Slo-Tech 3D Team: unigine heaven 3.0
freesty ::
Najprej preberi prvi post v celoti!
Rezultate postaj v to temo. Updatal bom koliko bom na internetu.
Download: http://unigine.com/products/heaven/down...
Nastavitve:
Render: Direct X 11
Mode: 1680x1050 fullscreen
Shaders: high
Textures: high
Filter: trilinear
Anisotropy: 16x
Occlusion: enabled
Refraction: enabled
Volumetric: enabled
Anti-Aliasing: 8x
Tessellation: extreme
Naredi screenshot(F12) po koncanem benchmarku pri prvi sceni(kamnita pot) zato, da se vidi, če je tesselation prižgan.
Poleg še napiši:
nickname - OS - procesor / hitrost - GPU / core / shaders / memory - FPS - rezultat
Rezultati:
1. freesty | Radeon 7950 | 57.2 | 1440
freesty ::
REZULTATI:
1. 01001 - i7-3770K @ 4800 - GTX690 QUAD SLI @ 1210 - 193.9 - 4883
2. cole-22 - i7 3770K @ 4500 - 2× GTX680 @ 1200 - 112.8 - 2842
3. Moonman - i7 2600K @ 4,9Ghz - GTX480 SLI / core@850 / memory@1075 - 75.7 - 1906
4. GaŁu - i5 2500K @ 4800MHz - Radeon 7950 / core@1250 / memory@1905 - 60,6 - 1527
5. freesty - i5 2500k @ 4800Mhz - Radeon 7950 / core@1210 / memory@1750 - 57.2 - 1440
6. Nwanko - i5 750 @ 4000Mhz - Radeon 7950 / core@1250 / memory@1550 - 57 - 1436
7. 18Jerry18 - i5 3570K @ 3400Mhz - Asus gtx670 /core@1202/ memory@3557 - 54.6 - 1376
8. Smukec - i5 3570K @ 3400Mhz - GTX670 / core@1058 / memory@6008MHz - 49.5 - 1246
9. miraldinjo-i5 2500k @ 3300Mhz - Radeon 7870 / core@1320 / memory@1420 - 48.5 - 1222
10. Silverwing- i5 3570K @ 3400Mhz - Radeon 7870 / core@1240 / memory@1385 - 45 - 1133
11. fr4nc - AMD FX-8120 @ 4500Mhz - Radeon 7850 / core@1210 / memory@1390 - 42.6 - 1072
12. 6151 - i5 2500k @ 4600Mhz - GTX 570 / core@926 / shader@1852 / memory@2100 - 40.6 - 1024
13. TechBeats - Q9450 @ 3520Mhz - GTX 570 / core@950 / shader@1900 / memory@2250 - 40.6 - 1023
14. timek - i5 3570K @ stock - Radeon 7950 @ stock - 38.9 - 980
15. taz - i7 870 @ 3855MHz / Radeon 6950@6970 / core@1030 / Memory@1500 - 33.1 - 835
16. Janac - i5 661 @ 4524,31Mhz - / MSi Radeon 6950 TF2\OC 2Gb core@985 / memory@1350 - 29.8 - 752
17. sLoTigerMaN - i5 2500k @ 3300Mhz - Radeon 6970 / core@880MHz/ memory@1375MHz - 29,1 - 734
18. Janac - i5 661 @ 4446Mhz - GTX 560 1Gb / core@933 / shader@1620 / memory@2120 - 26.1 - 658
19. JC Denton - Phenom II 970T @ ?? - Radeon 6870 / core@945 / memory@1150 - 24.6 - 619
20. einstein400 - 2× Xeon 5120 @ 1866 MHz - Radeon 6850 /core @850 / memory@1200 - 20.1 - 505
21. nofaith - q6600 @ 2700 Mhz - gtx 460 786mb /core@900 / Shader@1800 / memory@2200 - 17.6 - 443
  • spremenil: freesty ()
Icematxyz ::
Glede na to da so podprte vse tri večje platforme bo kot kaže to lahko ena prva takšnih "cross-platform" "benchmark" tem na slo-tech, kar je seveda razveseljivo, če se bodo seveda našli zainteresirani uporabniki. Kolikor vem česa takšnega še s tako kvalitetnim in enostavnim orodjem za merjenje zmogljivosti ni bilo moč početi?
Predlagam torej, da če se pojavijo zainteresirani uporabniki še s drugih platform da še dopišejo OS (in nastavitve), ki ga torej uporabljajo.
freesty ::
Nima noben vole tole spustit na svojmu kompu? =\
Bananovec ::
Bom jaz, če ne bo kartica klecnila, ker je rahlo defektna.
Regards, Apple
Bananovec ::
Se pardoniram, vendar je benchmark neusprešen pri meni. Bom ponovil test čez kakšen mesec, ko bom predvidoma dobil kartico nazaj.
Regards, Apple
miraldi ::
Bom jaz zdle spustu heaven 3d benchmark ;)
i7 12700k
RTX 4070ti
32Gb
miraldi ::
Evo freesty sem dal kar iste nastavitve za Heaven DX11 Benchmark kot ti:
Nastavitve:
Render: Direct X 11
Shaders: high
Textures: high
Filter: trilinear
Anisotropy: 16x
Occlusion: enabled
Refraction: enabled
Volumetric: enabled
Anti-Aliasing: 8x
miraldinjo- i5 2500k / 3300Mhz stock- Radeon 7870 / core 1100Mhz / memory 1200Mhz- 42.2 / 1068
Pa še screenshot:
http://shrani.najdi.si/?3G/Yu/E9NtHZp/0...
i7 12700k
RTX 4070ti
32Gb
  • spremenilo: miraldi ()
freesty ::
Kul, cim vec da se vidi katera grafa je res p/p.
fr4nc ::
Jaz bi spustu, sam lahk nastavlam le: API, Tessellation, Shaders, Anisotropy, Stereo 3D, Anti-aliasing ter resolucijo...
Kje Vi to najdete: Occlusion, Refraction in Volumetric??
freesty ::
 nastavitve
nastavitve
Evo takle mors met:)
fr4nc ::
Aha TNX! Bom pognal potem.
fr4nc ::
freesty je izjavil:
Heh :)).
Če je to edini namen tega testiranja je dejansko bzv - ker to se itak ve - 7850 :P.
Bom pa vseeno dokazal ;)!
fr4nc ::
Evo:
fr4nc - AMD FX-8120 / 4500Mhz - Radeon 7850 / core@1135 / memory@1390 - 41.1 - 1036
Grafična je na stock voltaži... mogoče se še malo poigram.
Samo škoda, da sem prodal primerek, ki je dosegel 1293/1566 @1.225V :|.
freesty ::
Zaka pa si prodal? :o
Janac ::
lahko tudi jaz?
fr4nc ::
freesty je izjavil:
Ker sem prodal cel PC takrat ;((.
freesty ::
Janac je izjavil:
lahko tudi jaz?
Ja seveda, zato je ta topic.
franc ka zaj si kupu cist isto verzijo kartice?
fr4nc ::
freesty je izjavil:
Da prej sem imel SAPPHIRE 7850 pa zdaj mam - sam prejšnji primerek je imel ASIC 88,9%, ta pa ima le 74% ;((, kar je ogromna razlika :'(.
Sej bi kupil 7870 sam se itak ne splača (kar sem dokazal v tej temi ;)), 7950 pa je že predraga.
Janac ::
evo jaz imam nastavitve:
Time: 259.977
Frames: 5475
FPS: 21.0595
Min FPS: 7.14832
Max FPS: 55.3177
Scores: 530.49 -> very very bad
THEbassfreak - Win7 ultimate x64 - i5 661 stock / NVIDIA GeForce GTX 560 stock / 900 MHz / 1800 MHz / 4000 MHz - 21.0595 - 530.49 :(
fr4nc ::
Še z dvigom voltaže (dlje res ne gre :8)):
fr4nc - AMD FX-8120 / 4500Mhz - Radeon 7850 / core@1210 / memory@1390 - 42.6 - 1072
Janac ::
kaj pa se hoces saj imas enkrat vec score kot jaz;)
fr4nc ::
Janac je izjavil:
Heh :)). Tvoja resolucija ni zanemarljiva.
Probaj dat na 1680x1050.
freesty ::
Janac popravi screenshot pa resolucijo.
Janac ::
kaj???
jaz bi dal lahko na veliko vec ce zelite :)
freesty ::
Pa fora je da das na majn, da lahko primerjamo rezultate.
Kaj se tu zaj z resolucijo ven meces, daj da vidimo kak rezultat dobis na svoji grafi pri 1680x1050.
Janac ::
Ok. Samo toliko v vednost jaz imam 1920x1080 monitor :))
ok bom sedaj dal na 1680x 1050 kaj se moram spremenit?
pa kako naj prt_scr posnamem na koncu ko ti pove rezultate?
  • spremenil: Janac ()
freesty ::
F12 prtisnes
Screenshot se ti shrani tule:
"C:\Users\Username\Unigine Heaven\screenshots"
Nastavitve mas malo visje v mojem postu sliko kaj moras nastavit.
Janac ::
samo resolucijo potem.
ok bom dal f12 ker prt-scr nedela :(
nebom sem lepil slike ker je samo 30score vec :(
miraldi ::
Mal sem razočaran nad mojo 7870 pri temu benchmarku ker je isti k**** kokr 7850 čeprav vem da se v igrah bolj poveča razlika v performancu sorazmerno z ceno med njima. Kok naj bi bilo razlike med 7850 in 7870 15% ?
i7 12700k
RTX 4070ti
32Gb
Janac ::
Mislim da ima franc svojo navito :)
fr4nc ::
Janac je izjavil:
Ja sej jaz mam tudi ;). Pa lahk vseeno dam na 1680x1050.
freesty ::
@miraldinjo spravi svojo na 1200+ core pa 1400memory, potem bo bolj opazna razlika.
fr4nc ::
miraldi je izjavil:
Testiraj kak Far Cry 2 pa FullHD pa vse na ultra ša javi rezultate na ZS.
miraldi ::
Kje pa se to navije a v catalyst control center tam pod amd overdrive? A to kaj škoduje grafični? Bom Naredu test še z Far Cry 2.
Franc a to si navil svojo 7850?
Katere driverje uporabljate catalyst 12.6 ali beta 12.7?
i7 12700k
RTX 4070ti
32Gb
fr4nc ::
Ja sem navil svoja ja... core iz 860 na 1210, memory pa iz 1200 na 1390 ;).
Lahko tam ja, ali pa kak Sapphire trixx ipd.
Jaz imam 12.4 driverje.
freesty ::
http://shrani.najdi.si/?18/10b/wpspcvj/...
freesty - i5 2500k / 4800Mhz - Radeon 7950 / core@1200 / memory@1750 - 57.2 - 1440
Evo že mamo top3 :)
miraldi ::
Sem navil svojo 7870 GPU 1245 in memory na 1560 da bojo bolj primerljivi rezultati(use tri navite) pa mi je pri drugem delu heaven zaštekal vrglo ven pa javlo neko napako pa ni važno katero resolucijo izberem: d3d11 APPwindow do_swap device remowed
Kaj to pomeni? Kakšne rešitve?
i7 12700k
RTX 4070ti
32Gb
fr4nc ::
Dvigni voltažo grafične kartice - če ne veš kako - poglej tuje forume + yt ;)
miraldi ::
Sem že dojel kaj je narobe gledu sm overclock za Saphire 7870 namesto za Gigabyte 7870. Bom objavil teste overclocane grafe pa brez dvignjene voltaže ker naj bi blo to rizično početje.
Zaenkrat si z svojo navito 7850 malo prehitel stock 7870 :|
Od katere firme pa imate grafične?
i7 12700k
RTX 4070ti
32Gb
Janac ::
gigabyte windforce x2 :)
fr4nc ::
miraldi je izjavil:
Ti imaš svoje že tovarniško navito - Gigabyte Radeon HD 7870 2GB OC - stock clock je 1000MHz, tvoja ima 1100MHz ;).
Jaz imam SAPPHIRE, sam ne ono OC verzijo, ampak navadno (stock core: 860MHz, memory: 1200MHz) :D.
freesty ::
miraldi je izjavil:
Te kartice se tak isto navijajo nima veze katero imas...
Ti lahko brez skrbi dvignes voltazo, ker imajo itak kartice zascito in Voltdrop tako, da ne mores skurit. Do +125mV je povsem varno sam temperature malo glej, da ne bojo prevec narasle.
@Janac daj objavi rezultate, da vidimo.
miraldi ::
Mal sem narobe napisu mislu sem stock tovarniško(100Mhz navita brez mojga navijanja)vzel sem jo bolj zaradi hlajenja in tišine ker so tisti trije ventilatorji res super glede tega bravo gigabyte winforce :D.
fr4nc kar pošteno si jo navil kaj nej ti rečem ;)
i7 12700k
RTX 4070ti
32Gb
fr4nc ::
miraldi je izjavil:
Ma to niti ne, ker ne gre (je malo slabši primerek)... s prejšnjo 7850 je šlo na 1293/1566 :D
fr4nc je izjavil:
freesty ::
Kak si pa prisel na 1293? Na 1300 ni bla stabilna?
fr4nc ::
freesty je izjavil:
Večurna testiranja... nope ni šlo na 1300 :'(.
Sem prigoval po 1MHz na koncu, na 1294 ni spustilo skozi.
miraldi ::
Evo rezultati mojega navijanja brez spreminjanja voltaže:
Nastavitve:
Render: Direct X 11
Shaders: high
Textures: high
Filter: trilinear
Anisotropy: 16x
Occlusion: enabled
Refraction: enabled
Volumetric: enabled
Anti-Aliasing: 8x
miraldinjo- i5 2500k / 3300Mhz stock- Radeon 7870 / core 1200Mhz / memory 1375Mhz- 45 / 1133
Je pa z Catalyst 12.6 kr za kakšen procent boljši rezultat kako z Beta 12.7 pol mi je mogoče boljše imeti 12.6 tudi za igre..
i7 12700k
RTX 4070ti
32Gb
fr4nc ::
Aha... bom dal potem gor 12.6 pa poročam - če je bolje kot 12.4 ;).
freesty ::
miraldinjo probas se procesor navit pa bos se par fpsjev pridobil:)
1 / 11
Slo-Tech 3D Team: Unigine Valley 1.0 (strani: 1 2 3 )
Oddelek: Navijanje
10729942 (18005) dj_uro
Unigine Heaven 4.0 (strani: 1 2 3 )
Oddelek: Navijanje
10651084 (36490) barocco
