[android] java.lang.RuntimeException
piki12 ::
Dober večer vsem,
rad bi vpašal zakaj se mi naredi napaka ko z naslednjo kodo naložim recimo z dropboxa ali pa z nekega določenega placa, oz če slikam sliko mi javi za ta del napako. Če pa hočem naloadati sliko z galerije mi pa zadeva dela odlično. Sedaj me zanima zakaj, je ta del tako občutljiv..
@Override
protected void onActivityResult(int requestCode, int resultCode, Intent data) {
    if (resultCode != RESULT_OK) return;
    switch (requestCode) {
        case PICK_FROM_CAMERA:
            this.picturePath = picturePath;
            Intent intent1 = new Intent(getBaseContext(), AndroidPaint.class);
            startActivity(intent1);
            break;
        case PICK_FROM_FILE:
            Uri selectedImage = data.getData();
            String[] filePathColumn = {MediaStore.Images.Media.DATA};
           Cursor cursor = getContentResolver().query(selectedImage, filePathColumn, null, null, null);
            cursor.moveToFirst();
            int columnIndex = cursor.getColumnIndex(filePathColumn[0]);
            String picturePath = cursor.getString(columnIndex);
            cursor.close();
            Intent intent = new Intent(getBaseContext(), AndroidPaint.class);
            startActivity(intent);
            //  doCrop();
            break;
Javi mi naslednjo napako
  java.lang.RuntimeException: Failure delivering result ResultInfo{who=null, request=3, result=-1, data=Intent { dat=file:///mnt/sdcard/Android/data/com.dropbox.android/files/scratch/app.png typ=image/png }} to activity {com.slikar.slika/slikar.Main.FirstPage}: java.lang.NullPointerException
    at android.app.ActivityThread.deliverResults(ActivityThread.java:3103)
    at android.app.ActivityThread.handleSendResult(ActivityThread.java:3146)
    at android.app.ActivityThread.access$1100(ActivityThread.java:132)
    at android.app.ActivityThread$H.handleMessage(ActivityThread.java:1187)
    at android.os.Handler.dispatchMessage(Handler.java:99)
    at android.os.Looper.loop(Looper.java:137)
    at android.app.ActivityThread.main(ActivityThread.java:4575)
    at java.lang.reflect.Method.invokeNative(Native Method)
    at java.lang.reflect.Method.invoke(Method.java:511)
    at com.android.internal.os.ZygoteInit$MethodAndArgsCaller.run(ZygoteInit.java:789)
    at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:556)
    at dalvik.system.NativeStart.main(Native Method)
    Caused by: java.lang.NullPointerException
    at slikar.Main.FirstPage.onActivityResult(FirstPage.java:396)
    at android.app.Activity.dispatchActivityResult(Activity.java:4649)
    at android.app.ActivityThread.deliverResults(ActivityThread.java:3099)
    ... 11 more
lp,
ppiki12
user4683 ::
katera izmed vrstic zgoraj je vrstica 396? v tej imas namrec nekaj null
piki12 ::
V vrstici Cursor cursor po nase 16 vrstica
getContentResolver() vrne null.
Zakaj, pa bo kdo drugi vedel...
piki12 ::
in zakaj pa to vrne, sedaj me zanima,..
Osebno nimam pojma ker enostavno mi ni jasno, pri navadni galeriji dela odlično, pri dropboxu pa pri pick from file pa ne..Sem pregledal na stacku že vse variante pa mi še ni jasno..
Za vsak primer tja dodaj kontrolo, če je res null, in če je izpiše kaj podatkov, vsaj toliko, da se potrdi, da je res null.
Mavrik ::
Če samo prebereš dokumentacijo klicev, ki jih delaš, boš takoj opazil kakšno ogromno neumnost počneš.
piki12 ::
ja in kakšna neumnost je to ?
Mavrik ::
Razloži mi, kaj točno to dela oz. zakaj si to napisal:
piki12 ::
rabim da path vun dobi ? Sem pa koperal z exampla ..na netu..
  • spremenilo: piki12 ()
piki12 ::
Mah ne morš verjet zdej sem spremenu pa mi ne dela galerija ostalo pa dela:
/external/images/media/333: open failed: ENOENT
Problem pa je da te poti ne najde, pri ostalih dveh ko dobi celo pot pa najde :O..
Spremenjena koda
    @Override
               picturePath= mImageCaptureUri.getPath().toString() ;
          //      doCrop();
                break;
                mImageCaptureUri = data.getData();
                picturePath= mImageCaptureUri.getPath().toString();
          //      doCrop();
                break;
kr?en ::
Kaj pa ce bi ti kaksen breakpoint postavil in zagnal debug mode?
piki12 ::
from dropbox: /mnt/sdcard/Android/data/com.dropbox.android/files/scratch/appSetpint.png
from galerija: /external/images/media/333
from camera:/mnt/sdcard/tmp_avatar_1382875588475.jpg
from pick from file /sdcard/DCIM/Camera/IMG_20131015_103458.jpg
Pobral sem z vseh 4 primerov sedaj ne vem kaj je narobe tole no :( samo galerija ne dela, ker dobim res čudn link ampak ne vem zakaj, ma kdo idejo kaj je narobe ..
Mavrik ::
Ja, dobiš URI ki kaže na Content provider in ne datoteko.
No, vidim da si končno pogruntal da iskanje poti do datoteke v Dropboxu v sistemski galeriji ni pametno ;)
ENOENT dobiš če probaš pisati v datoteko, ki ni tvoja. Če misliš pisati v datoteke, potem jasno ne moreš tega delati direkt v datoteko iz druge aplikacije.
Anyway, kar ti dela probleme je tole:
Uri je samo naslov, ki ni nujno pot do datoteke. Druga aplikacija ti lahko da karkoli, dokler se da naslov razreši v veljavno vsebino na napravi. Zato zunanjo vsebino odpiraš s ContentResolverjem, ki poskrbi, da dobiš z Urija veljaven InputStream.
Torej sliko naložiš z Urija takole:
InputStream imageInputStream = getContentResolver().openInputStream(uri);
Bitmap image = BitmapFactory.decodeStream(imageInputStream);
imageInputStream.close();
Jasno lahko tule uporabiš še več opcij, oz. če rabiš vsebino kot datoteko, jo pač skopiraš v datoteko z InputStreama v svoj cache direktorij.
piki12 ::
Veš kako js nardim :D
tole kar si ti napisal, shranim, preberem vendar to traja :( ..
[Android] Bluetooth aplikacija
Oddelek: Programiranje
51503 (1366) marjan_h
[Android] Splošno
352373 (1503) piki12
android črta
412979 (2250) g333kk
[android] vstavljanje slike
71674 (1571) messi
[android] crash
61830 (1639) messi
