[PHP] ZendStudio problem
GoodSatanist ::
Imam problem z ZendStudio. Noče se zagnati, če se v terminalu prijavim kot root. Javi neko obskurno napako v JVM in fukne ven. Kot root se pa želim prijaviti zato, ker je mapa /var/www read-only.
GoodSatanist ::
Ko dam na primer new->local php project, mi kot root direktorij predlaga /var/www, kar je OK, samo ZendStudio ne more pisati vanjo, ker so pravice pač 744. Če se pa v terminalu prijavim kot root in kot root zaženem ZendStudio, pa javi neko jebeno napako v JVM in takoj fukne ven, čim se naloži.
Googlal že ko fukjen za rešitev, pa nikjer tega ne omenja.
Anyone???;((
GoodSatanist ::
Tole javi:
A fatal error has been detected by the Java Runtime Environment:
# SIGSEGV (0xb) at pc=0xb5ab8d0f, pid=2450, tid=3025636208
# JRE version: 6.0_23-b23
# Java VM: OpenJDK Client VM (20.0-b11 mixed mode, sharing linux-x86 )
# Derivative: IcedTea6 1.11pre
# Distribution: Ubuntu 11.10, package 6b23~pre11-0ubuntu1.11.10.1
# Problematic frame:
# J org.eclipse.core.internal.dtree.DataTreeNode.asReverseComparisonNode(Lorg/eclipse/core/internal/dtree/IComparator;)Lorg/eclipse/core/internal/dtree/AbstractDataTreeNode;
# An error report file with more information is saved as:
# /tmp/hs_err_pid2450.log
# If you would like to submit a bug report, please include
# instructions how to reproduce the bug and visit:
# https://bugs.launchpad.net/ubuntu/+sour...
Aborted
Tudi če spremenim pravice mape /var/www na 777 s chmod, pa potem zaženem ZendStudio kot navaden user in dam new->local php project, fukne ven.
GoodSatanist ::
Rešil problem s
chown uporabnik /var/www
in reinštalacijo ZendStudia.
Dnsmasq problem
Oddelek: Omrežja in internet
131501 (1128) BlaY0
Domači strežnik (strani: 1 2 )
8018695 (16788) Zalachenko
Ne zazna R.class -android
Oddelek: Programiranje
171752 (1590) Marat
Linux, pobrisane particije in recovery
Oddelek: Operacijski sistemi
73313 (2887) 5er-->
Ubuntu 7.04 + Pinnacle PCTV = slika super, zvoka ni - Linux n00b here (strani: 1 2 )
707915 (5356) poweroff
