Forum » Elektrotehnika in elektronika » AC-AC napajalnik
AC-AC napajalnik
igor0203 ::
igor0203 ::
Rabil bi prav nekaj takega, ker bi ga ponucal za en ojačevalec za slušalke in mi je bolj priročen napajalnik v taki obliki kot pa trafo+ohišje.
Fave ::
Potem je pa lahko tudi DC. Daj shemo od ojačevalnika.
My mind's a hyper tool that fixes everything.
- spremenil: Fave ()
jest10 ::
O2 headphone amplifier
Obvezno mora biti AC napajanje.
Ja seveda... Zato pa deluje tudi na baterije
Noben problem ni, če ga priklopiš na enosmerno. Zadeva ima itak usmernik.
Fave ::
To so AC baterije. Bo novica jutri na ST
Ni ravno tako enostavno. Tule je link do sheme: https://docs.google.com/viewer?a=v&pid=...
igor0203 ::
WHAT'S AN O2? The Objective2 (O2) is my attempt at a "One-Size-Fits-Nearly-All" headphone amp. It can drive most any headphone from the most sensitive IEMs to some really power hungry full size cans from 16 to 600 ohms. It's small, inexpensive, and runs on batteries or AC power.
For AC line power or charging, connect the AC wall transformer to this jack. The standard plug is 5.5mm outside and 2.1mm inside. The transformer output can be anywhere from 14 VAC to 20 VAC and at least 200 mA. Don't use more than 20 VAC or less than 14 VAC (except for the 12 VAC transformers listed in the parts list). Do not try to use a DC adapter. A DC adapter may appear to work if batteries are installed, but the amp will be at least partly running off the batteries.
- spremenil: igor0203 ()
ToniT ::
Vsi modemi za ADSL (stari Callisto od IskraTela) imajo točno tak adapter. Če poznaš koga na Telekomu, ti ga zrihta zastonj. Imam jih tudi jaz, če te zanima....
st0jko ::
Jaz pa iščem 240VAC -> 24VAC (~300mA) vtični napajalnik... Kdo ve kje bi lahko to dobil v SLO?
keks?
| » | DAC pretvornik ali zvočna kartica?Oddelek: Kaj kupiti | 4705 (3097) | puda |
| » | Transformator 220V na 12V (enosmerni,10A)Oddelek: Elektrotehnika in elektronika | 14880 (7051) | krneki0001 |
| » | Slušalke na Samsung smart TVOddelek: Pomoč in nasveti | 1114 (1026) | Konlov |
| » | Priklop navadnih slušalk na optični audio izhod?Oddelek: Zvok in slika | 6259 (5860) | Janac |
