usb bootable image windows
T-Mac ::
pozdravljeni
mogoce kdo ve zakaj ce zelis imeti bootable windowse na usb da mora biti usb kljuc velik od 1 gb do 2 gb max... ce pa zelis vecjega so pa neke dolge kolobocije da zrihtas...
technolog ::
windows na 2giga. To je zgolj neslana šala. :)
T-Mac ::
usb do 2 gb max...
1.Plug in your USB Drive (Minimum USB Drive capacity 2 GB)
2.Format the USB drive to FAT32
3.Download Unetbootin from UNetbootin - Homepage and Downloads
4.Start Unetbootin and select diskimage (use the backtrack-final ISO)
5.Select your USB drive and click "OK" for creating a bootable BackTrack USB drive
to sprasujem
technolog ::
To ni postopek, da bootaš v windows, ampak samo v inštalacijski CD. Je treba tud mal možgane uporabljat.
Drugač pa ni nobene take omejitve.
VelikiTun ::
T-Mac je izjavil:
usb do 2 gb max...
Kot je povedal predhodnik, se postopek nanaša na pripravo USB ključka za namestitev sistema z njega.
Poleg vsega si v citiranem delu oglej odebeljeni del. Govori o minimalni velikosti.
T-Mac ::
bi mogoce kdo vedel kaj moram narediti ko bootam install win xp iz usb mi napise hal.dll missing...
malo sem brskal in odkril tole samo ne razumem, bi mi znal kdo pomagati
hvala v naprej
When you turn on the Eee, hold down "Esc" to choose the boot device and select the USB stick/ SD card. You'll need to do this at each reboot until XP is fully installed and you've logged in.
Choose Text installation at first time and GUI INSTALLATION AFTER REBOOT TWICE! - ( Choose step 1 to start installing, after reboot choose step two, after continued install press step 2 AGAIN to log into XP - As soon as you arrive at the Windows XP Desktop you can safely remove the USBStick / SD card
tukaj je celotni potek:
prilagam samo zaradi tega besedila da bi bilo mogoce lahko bolj logicno:
Method 2 Full XP Install
You will need a special tool to copy the Installationfiles and making the USB-stick/SD card bootable - usb_multiboot_10.zip
Unpack to any folder. THE PATH TO YOUR FOLDER MUST BE SIMPLE AND WITHOUT SPACES! (ex. c:\usb_multiboot_10)
Insert USBstick / SD card.
ALL DATA ON YOUR STICK WILL BE ERASED! Please back up before running USB_MultiBoot_10.cmd!
Run USB_MultiBoot_10.cmd. follow text description.
Format utility will apear. Choose NTFS for >=4Gb usb flash and FAT16 for other, Start format, Close after finishing to allow the DOS operations to continue.
diamondsw: Using the "HP format" option works fine for any capacity, and you can use FAT32 without problems (I used a 4GB stick). This can be useful as more systems can read FAT32 than NTFS.
NOTE: If you are doing this from a Vista machine, you may need to run PeToUSB.exe as adminstrator in order for this program to recognize the jump drive. (Right click PeToUSB.exe > Properties > Compatibility > "Run this program as an administrator" checked.)
Set options 1 and 2. Set option 0 only if you want to use USB HDD instead of a USB stick/ SD card.
Do not touch other options if you have no idea about it.
Choose 3 after setting all other options. It will create the image and write it to the USB stick as well as making the USBstick / SD card bootable.
Answer Yes to all questions that come up (these vary depending on options selected).
When it finishes copying, remove your usb stick and insert it in the EeePC to install XP.
Choose Text installation at first time and GUI INSTALLATION AFTER REBOOT TWICE! - ( Choose step 1 to start installing, after reboot choose step two, after continued install press step 2 AGAIN to log into XP - As soon as you arrive at the Windows XP Desktop you can safely remove the USBStick / SD card.
If you get hal.dll not found errors, read carefully the last two last bullets!
If you get 'ntldr is missing' or other boot errors after you have ran text installation make sure you have deleted ALL partitions during 'text installation' this includes the BIOS partition.
  • spremenil: T-Mac ()
T-Mac ::
mislim da moram zaradi napake hal.dll missing spremeniti boot.ini sledeco vsebino:
[Boot Loader]
Timeout=10
Default=multi(0)disk(0)rdisk(2)partition(1)\WINDOWS
[Operating Systems]
C:\btsec\XPSTP.bs="1. Begin TXT Mode Setup Windows XP, Never unplug USB-Drive Until Logon"
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="2. and 3. Continue with GUI Mode Setup Windows XP + Start XP from HD 1" /FASTDETECT
multi(0)disk(0)rdisk(2)partition(1)\WINDOWS="Continue GUI Setup + Start XP from HD 2, use if installing on HD2" /FASTDETECT
c:\grldr="4. Start GRUB4DOS Menu - DOS FPY IMAGES + Linux + XP Rec Cons + Vista"
C:\btsec\XATSP.bs="Attended Setup XP, Never unplug USB-Drive Until After Logon"
mislim da imam prav in ce bi bil kdo prijazen ce ima kake izkusnje s tem bi bil zelo vesel hvala
T-Mac ::
kakor razumem nekaj v zvezi s particijami in diski nimam pravilno nastavljeno
T-Mac ::
je mogoce problem v tem da sem image delal na drugem racunalniku ki ima drugacno razporeditev diskov...
Asus WL500gP, dd-wrt, printer and disk sharing
Oddelek: Omrežja in internet
97328 (3732) coyotee
Inštaliranje Windows7 iz usb
144431 (3988) king67
Izpad elektrike & Disk Boot Failure (strani: 1 2 )
506364 (5776) Damjan Jagar
USB ključ error => disk is not formatted
194772 (4329) muzičar
OS na USBju
Oddelek: Operacijski sistemi
152673 (2344) Spajky
