Forum » Pomoč in nasveti » 3d shader model
3d shader model
miha121 ::
Pozdravljeni,
mi je uspelo uštimat prejšen problem z računalnikom, zdaj pa me zanima, če moram nujno zamenjati grafično, ali je kaj drugega. Rad bi igral igro landwirtschafts simulator 2011.
Grafična je pa:intel dtc-aat06 intel core duo delta. Grafična pa nvidia sli.
Pa hvala za odgovore. Se pa tudi zahvaljujem, ker ste mi v prejšnjem postu pomagali.
- polepsal: Mavrik ()
69charger ::
Prenesi si programček CPUID CPU-Z pa nam povej točno ime procesorja in grafične kartice.
miha121 ::
Pentium(R) Dual-Core CPU E5300 @ 2.60GHz
DMI BIOS
vendor American Megatrends Inc.
version 080014
date 04/10/2009
DMI System Information
manufacturer BIOSTAR Group
product G31-M7 TE
version unknown
serial None
UUID {03000200-0400-0500-0006-000700080009}
DMI Baseboard
vendor BIOSTAR Group
model G31-M7 TE
revision unknown
serial None
DMI System Enclosure
chassis type Desktop
chassis serial None
DMI Processor
manufacturer Intel
model Pentium(R) Dual-Core CPU E5300 @ 2.60GHz
clock speed 2600.0 MHz
FSB speed 200.0 MHz
multiplier 13.0x
DMI Memory Controller
correction 64-bit ECC
Max module size 4096 MBytes
DMI Memory Module
designation DIMM0
size 2048 MBytes (double bank)
DMI Memory Module
designation DIMM1
DMI Memory Module
designation DIMM2
DMI Memory Module
designation DIMM3
DMI Physical Memory Array
location Motherboard
usage System Memory
correction None
max capacity 4096 MBytes
max# of devices 4
DMI Memory Device
designation DIMM0
format DIMM
type SDRAM
total width 64 bits
data width 64 bits
size 2048 MBytes
DMI Memory Device
designation DIMM1
format DIMM
type unknown
DMI Memory Device
designation DIMM2
format DIMM
type unknown
DMI Memory Device
designation DIMM3
format DIMM
type unknown
Graphics
Number of adapters 1
Graphic APIs
API Intel I/O
Display Adapters
Display adapter 0
Display name \\.\DISPLAY1
Name Intel(R) G33/G31 Express Chipset Family
Memory size 256 MB
PCI device bus 0 (0x0), device 2 (0x2), function 0 (0x0)
Vendor ID 0x8086 (0x1565)
Model ID 0x29C2 (0x3103)
Performance Level 0
Software
Windows Version Microsoft Windows XP Professional Service Pack 3 (Build 2600)
DirectX Version 10.0
DMI BIOS
version 080014
date 04/10/2009
product G31-M7 TE
version unknown
serial None
DMI Baseboard
model G31-M7 TE
revision unknown
serial None
chassis serial None
DMI Processor
manufacturer Intel
FSB speed 200.0 MHz
multiplier 13.0x
DMI Memory Module
designation DIMM0
DMI Memory Module
designation DIMM1
DMI Memory Module
designation DIMM2
DMI Memory Module
designation DIMM3
usage System Memory
correction None
max# of devices 4
DMI Memory Device
designation DIMM0
format DIMM
type SDRAM
total width 64 bits
data width 64 bits
size 2048 MBytes
DMI Memory Device
designation DIMM1
format DIMM
type unknown
DMI Memory Device
designation DIMM2
format DIMM
type unknown
DMI Memory Device
designation DIMM3
format DIMM
type unknown
Graphics
Graphic APIs
API Intel I/O
Display Adapters
Display adapter 0
Memory size 256 MB
Performance Level 0
Software
Isotropic ::
tle ti pise, da mas graficno onboard maticne - intel g33.
prestavi konektorje na nv graficno.
http://slo-tech.com/forum/t490013/zacet...
lol, tak racunalnik si kupil? kuk si pa dal zanj?
- spremenil: Isotropic ()
miha121 ::
Ne,to je družinski rač.za šolo,itd.Tistega pa nisem kupil.Cene ne vem,predvidevam da je slab računalnik?
Kam moram prestavit konektorje?
Kako pa vem za BIOSE.
Hvala za odgovore.
Hvala za odgovore.
Isotropic ::
poglej zadaj, k so tiste reze vodoravne, ce mas kaksne izhode za prikljucek za monitor. poj pa sam odvij ta prikljucek z maticne plosce pa ga privij tam. na servisu ti dobesedno nimajo kaj delat, ker to moras itak zunaj kiste doma naredit.
miha121 ::
In potem bi moralo delati,mislim landwirtschafts simulator 2011,2009?
Če lahko samo še to obrazložiš,kam ga privijem?Če sem razumel,najprej odprem kišto,tisti priključek na katerem je kabel za ekran odvijem,in ga priključim na grafično?
Pa hvala za odg.
Pa hvala za odg.
- spremenilo: miha121 ()
miha121 ::
Senitel ::
Nič ne rabiš odpirat kište. Zadaj imaš trenutno kabel za monitor na matično pritrjen, sedaj ga pa prestavi nižje dol na grafično.
miha121 ::
Ampak nižje je le neka mrežica,tam kjer bi moralo to biti.Se jo pa da odstranit.
Ampak ni ničesar.Tudi ko sem že odprl računalnik je bila grafična drugje priklopjena,ni v bližini ohišja.
Janac ::
Slikaj zadnji del racunalnika
Kako ni v blizini ohisja?
- spremenil: Janac ()
miha121 ::
Ja oprosti če ne vem.kaj se spravlate na neizkušnga človeka.
Kje pa je grafična kartica?
miha121 ::
Senitel ::
G31-M7 TE ima PCI-Ex ja. Pač nabavi grafično, vtakni v kišto, preklopi kabl za monitor na grafično in inštaliraj driverje. Če ti pride na pamet kaj žagat, potem si na napačni poti.
miha121 ::
Samo še tole bi rad uprašal.Če bo tale grafična pasala na moj računalnik,glede teh vodil,itd? http://www.mlacom.si/zotac-zt-50604-10l...
miha121 ::
Kje jo čem pa dobit?
Pa saj ta ima shader model 5.0,jaz pa 3.0 rabim.Bo kar vredi.
Isotropic ::
| » | navijanje E7500Oddelek: Navijanje | 3292 (2175) | grobar |
| » | ugašanje in restartanje računalnikaOddelek: Pomoč in nasveti | 6718 (6371) | Cold1 |
| » | Ali je tale računalnik dober ali bi za takšen denar dobil kaj boljšega?Oddelek: Kaj kupiti | 1967 (1780) | IVo |
| » | Kateri ram kupiti?Oddelek: Kaj kupiti | 1095 (1095) | tom13 |
| » | Procesor ko žerjavica?Oddelek: Hlajenje in modifikacije | 2082 (1848) | T0RN4D0 |
