windows media center (nikakor ne gre izklopit)
djforever ::
lp, danes me je kolegica poklicala da ne more nikakor nainternet pa nič
pridem do njenega prenosnika in vidim da se vedno ko hoces kaj naredit vklopi windows media center
kako izklopit,probalsem že v services disabled, pa po tistih vse postopkih,
bojim se da bom mogel ponovno naložit sistem
Cold1 ::
Po vsej verjetnosti so se ji datotečni tipi povezali z WMC-jem, če nimaš na voljo nobene obnovitvene točke si pomagaj z kakim znanim obnovitvenim postopkom.
Za več si poglej tule:
Windows XP File Association Fixes
http://www.dougknox.com/xp/file_assoc.h...
The files listed here are all ZIP files, which contain a REG (Registry) file. Download the ZIP and open it. Extract the REG file to your hard disk and double click it. Answer yes to the import prompt. REG files can be viewed in Notepad. Each of the REG files contains the default settings for the file extension indicated. For the ZIP file fix, the download is a REG file, since ZIP's aren't working anyway!
NOTE: If your EXE file associations are corrupted, it can be difficult to open REGEDIT, or to even import REG files. To work around this, press CTRL-ALT-DEL and open Task Manager. Once there, click File, then hold down the CTRL key and click New Task (Run). This will open a Command Prompt window. Enter REGEDIT.EXE and press Enter.
In tule:
File Association Fixes for Windows 7
http://www.winhelponline.com/blog/file-...
File association fixes for Windows Vista
http://www.winhelponline.com/articles/1...
18zimoni ::
Poskusi z tem programom.Meni je uspelo rešit podobno napako.
http://www.thewindowsclub.com/repair-fi...
djforever ::
tnxx
Kako spremeniti programe :s
161418 (1001) butec
ikone!
71527 (1476) gogolinho
Adobe reader in Ikone
8917 (855) Duhec
ping težava s start /run meniju
51337 (1249) Duhec
Vse .exe datoteke -> .lnk
62635 (2635) axxxe
