Forum » Operacijski sistemi » Backup in Virtualc
Backup in Virtualc
Nesta ::
I have old PC (1 HDD, 1 Partition) 6 year OLD.
I got new PC in my job and now I need to do a complete backup of old PC and make virtual pc (like Virtualbox or something like it) on my new PC.
Need all files to be accessibly from old PC on new PC.
Can I do this and how?
I can accesses old PC over remote desktop now, but this PC is going by by soon :)
Please help.
Please help.
Nesta ::
Icematxyz ::
Ne morm ponucal ga bodo za nekaj drugega
It talks!
How To Convert Physical Computer Into Virtual Machine (VMware, VirtualBox & Virtual PC)
Če pa gre za dva Windows sistema pa vseeno menim, da preprosto prenesi programe/podatke na nov računalnik in to je to.
krneki0001 ::
Stari računalnik prižgeš, postaviš v mrežo, na novem pa ralaufaš vmware in vklopiš funkcijo import, pa izbereš staro mašino in bo komplet celo mašino z IP-jem in vsem potegnilo noter.
Nesta ::
Dobim tole napako :(
FAILED: Unable to create a VSS snapshot of the source volume(s). Error code:
2147754774 (0x80042316).
primus1024 ::
Zdownloadaj: http://www.vmware.com/products/converte...
Naloži na staro mašino in ti bo skonvertiral fizično mašino v vmware image, ki ga lahko uporabljaš na novi mašini.
Converter in Vmware player sta oba zastonj.
Nesta ::
Isto napako dobim ce na lokalni kisti hocem izvesti zadevico :|
Z tistem acronisom naredi image lokalno?
Nesta ::
Kaj pa je narobe s tem forumom? ne morm popraviti objave? In link sliko mi narobe shrani :|
primus1024 ::
Tam ti očitno nek sysprep manjka.
https://www.google.si/search?q=vmconver...
Ali imaš tam kamor si dal destination dovolj prostora?
- spremenil: primus1024 ()
Nesta ::
To je res joke. Faila na random med 91 in 93% :| nimam pojma kaj vec naresti
[2012-05-16 15:04:19.807 01648 verbose 'TaskListDataProvider'] Updating task: (converter.task.TaskInfo) {
dynamicType = <unset>,
key = "task-15",
task = 'converter.task.Task:task-15',
name = "Convert",
descriptionId = "Convert.P2V",
userName = "Anco",
source = "10.1.1.247",
target = "\\devel01\backup\orhideja\orhideja.vmx",
state = "running",
cancelled = false,
cancelable = true,
data = <unset>,
error = (vmodl.MethodFault) null,
result = <unset>,
progress = 89,
estimatedTimeRemaining = 3942,
transferRate = 19044,
queueTime = "2012-05-16T11:59:16.579018Z",
startTime = "2012-05-16T11:59:17.162048Z",
completeTime = <unset>,
eventChainId = 123,
vcTask = <unset>,
logBundleInfo = (converter.DiagnosticManager.TaskLogBundleInfo) null,
job = 'converter.server.conversion.ConversionJob:job-27',
hasChildren = <unset>,
parentTask = <unset>,
rootTask = <unset>,
[2012-05-16 15:04:58.599 01648 verbose 'ConverterDataProviderImpl'] Converter::Client::Gui::Wizard::ConverterDataProviderImpl::PropertyCollectorThread[1064] - (vmodl.query.PropertyCollector.UpdateSet) {
version = "1064",
filterSet = (vmodl.query.PropertyCollector.FilterUpdate) [
(vmodl.query.PropertyCollector.FilterUpdate) {
filter = 'vmodl.query.PropertyCollector.Filter:session[08B7636B-5D7C-43C3-AF4B-7E9123CD9050]F677BF20-73E7-4A76-BB12-14BB42691705',
objectSet = (vmodl.query.PropertyCollector.ObjectUpdate) [
(vmodl.query.PropertyCollector.ObjectUpdate) {
kind = "modify",
obj = 'converter.task.Task:task-15',
changeSet = (vmodl.query.PropertyCollector.Change) [
(vmodl.query.PropertyCollector.Change) {
name = "info",
op = "assign",
val = (converter.task.TaskInfo) {
key = "task-15",
name = "Convert",
userName = "Anco",
state = "running",
cancelled = false,
cancelable = true,
data = <unset>,
result = <unset>,
progress = 89,
transferRate = 21590,
eventChainId = 123,
vcTask = <unset>,
rootTask = <unset>,
truncated = <unset>,
[2012-05-16 15:04:58.599 01648 verbose 'TaskListDataProvider'] Updating task: (converter.task.TaskInfo) {
key = "task-15",
name = "Convert",
userName = "Anco",
state = "running",
cancelled = false,
cancelable = true,
data = <unset>,
result = <unset>,
progress = 89,
eventChainId = 123,
vcTask = <unset>,
rootTask = <unset>,
[2012-05-16 15:04:58.806 01648 verbose 'ConverterDataProviderImpl'] Converter::Client::Gui::Wizard::ConverterDataProviderImpl::PropertyCollectorThread[1065] - (vmodl.query.PropertyCollector.UpdateSet) {
version = "1065",
kind = "modify",
name = "info",
op = "assign",
key = "task-15",
name = "Convert",
userName = "Anco",
state = "running",
cancelled = false,
cancelable = true,
data = <unset>,
result = <unset>,
progress = 89,
estimatedTimeRemaining = 3944,
eventChainId = 123,
vcTask = <unset>,
rootTask = <unset>,
[2012-05-16 15:04:58.806 01648 verbose 'TaskListDataProvider'] Updating task: (converter.task.TaskInfo) {
key = "task-15",
name = "Convert",
userName = "Anco",
state = "running",
cancelled = false,
cancelable = true,
data = <unset>,
result = <unset>,
progress = 89,
eventChainId = 123,
vcTask = <unset>,
rootTask = <unset>,
[2012-05-16 15:04:58.968 01648 verbose 'ConverterDataProviderImpl'] Converter::Client::Gui::Wizard::ConverterDataProviderImpl::PropertyCollectorThread[1066] - (vmodl.query.PropertyCollector.UpdateSet) {
version = "1066",
kind = "modify",
name = "info",
op = "assign",
key = "task-15",
name = "Convert",
userName = "Anco",
state = "running",
cancelled = false,
cancelable = true,
data = <unset>,
result = <unset>,
progress = 90,
eventChainId = 123,
vcTask = <unset>,
rootTask = <unset>,
[2012-05-16 15:04:58.968 01648 verbose 'TaskListDataProvider'] Updating task: (converter.task.TaskInfo) {
key = "task-15",
name = "Convert",
userName = "Anco",
state = "running",
cancelled = false,
cancelable = true,
data = <unset>,
result = <unset>,
progress = 90,
eventChainId = 123,
vcTask = <unset>,
rootTask = <unset>,
[2012-05-16 15:04:59.155 01648 verbose 'ConverterDataProviderImpl'] Converter::Client::Gui::Wizard::ConverterDataProviderImpl::PropertyCollectorThread[1067] - (vmodl.query.PropertyCollector.UpdateSet) {
version = "1067",
kind = "modify",
name = "info",
op = "assign",
key = "task-15",
name = "Convert",
userName = "Anco",
state = "running",
cancelled = false,
cancelable = true,
data = <unset>,
result = <unset>,
progress = 90,
estimatedTimeRemaining = 3901,
eventChainId = 123,
vcTask = <unset>,
rootTask = <unset>,
[2012-05-16 15:04:59.155 01648 verbose 'TaskListDataProvider'] Updating task: (converter.task.TaskInfo) {
key = "task-15",
name = "Convert",
userName = "Anco",
state = "running",
cancelled = false,
cancelable = true,
data = <unset>,
result = <unset>,
progress = 90,
eventChainId = 123,
vcTask = <unset>,
rootTask = <unset>,
[2012-05-16 15:05:36.440 01648 verbose 'ConverterDataProviderImpl'] Converter::Client::Gui::Wizard::ConverterDataProviderImpl::PropertyCollectorThread[1068] - (vmodl.query.PropertyCollector.UpdateSet) {
version = "1068",
kind = "modify",
name = "event",
op = "assign",
val = (converter.event.Event) [
(converter.event.TaskEvent) {
key = 123,
chainId = 123,
type = "info",
createdTime = "2012-05-16T11:59:16.867034Z",
userName = "Anco",
fullMessage = "Task: Convert physical machine.",
job = <unset>,
info = (converter.task.TaskInfo) {
key = "task-15",
name = "Convert",
userName = "Anco",
state = "queued",
cancelled = false,
cancelable = true,
data = <unset>,
result = <unset>,
progress = <unset>,
estimatedTimeRemaining = <unset>,
transferRate = <unset>,
startTime = <unset>,
eventChainId = 123,
vcTask = <unset>,
rootTask = <unset>,
(converter.event.VolumeCloningStartedEvent) {
key = 124,
chainId = 123,
type = "info",
createdTime = "2012-05-16T11:59:28.508279Z",
userName = "Anco",
fullMessage = "Starting to clone volume 'C:'.",
job = <unset>,
volumePath = "C:",
(converter.event.VolumeBlockLevelCloningBadBlockEvent) {
key = 125,
chainId = 123,
type = "warning",
createdTime = "2012-05-16T12:46:03.79891Z",
userName = "Anco",
fullMessage = "Unable to read the block at offset '-,770,052,096' on volume 'C:'.",
job = <unset>,
volumePath = "C:",
offset = 102309163008,
(converter.event.VolumeCloningCompletedEvent) {
key = 126,
chainId = 123,
type = "info",
createdTime = "2012-05-16T13:05:36.097913Z",
userName = "Anco",
fullMessage = "Completed cloning volume 'C:'.",
job = <unset>,
volumePath = "C:",
name = "info",
op = "assign",
key = "task-15",
name = "Convert",
userName = "Anco",
state = "running",
cancelled = false,
cancelable = true,
data = <unset>,
result = <unset>,
progress = 93,
eventChainId = 123,
vcTask = <unset>,
rootTask = <unset>,
[2012-05-16 15:05:36.440 01648 verbose 'TaskListDataProvider'] Updating task: (converter.task.TaskInfo) {
key = "task-15",
name = "Convert",
userName = "Anco",
state = "running",
cancelled = false,
cancelable = true,
data = <unset>,
result = <unset>,
progress = 93,
eventChainId = 123,
vcTask = <unset>,
rootTask = <unset>,
[2012-05-16 15:05:36.507 01648 verbose 'ConverterDataProviderImpl'] Converter::Client::Gui::Wizard::ConverterDataProviderImpl::PropertyCollectorThread[1069] - (vmodl.query.PropertyCollector.UpdateSet) {
version = "1069",
kind = "modify",
name = "info",
op = "assign",
key = "task-15",
name = "Convert",
userName = "Anco",
state = "running",
cancelled = false,
cancelable = true,
data = <unset>,
result = <unset>,
progress = 93,
estimatedTimeRemaining = 3780,
eventChainId = 123,
vcTask = <unset>,
rootTask = <unset>,
[2012-05-16 15:05:36.508 01648 verbose 'TaskListDataProvider'] Updating task: (converter.task.TaskInfo) {
key = "task-15",
name = "Convert",
userName = "Anco",
state = "running",
cancelled = false,
cancelable = true,
data = <unset>,
result = <unset>,
progress = 93,
eventChainId = 123,
vcTask = <unset>,
rootTask = <unset>,
[2012-05-16 15:05:48.520 01648 verbose 'ConverterDataProviderImpl'] Converter::Client::Gui::Wizard::ConverterDataProviderImpl::PropertyCollectorThread[1070] - (vmodl.query.PropertyCollector.UpdateSet) {
version = "1070",
kind = "modify",
name = "event",
op = "assign",
key = 123,
chainId = 123,
type = "info",
userName = "Anco",
job = <unset>,
key = "task-15",
name = "Convert",
userName = "Anco",
state = "queued",
cancelled = false,
cancelable = true,
data = <unset>,
result = <unset>,
progress = <unset>,
eventChainId = 123,
vcTask = <unset>,
rootTask = <unset>,
key = 124,
chainId = 123,
type = "info",
userName = "Anco",
job = <unset>,
volumePath = "C:",
key = 125,
chainId = 123,
type = "warning",
userName = "Anco",
job = <unset>,
volumePath = "C:",
key = 126,
chainId = 123,
type = "info",
userName = "Anco",
job = <unset>,
volumePath = "C:",
(converter.event.SourceSnapshottingStartedEvent) {
key = 127,
chainId = 123,
type = "info",
createdTime = "2012-05-16T13:05:48.400913Z",
userName = "Anco",
fullMessage = "Creating a snapshot of the source system.",
job = <unset>,
[2012-05-16 15:05:48.667 01648 verbose 'ConverterDataProviderImpl'] Converter::Client::Gui::Wizard::ConverterDataProviderImpl::PropertyCollectorThread[1071] - (vmodl.query.PropertyCollector.UpdateSet) {
version = "1071",
kind = "modify",
name = "info",
op = "assign",
key = "task-15",
name = "Convert",
userName = "Anco",
state = "running",
cancelled = false,
cancelable = true,
data = <unset>,
result = <unset>,
progress = 93,
estimatedTimeRemaining = 0,
eventChainId = 123,
vcTask = <unset>,
rootTask = <unset>,
[2012-05-16 15:05:48.668 01648 verbose 'TaskListDataProvider'] Updating task: (converter.task.TaskInfo) {
key = "task-15",
name = "Convert",
userName = "Anco",
state = "running",
cancelled = false,
cancelable = true,
data = <unset>,
result = <unset>,
progress = 93,
eventChainId = 123,
vcTask = <unset>,
rootTask = <unset>,
[2012-05-16 15:05:49.675 01648 verbose 'ConverterDataProviderImpl'] Converter::Client::Gui::Wizard::ConverterDataProviderImpl::PropertyCollectorThread[1072] - (vmodl.query.PropertyCollector.UpdateSet) {
version = "1072",
kind = "modify",
name = "info",
op = "assign",
key = "task-15",
name = "Convert",
userName = "Anco",
state = "error",
cancelled = false,
cancelable = true,
data = <unset>,
error = (converter.fault.VSSSnapshotFault) {
faultCause = (vmodl.MethodFault) null,
errCode = "2147754774 (0x80042316)",
msg = "Unable to create a VSS snapshot of the source volume(s). Error code: 2147754774 (0x80042316).",
result = <unset>,
progress = 93,
transferRate = 20867,
completeTime = "2012-05-16T13:05:49.534767Z",
eventChainId = 123,
vcTask = <unset>,
rootTask = <unset>,
[2012-05-16 15:05:49.675 01648 verbose 'TaskListDataProvider'] Updating task: (converter.task.TaskInfo) {
key = "task-15",
name = "Convert",
userName = "Anco",
state = "error",
cancelled = false,
cancelable = true,
data = <unset>,
result = <unset>,
progress = 93,
eventChainId = 123,
vcTask = <unset>,
rootTask = <unset>,
[2012-05-16 15:19:48.112 07064 info 'ConverterSession'] Converter data provider created.
[2012-05-16 15:19:48.113 07064 info 'DiagnosticDataProvider'] Converter::Client::Gui::Common::DiagnosticDataProvider::DownloadTaskDiagnosticFile - Using converter.task.Task:task-15
[2012-05-16 15:19:49.139 07064 info 'DiagnosticDataProvider'] Converter::Client::Gui::Common::DiagnosticDataProvider::DownloadTaskDiagnosticFile - Received bundle info (converter.DiagnosticManager.TaskLogBundleInfo) {
key = "task-15-diag-20120516130549-qpdwmh.zip",
timeCreated = "2012-05-16T13:05:49.550367Z",
format = "zip",
content = (converter.DiagnosticManager.BundleContent) [
"workerLogs",
"serverLogs"
size = 409298,
crc = -730211390,
Nesta ::
Help anyone? :(
result = <unset>,
progress = 93, Nesta ::
Hvala.
To zgleda imam vse OK.
Mogoce mislis da rabim kaksne admin pravice?
Naceloma naj bi imel vse .
XP racunalnik je tisti katerega hocem spravt na virtualca, Windows 7 je pa tisti na katerem laufam vmware konverter.
Včasih kakih mašin preprosto ne moreš pretvorit z VmWare converterjem.
Se je tudi že meni zgodilo. Ni šlo in pika. Pa sem vse mašine spravil na VmWare server razen ene. Za katero sem potem porabil več časa kot za vse skupaj. Pa še vedno ni šlo ...
| » | Problem z ramom ali diskom? Prosim za nasvet.Oddelek: Strojna oprema | 1592 (1494) | Duhec |
| » | HP Pavilion dv7 reboot problemOddelek: Pomoč in nasveti | 2666 (2599) | Yacked2 |
| » | Undo za ComboFixOddelek: Pomoč in nasveti | 2436 (2201) | MrStein |
| » | [WPF] Vrednost Textbox kot "angle" v AxisAngleRotation3DOddelek: Programiranje | 1198 (1133) | saule |
| » | API+VBOddelek: Programiranje | 2573 (2277) | webblod |
