Forum » Programiranje » [c#] iz class v class
japol ::
V class Prerezi.cs imam:
Kako dostopam do teh listov (List1,..., lista,...) iz drugega classa (npr. iz Meni.cs)?
public class Lists
public List<string> List { get; set; }
public List<string> List1 { get; set; }
public List<string> List2 { get; set; }
public List<string> List3 { get; set; }
public List<string> List4 { get; set; }
public List<string> List5 { get; set; }
public List<Image> ListSlike { get; set; }
public void DodajVBazo(Form1 f1)
List<string> list = new List<string>();
Lists lista = new Lists();
List<string> list1 = new List<string>();
List<string> list2 = new List<string>();
List<string> list3 = new List<string>();
List<string> list4 = new List<string>();
List<string> list5 = new List<string>();
List<Image> listslike = new List<Image>();
lista.List = list;
lista.List1 = list1;
lista.List2 = list2;
lista.List3 = list3;
lista.List4 = list4;
lista.List5 = list5;
darkkk ::
Do katerih listov :) ?
Verjetno boš mel problem, če boš hotel dat Listu ime List, torej daj raje ime list :P
Uglavnem tale tvoj dodajVBazo bi moral bit kar konstruktor, ampak...
Lists seEnList=new Lists(); //klices default konstruktor seEnList.DodajVBazo(f3); //f3 je pac neka forma List<string> neMeJahatSeEnList = seEnList.list1; //dobis ven list1 iz instance seEnList, ki je razreda Lists.
- spremenil: darkkk ()
japol ::
Poskusil sem tako:
a mi javi da je list enak null. V resnici pa vsebuje podatke.
public void Shranitev2(Form1 f1)
Prerezi.Lists p = new Prerezi.Lists();
SaveFileDialog saveFile1 = new SaveFileDialog();
saveFile1.DefaultExt = "*.txt";
saveFile1.Filter = "txt Files (*.txt)|*.txt|All Files (*.*)|*.*";
if (saveFile1.ShowDialog() == System.Windows.Forms.DialogResult.OK && saveFile1.FileName.Length > 0)
StreamWriter sw = new StreamWriter(saveFile1.FileName);
for (int i = 0; i < int.Parse(f1.treeView1.Nodes.Count.ToString()); i++)
f1.treeView1.SelectedNode = f1.treeView1.Nodes[i];
for (int j = 0; j < p.List.Count; j++)
sw.WriteLine(pp.lista.List[1].ToString());
sw.Close();
darkkk ::
Ti nikjer ne nafilaš tvojega Prerezi.Lists p-ja. Kliče se z default constructorjem, vsi memberji so null. (tj. p.List -> null)
Poleg tega v vrsti 10: f1.treeView1.Nodes.Count -> integer, ne rabiš tega to string pa parsat v int, ali?
Poleg poleg tega: vrsta 15, od kje se je pp vzel, kaj je to?
(če pa hočeš videt, kaj maš noter, daj si breakpointe med kodo :) )
japol ::
Potrebujem vsebino iz List1, List2,.... in list1, list2,... v nekem drugem classu (Meni.cs). Kako to naredim?
- pp je mišljen p
- z breakpointi si pa v tem primeru ne morem pomagati ker edino kar mi pove da je lista.list enaka null
- s klikom na nek gumb se zafilajo Lists in niso prazni.
Sedaj razmišljam če uporabim sledeče:
ampak tudi v tem pirmeru porebujem vsebino vseh "list1",... v nekem drugem classu.
- pp je mišljen p
public class Lists
lista.List = list;
list.Add(f1.textBox35.Text);
list.Add(f1.textBox36.Text);
list.Add(f1.textBox37.Text);
TreeNode node;
node = f1.treeView1.Nodes.Add("P: " + f1.textBox35.Text);
node.Nodes.Add("E: " + f1.textBox36.Text);
node.Nodes.Add("Pr: " + f1.textBox37.Text);
node.Tag = lista;
| » | [c#] shrani text, tabele, slikeOddelek: Programiranje | 2010 (1616) | Kemalito |
| » | C# tabelaOddelek: Programiranje | 1393 (1245) | Mitja Bonča |
| » | c# datagridview in comboxOddelek: Programiranje | 1634 (1522) | OmegaM |
| » | [c#]: iz ascx v ascxOddelek: Programiranje | 1091 (943) | nuclear |
| » | c# base class, derived class, inheritance problemOddelek: Programiranje | 1816 (1695) | Vapo1 |
