Forum » Operacijski sistemi » PreFetch - ne deluje?
Windows 7 Pro 64 bitov.
Task Manager kaže 2500 MB free.
Zakaj ko poženem Firefox melje tudi 5 sekund po disku?
A ni smisel Superfetch, da pogosto uporabljane programe vnaprej naloži? (FF pogosto uporabljam, razen njega uporabljam tam 5-10 programov pogosto, vse skupaj niti za 1 GB, torej komot bi se vse lahko naložilo)
RAM-a je vse skupaj 5 GB.
Isotropic ::
nekje v win mapi so te datoteke od prefetch, si lahko pogledas
se mi pa opera nalozi prej kot v 5s
Huh? Na predzgodovinskem PC se mi je FF naložil v sekundi in pol.
Eh, napredek..
Eh, napredek..
Jst ::
Tam ko je na naslednji sliki rdeča puščica ti kaže 2500GB Free?
Skoraj da ne verjamem.
Jst ::
To je pa res nekaj narobe. Si pogledal "services.msc" če ti laufa SuperFetch in dependencies?
SuperFecth laufa.
Ima dve odvisnosti:
- Remote Procedure Call (RPC) - deluje
- File Information FS MiniFilter - tega ni za videti pod servisi. Kje ga najdem?
Ima dve odvisnosti:
Buggy ::
Ce imas OS instaliran na SSD je lahko to razlog.
By default, Windows 7 will disable Superfetch, ReadyBoost, as well as boot and application launch prefetching on SSDs with good random read, random write and flush performance. These technologies were all designed to improve performance on traditional HDDs, where random read performance could easily be a major bottleneck. See the FAQ section for more details.
FAQ: Will Superfetch be disabled on SSDs?
Yes, for most systems with SSDs.
If the system disk is an SSD, and the SSD performs adequately on random reads and doesn't have glaring performance issues with random writes or flushes, then Superfetch, boot prefetching, application launch prefetching, ReadyBoost and ReadDrive will all be disabled.
Initially, we had configured all of these features to be off on all SSDs, but we encountered sizable performance regressions on some systems. In root causing those regressions, we found that some first generation SSDs had severe enough random write and flush problems that ultimately lead to disk reads being blocked for long periods of time. With Superfetch and other prefetching re-enabled, performance on key scenarios was markedly improved.
Mavrik ::
Mogoče pa preprosto ne delaš nič takega, kar bi bilo vredno prefetchati. Firefox je v končni fazi le 36MB... ti pa maš 600MB keširanega. Firefox pa tudi dela precej betarij okoli sqlite baz v katerih shranjuje svoje podatke (in ki se lahko hudo upočasnijo... a imaš nov firefox in si probal pognat VACUUUM na bazah?), ki precej zmanjšuje učinkovitost takih mehanizmov.
- spremenil: Mavrik ()
Poganjam programe. Kaj še naj počnem, da bo vredno prefetch-at ???
FF ni tak star, niti tako pogosto ne uporabljam (bolj pogosto Chrome), da bi se mu kaj nabralo. Bom probal "posesati"...
Eh, SSD pa bi itak moglo leteti, a ne?
Navadna vrteča se plošča je.
- spremenil: MrStein ()
Icematxyz ::
Morda pa je zadeva vseeno bolj preprosta, kot je opisana v hrošču višje? Določeni mehanizmi delujejo za določena opravila bolje/slabše in določeni mehanizmi so vsaj v primeru FF zagona proti produktivni?
Kakorkoli, Q2 2012 je nekje časovno okno za odpravo tega hrošča in potem se lahko preveri ta teorija tudi v praksi s preprostim klikom na zaganjalnik omenjenega programa!
Zanimivo branje o Super/Pre-Fetch (v bugu).
S tem, da je tema nasploh, ne samo o FF.
Res hecno, da SuperFecth upočasni zagon programa, ne pa obratno.
Icematxyz ::
Verjetno je zelo odvisno tudi od primera do primera. Ker si ravno omenjal FireFox in sem po naključju naletel na ta info sem prilepil to še sem.
srus ::
Bi rekel, da se Microsoft ne bo kaj posebej potrudil, da bi se FF čimhitreje štartal, prej nasprotno ;-)
Prefetch gor ali dol pet sekund je preveč. Stori sledeče:
- onemogoči vse plugine, ekstenzije in addone v FF
- namesto Task Managerja si z Microsoftovih strani naloži Proccess Explorer - tako boš dobil veliko jasnejšo sliko kaj se dogaja ob zagonu FF, kdo, kdaj dela kaj, kdo čaka na koga itd.
Mavrik ::
Pozor: Bug, ki ga je postal Icematxyz velja samo za Windows XP, ki ima drug prefetch mehanizem kot je SuperFetch na Vista/7. Tako da tisto najverjetneje ni relevantno.
RejZoR ::
Pri Firefoxu se cacha še cel kup drugega, vključno s plugini, torej še PDF reader, Adoeb Flash itd itd...
Icematxyz ::
| » | ramdisk + readyboostOddelek: Programska oprema | 1358 (1212) | boogie_xlr |
| » | SSD diskOddelek: Strojna oprema | 2217 (1740) | RejZoR |
| » | Readyboost v Win 7Oddelek: Strojna oprema | 1670 (1541) | g. Oden |
| » | Vista in nenadno žretje RAMaOddelek: Operacijski sistemi | 2910 (1855) | napsy |
| » | Novosti v Vista jedruOddelek: Novice / Operacijski sistemi | 7723 (5716) | Matako |
