AC-AC napajalnik
AC-AC napajalnik
igor0203 ::
Ima kdo kako idejo, kje bi dobil 15V AC 1A napajalnik? Klical že vse možne trgovine in nikjer jih nimajo, opcija je DE, ampak bi dal za PTT več kot je vreden napajalnik. Pri nas sem našel samo AC-DC, potrebujem pa AC-AC.
boogie_xlr ::
20W transformator iz 220V na 15V, pa imaš še za malo več kot 1 amper.
igor0203 ::
Rabil bi prav nekaj takega, ker bi ga ponucal za en ojačevalec za slušalke in mi je bolj priročen napajalnik v taki obliki kot pa trafo+ohišje.
Fave ::
Potem je pa lahko tudi DC. Daj shemo od ojačevalnika.
My mind's a hyper tool that fixes everything.
  • spremenil: Fave ()
igor0203 ::
O2 headphone amplifier
Obvezno mora biti AC napajanje.
  • spremenil: igor0203 ()
jest10 ::
igor0203 je izjavil:
Ja seveda... Zato pa deluje tudi na baterije;((
Noben problem ni, če ga priklopiš na enosmerno. Zadeva ima itak usmernik.
Fave ::
jest10 je izjavil:
To so AC baterije. Bo novica jutri na ST :D
Ni ravno tako enostavno. Tule je link do sheme: https://docs.google.com/viewer?a=v&pid=...
igor0203 ::
WHAT'S AN O2? The Objective2 (O2) is my attempt at a "One-Size-Fits-Nearly-All" headphone amp. It can drive most any headphone from the most sensitive IEMs to some really power hungry full size cans from 16 to 600 ohms. It's small, inexpensive, and runs on batteries or AC power.
For AC line power or charging, connect the AC wall transformer to this jack. The standard plug is 5.5mm outside and 2.1mm inside. The transformer output can be anywhere from 14 VAC to 20 VAC and at least 200 mA. Don't use more than 20 VAC or less than 14 VAC (except for the 12 VAC transformers listed in the parts list). Do not try to use a DC adapter. A DC adapter may appear to work if batteries are installed, but the amp will be at least partly running off the batteries.
ToniT ::
Vsi modemi za ADSL (stari Callisto od IskraTela) imajo točno tak adapter. Če poznaš koga na Telekomu, ti ga zrihta zastonj. Imam jih tudi jaz, če te zanima....
igor0203 ::
Nažalost ne poznam. Če imaš slučajno 2 viška, bi lepo prosil...
ToniT ::
Lahko dobiš!
Na ZS prosim!
st0jko ::
Jaz pa iščem 240VAC -> 24VAC (~300mA) vtični napajalnik... Kdo ve kje bi lahko to dobil v SLO?
keks?
DAC pretvornik ali zvočna kartica?
294706 (3098) puda
Transformator 220V na 12V (enosmerni,10A)
1914881 (7052) krneki0001
Slušalke na Samsung smart TV
51115 (1027) Konlov
Priklop navadnih slušalk na optični audio izhod?
Oddelek: Zvok in slika
296260 (5861) Janac
