Edined vzorec + statement-i [PHP]
JesusChrist ::
Zdravo!
Trenutno v svoji aplikaciji uporabljam vzorec edinec + klasični query-ji. Sedaj bi rad uvedel prepared statemente, ampak se mi zdi malo zapleteno vse skupaj in ne vem kako naj le-te uvedem.
Koda edina:
abstract class Database_Object
    protected static $DB_Name;
    protected static $DB_Open;
    protected static $DB_Conn;
    protected function __construct($database, $hostname, $hostport, $username, $password)
        self::$DB_Name = $database;
        self::$DB_Conn = mysql_connect($hostname . ":" . $hostport, $username, $password);
        if (!self::$DB_Conn) { die('Critical Stop Error: Database Error<br />' . mysql_error()); }
        mysql_select_db(self::$DB_Name, self::$DB_Conn);
    private function __clone() {}
    public function __destruct()
        //mysql_close(self::$DB_Conn);  <-- commented out due to current shared-link close 'feature'.  If left in, causes a warning that this is not a valid link resource.
final class DB extends Database_Object
    public static function Open($database = "db", $hostname = "localhost", $hostport = "3306", $username = "root", $password = "test")
        if (!self::$DB_Open)
            self::$DB_Open = new self($database, $hostname, $hostport, $username, $password);
        else
            self::$DB_Open = null;
        return self::$DB_Open;
    public function qry($sql, $return_format = 0)
        $query = mysql_query($sql, self::$DB_Conn) OR die(mysql_error());
        switch ($return_format)
            case 1:
                $query = mysql_fetch_row($query);
                return $query;
                break;
            case 2:
                $query = mysql_fetch_array($query);
                return $query;
                break;
            case 3:
                $query = $query[0];
                return $query;
            default:
                return $query;
Uporaba:
$DB = DB::Open();
$DB->qry("SQL");
Kako sedaj uvesti v zgornji razred statemente?
remember, the clock is ticking. run like no tomorrow.
keworkian ::
Naorbe prebral
Obscenities in B-Flat
krho ::
WTF je edinec? singelton? Ljudje božji a bi nehali to prevajat prosim. ;((
Prepared stavki preko navadnega vmesnika ne gredo. boš lepo popravit kodo in uporabiti PDO.
[MySQL]Stored procecdure za kreacijo baze
Oddelek: Programiranje
6979 (868) Spura
php skripta za registracijo uporabnikov
Oddelek: Izdelava spletišč
162605 (2186) skorpio
OleDb in visual studio .net
162680 (2459) Kovalchuk
[Java] Shranjevanje podatkov in datotek
71593 (1546) Vesoljc
[C++] for {}
292063 (1757) Gundolf
