moras met ze veliko sreco,da nimas problemov.
Kar se pa tice newegga,se splaca ucas prebrat komentarje, velikokrat se izkaze, da folk da en jajc, v resnici pa nimajo pojma in so sami krivi za napako.
s51as ::
Ni vse samo v karakteristikah... specifikacije so že lahko enake ali boljše zanesljivost je pa nekaj drugega...
KTr1sk ::
Sem našel dva "Review"-a (zakaj je sploh dvakrat enak izdelek gor?)
http://www.newegg.com/Product/Product.a... -Tu ni nobenih slabih komentarjev
in
http://www.newegg.com/Product/Product.a... -tukaj pa so štirje negativni komentarji
"Pros: Installation was easy, no issues and booted easily.
Cons: Ran for about two hours. After installing windows updates I restarted. Then I got an error code "A2" on the motherboard. Having error codes is great, as long as the accompanying manual says something useful about the code. Now it's a paperweight.
Manufacturer Response:
Dear AsRock Customer
We sincerely apologize for any inconvenience this may have caused you. "A2" code should have screen display, please try with onboard video. Try with another known good display card to eliminate the issue. If still having same issues please contact our Tech Support at 909-590-8308. We can assist you shortly.
Thank you
AsRock SUPPORT
Tech Support Email: user@asrockamerica.com
69charger ::
ASRock ponuja čisto dobre plate, tisti pa ki ne vejo kaj govorijo bodo pa tolkli po njih.
TOP ::
69charger je izjavil:
Točno tako.Sam se enkrat mel neko obično plato od Asrocka in sem jih vedno klincal,da so krap plate in podobno,nakar sem se opogumil in vzel Extreme3 gen3 za I5 proc in moram reč super plata.Nekateri ne veste,da je včasig Asrock spadal pod Asus,ampak sedaj so se odcepli in ponujajo bolše plate za malo denarja,kot na primer Asus ali Gigabyte.Doma mam še P67 Gigabyte UD4,ki pa jo ne zamenjam,ker se ful dobro navija.Sprobal sem tud nekaj Asusovih P67 amapak so me razočarale.Tako da Asrock,kakšne Extreme plate so super plate.
KTr1sk ::
Sem danes že sestavil comp in morem potrkat da plata Asrock Z77 Pro4 bo zame čist ok,hladilnik je pa tako majhen tisti ki je priložen zraven 3570k, tako da navijenje odpade, če bi še imel stari dobr hladilnik mugen2 bi bilo super, ker ima plata tudi luknje za 775 hladilnik!
temperatura na stock hladilniku 3570k
(je prišla čez 50°C in nič konkretnega ne delam ...inštalirajo se programi in gonilniki)
fr4nc ::
KTr1sk je izjavil:
Hmmm... to pa je slab podatek :|.
Jaz sem imel i5 2500K navit na stock coolerju, zdaj pa ne bom mogel i5 3570K niti "malo" naviti ali kaj praviš?
TOP ::
Z stock hladilnikom nimaš kaj dosti navijat,ker pri obremenitvi so temperature,kaj hitro visoke.
fr4nc ::
TOP je izjavil:
So sad :'(... Kater cooler predlagate - SLO trg, cena cca. 40€?
Lp in hvala
KTr1sk ::
@fr4nc : 2500k nisem imel nikoli, ti sam veš če si imel manj °C na stock hladilniku z stock frekvencam, sam imam takšen hladilnik
in ohišje imam dobro prezračeno, spredaj in zadaj 120cm ventilator
fr4nc ::
KTr1sk je izjavil:
Temperatura je bila pač primeerna (ni bila ekstremna - še v normalnih/spremenljivih mejah za CPU)
V ohišju pa sem imel 5x120mm 2000rpm, tako da je bil v ohišju kar prijeten prepih 8-).
KTr1sk ::
Sem opazil na plati da,čeprav je ugasnjen računalnik, vseeno sveti miška oz vse kar je na usb priklopjeno in kar ima lučko sveti, nekje se verjetno to izkopi v biosu..ve kdo?
Janac ::
si priklopil na rdece usbje?
KTr1sk ::
sprednji usb, zadaj 2.0 (črni) in zadaj 3.0 (modri)..pri vseh je enako..sveti...nimam rdeče usb izhode
Janac ::
gigabyte ma tako...
katero plosco pa imas?
TOP ::
KTr1sk je izjavil:
To so posrečeni hladilnik od Intela,ki jih dajajo zraven procov.V resnici so hladilniki za en drek.Ko se naberejo praha se lepo zapackajo in potle vent začne lepo cviliti.Tako da si prisiljen vsake toliko spihati.
s51as ::
Ne vem če je kak cooler imun na prah.. :D
KTr1sk ::
Janac je izjavil:
gigabyte ma tako...
ja Asrock z77 Pro4 imam
KTr1sk ::
Brainstorm je izjavil:
..in katero ploščo si potem nabavil?
Brainstorm ::
Še nobene, ker sem malo ckviknil okoli novih Ivijev, ki se tako grejejo, čakam, da poda Intel uradno izjavo ali bo kaj popravil okoli tega ali bo pustil tako kot je. Ker se mi itak nikamor ne mudi.
Imam pa občutek, da bom nazadnje celo vzel plato od Asusa, da še malo zamenjam firme in sicer model P8Z77-V Z77.
korenje3 ::
neumnost. ASUS P8Z77-V Pro Z77 ima PCI slot.
2
Nakup gaming računalnika (strani: 1 2 )
5211657 (6669) Gox89
1155 plata
191648 (1203) Xserces
Katero 1155 maticno?
445626 (4334) Dr_M
Katero in kje kupiti osnovno ploŠčo z vodilom 1155 in sata3 priključkom
353922 (3490) easyrider3
