Katero tablico izbrati?
kmetek ::
link prosim.
floyd1 ::
schrack je izjavil:
Za 144 evrov dobim iz Nemčije 7" tablico Lenovo Ideapad A1 z GPS-jem.
Je še kakšna alternativa za približno tak budget?
Kolikor se spomnim testov, je ahilova peta te tablice njen ekran, ki je (po nekaterih testih sodeč) povsem nevreden imena Lenovo. Že pri manjših premikih tablice menda vidno spreminja barve, svetlejši odtenki postajajo temnejši ali izginejo, itd. Je pa ta cena res dobra.
Tu recimo piše:
Display
Lenovo IdeaPad A1 ScreenClick to EnlargeMiles behind its competitors in display quality, the IdeaPad A1's 7-inch, 1024 x 600 screen provided dull, grainy images and mediocre viewing angles in our tests. When we streamed an HD trailer of "The Avengers" from YouTube, the edges of objects looked pixilated and colors such as the orange fire in an explosion just didn't pop as much as they had on the Kindle Fire, Barnes & Noble Nook Tablet or Toshiba Thrive 7-inch.
Worse, when we angled the tablet away from our body, or twisted it left or right, colors started to really wash out. Perhaps we should not be surprised because, at full brightness, the IdeaPad A1's screen registered only 271 lux on our light meter, far less than the Kindle Fire's 460, the Nook Tablet's 392, or the Galaxy Tab 7.0 Plus's 326. All of the competitors offered far superior viewing angles, sharpness and color vibrancy.
schrack ::
To sem tudi sam zasledil.Malce sem v dvomih,glede nakupa. Čeprav bi jo potreboval le za hitri pregled forumov,kak tv spored in kakšenkrat kot navigacijo z igo-tom.Bom še malo premislil.
akulp ::
floyd1 je izjavil:
schrack je izjavil:
Tu recimo piše:
Display
Ja tudi jaz sem to bral, vendar sam (plus še dva kolega) zanikam. Kar je edino problem, proti gledano, cenovno precej dražjim tablicam je vidni kot in to, da moraš malenkost bolj pritisniti, kar sicer mene osebno do zdaj še ni oviralo.
Sicer pa forum:
http://forum.xda-developers.com/showthr...
Tudi v tej temi, ki jo spremljam od začetka do konca, zgoraj omenjenih težav nihče ne omenja.
LP,L
Aja, če sta kje blizu Kranja-Lj, se lahko zmenimo, pa preverita delovanje v živo.
Lukcc
  • spremenil: akulp ()
kmetek ::
še vedno čakam na link za 144€ :P
kmetek ::
tabonir ::
kmetek je izjavil:
zmagovalec
AKTION: Acer Iconia Tab A700 schwarz Full HD 10" Tablet Tegra 3 & Android 4.0
Kaj vem no. Nekak bi raje imel asus t. pad 300.
schrack ::
kmetek je izjavil:
Kmetek,poglej na ebay.de,prodajalec je delfitec in kao pošilja samo v de.Cena je 132 evrov samo še danes. Prodajalec mi je napisal,da mi pošlje v slo za 14 evrov.Je varno klikniti danes v košarico,ker mi mora spremeniti lokacijo glede pošiljanja?
kmetek ::
schrack ::
kmetek je izjavil:
139+14
Lenovo Ideapad A1 - 16GB, Wi-Fi, 7" Zoll - Multitouch - GPS - White Edition
Lenovo Ideapad A1 - 16GB, Wi-Fi, 7" Zoll - Multitouch - GPS - Black Edition
ima on še Pink sem videl.
Ta je :).
Imel je pa do zjutraj 5% OFF in dostavo samo po Nemčiji.
Očitno je popravil oglas.
schrack ::
sulaco ::
Pa sta vidva videla da je to POPRAVLJENA ROBA??
""B-Ware Info: Die Artikel stammen aus der Servicebearbeitung (Austausch/Rep.) des Herstellers Lenovo GmbH im Zuge der Garantie"
Kupite iPAD 2 verzije 2.4. Gor dela vse.
schrack ::
sulaco je izjavil:
Ja.Nabavil do sedaj 2 Garmina tovarniško obnovljena in delata po cca 2 letih bp.Za moje potrebe bo več kot dovolj.
blaz_89 ::
Zdravo,
nameravam kupiti tablični računalnik in ker nisem neki poznavalec katere tablice so dobre in katere ne se obračam na vas za predloge kaj kupiti. Nekaj malega sem brskal po spletu in si ogledal več tablic. Moja želja pri specifikaciji tablice je naslednja:
zaslon: 7" - 10.1"
Ločljivost: 1024 x 600
procesor: 1,2GHZ ali več
pomnilnik: 1 GB DDR3
notranji spomin: 8 GB (ali pa 4 GB in dodatno micro sd kartico velikosti 16GB)
Tablica bom uporabljal za brskanje po internetu, branju pdf in word dokumentov, poslušanje glasbe in gledanje filmov ter občasno odigral kakšno igrico. Kolikor sem med brskanjem zasledil je pri nekaterih tablicah problem ločljivost in počasno nalaganje aplikacij zato želim ločljivost in pomnilnik nekaj takšnega kot sem napisal zgoraj. Ali se pri tem motim in to ne vpliva veliko na delovanje tablic. Moj budget je nekje 200€. Tak da prosim za kakšen linke do tablic, ki mi jih priporočate.
Hvala, lp Blaž.
damjanll ::
Blaz:
Jaz bi priporocal tole:
Samsung Galaxy Tab 2 7" (259 EUR) :
http://www.prvavrsta.net/si/izdelek/558...
Kupil sem ga tudi sam kak teden nazaj in sem super zadovoljen. Sicer ni 1.2 GHz ampak 1 GHz dual core.
Lahko pa pocakas na Google Nexus Tablet 7 ki bo danes objavljen, vprasanje pa kdaj in ce pride to do nas.
floyd1 ::
Za začetek bi (bo) tudi Googlova najava naredila nekaj. Malo cenovnega pritiska, če ne drugega.
Drugače pa je zgornji predlog (Galaxy Tab 2) tudi moja trenutna izbira, če se bom sploh odločil za nakup. In tudi "samo" 1GHz dual core bo še nekaj časa delal OK.
  • spremenil: floyd1 ()
damjanll ::
Evo Nexus 7 je objavljen, izgleda super:
- Tegra 3
- 1280x800
- $199
Ampak samo za USA, UK & Australia. Kdaj bo prislo to v evropo kaj sele v slovenijo se mi pa ne sanja...
whitefish ::
V Sloveniji bo sigurno 199€...
medenko ::
to je najmanj kar bo če bo sploh kdaj na voljo, baje nima sd slota?
whitefish ::
Koliko spomina pa ima?
medenko ::
16/32
whitefish ::
To je dovolj :)
damjanll ::
Nexus 7:
http://www.theverge.com/2012/6/27/31204...
8GB: $199
16GB: $249
carota ::
damjanll je izjavil:
- Tegra 3
- 1280x800
- $199
Pa Android 4.1 ima, Bluetooth, NFC in 9h battery life.
Nisem pa zasledil če ima tudi GPS. Glede na Google Maps bi pričakoval, da je.
whitefish ::
floyd1 ::
GPS zgleda ima.
Samo 8 in 16 GB verziji brez mSD, tu 32 GB res ne bi bila švoh, ampak važna je bila cena... :(
Kar ponujajo za to ceno je (kljub zgoraj omenjenemu kiksu) - FENOMENALNO.
gregyk ::
V UK je cena 159GBP za 8GB verzijo, kar po današnjem tečaju znese cca. 200€.
Uradni podatki:
Screen
7" 1280x800 HD display (216 ppi)
Back-lit IPS display
Scratch-resistant Corning glass
1.2MP front-facing camera
Size
198.5 x 120 x 10.45mm
Weight
340g
Wireless
WiFi 802.11 b/g/n
Bluetooth
Memory
8 GB internal storage
1 GB RAM
USB
Micro USB
Battery
4325 mAh (Up to 8 hours of active use)
OS
Android 4.1 (Jelly Bean)
CPU
Quad-core Tegra 3 processor
Features
Microphone
NFC (Android Beam)
Accelerometer
GPS
Magnetometer
Gyroscope
medenko ::
gregy kok pa 16gb?
gregyk ::
medenko je izjavil:
gregy kok pa 16gb?
199 GBP = cca. 250€
Na tem linku si poglej (preko UK proxy-ja, ker če se ne uporabi proxy-ja, javi, da stvar v naši državici ni dosegljiva): http://proxay.co.uk/go.php?u=AcTJahse9E...
  • spremenil: gregyk ()
FlyingBee ::
verjetno bo prišla v Slovenijo tudi, kot smo tudi dočakali iphone v preteklosti ... US fore
whitefish ::
Sprva so govorili da bo 160e...
medenko ::
ja sej to je 199$ = 160€....za 200€ bi jo kurba vzel, kdo za skupinski nakup hehe?
whitefish ::
Ne hvala,sem tik.pred nakupm.SGS3 ali One X...
Da,samo problem je v tem da bo v Sloveniji tudi okoli 199€...
gregyk ::
gregyk je izjavil:
medenko je izjavil:
gregy kok pa 16gb?
199 GBP = cca. 250€
Link ne dela - direktna povezava je: https://play.google.com/store/devices/d...
UK proxy pa: http://proxay.co.uk
medenko ::
kam že vpišeš ta proxy?
aha odpreš in skopiraš itd....jap dela.....mene ful zanima tablica.
  • spremenilo: medenko ()
plavko61 ::
počasi bo fajn imet kak MiFi pri roki.
http://www.ztemf60.co.uk/
Dvakrat preberi, nato pa blekni...
medenko ::
to je, vzameš mobilni internet, pokneš sim notri in deluje kot neke vrste router?
kaj je potem drugače od ETH. ASUS WiFi N ruter + 3G (WL-330N3G)
damjanll ::
FlyingBee je izjavil:
Meni se pa na zalost zdi da je verjetnost majhna. Po moje ne bo na voljo v sloveniji, dokler ne bo celoten play store na voljo v sloveniji torej movies, music, books,... zato ker po moje, ce nekje play store ni dostopen nima smisla da tam prodajajo tablico brez dobicka... Pri nas so v play store na voljo samo android apps.
medenko je izjavil:
Hmm jaz bi bil za, samo kam bi pa to narocu, poznas koga iz UK?
  • spremenilo: damjanll ()
medenko ::
sprašujem na uk forumu, možnosti so 1:100000 hehe.
Google Nexus 7 and Android 4.1 - Mini Review
m0LN4r ::
Malo si bom sposodil temo. Razmišljam o darilu v obliki tablice:
http://www.mimovrste.com/artikel/272000...
Ta je najcenejša in največja tablica, ki se jo da dobit. Velikost mi je pomembna ker so mere diagonale enemu A5 listu.
Tablica bi se uporabljala za branje pdf, word, excel itd. dokumentov brskanje po spletu in branju. V glavnem 90% samo branju.
Zanimajo me vaša mnenja glede te tablice, kot darilo za nekoga ki veliko bere različne dokumente na prenosniku. Ali je primerno in zadovoljivo?
https://www.youtube.com/user/m0LN4r
damjanll ::
m0LN4r je izjavil:
Najbrz je ok, samo mogoce je malo svoh resolucija za 10" (1024 x 600) taka resolucija je ponavadi na 7" tablicah, za 10" bi bilo najbrz fajn ce je vsaj 1280x800 po moje...
sebamatko ::
Če je kdo za skupinski nakup Nexus 7, naj me prosim obvesti. :)
bdoxx ::
kje boš naročal?
damjanll ::
Hmm, jaz sem interesent za nakup, samo, kako?
sebamatko ::
Hm.. Iz google playa spomočjo http://www.izanglije.com/ oz. kakšne podobne strani... samo treba počakat do sredine julija, da zadeva izide :)
kmetek ::
schrack ::
Po dolgotrajnem premisleku sem naročil 7" kitajčka z IPS zaslonom:
http://www.pandawill.com/ainol-novo-7-a...
Cena je okoli 120 evrov( za prvi naročeni izdelek na pandawill dobite 5% popusta s kuponom), če mi gre skozi carinsko pošto, drugače pa še skoraj 30 evrov zraven.
Aurora II je že odposlana. Naknadno sem zasledil, da prva serija je imela težave z wi-fijem.V najslabšem primeru jo bo treba odpret in porihtat kabel od antene.
Še opozorilo, če kdo od vas slučajno naroča na Pandawill, naj se najprej pozanima na forumu, če je stvar na zalogi in dobavljiva.
V nasprotnem primeru lahko čakate tudi po več mesecev na željeni artikel.
  • spremenilo: schrack ()
MI5Ek- ::
Katero tablico izbrati izmed teh treh:
WayteQ xTAB-100is
Yarvik GoTab Zetta 9.7" (TAB468EUK)
Prestigio MultiPad PMP5097 PRO
Koliko sem gledal specifikacije tablic dokaj podobne. Prestigio ima 16GB notranjega spomina, WayteQ in Yarvik 8GB. Prestigio ima 6000mAh baterijo, WayteQ in Yarvik 8000mAh. WayteQ nima HDMI izhoda, Prestigio in Yarvik ga imata. Mislim da tudi Google Play deluje na vseh treh tablicah.
Je že imel kdo opravka s katero izmed teh tablic? Kako mnenje? Mogoče katero drugo 9.7" tablico v rang do max. 250EUR.
Niko_ ::
Zdravo tudi jaz imam eno vprašanje za vas, ki se bolje spoznate na tablične računalnike. Zanima me katero od naslednjih tablic naj kupim:
Pa zanima me še glede velikosti kaj je boljši 10" ali 8"? Drugače pa prosim če mi predlagate kakšno drugo tablico v rangu do 200 €.
Hvala za pomoč, Niko_
4 / 183
