Forum » Pomoč in nasveti » Iphone
Iphone
zoolander ::
Pozdravljeni,
moj prijatelj-tuji študent v Slo ima naslednje težave s svojim Iphonom, zato posredujem njegov email v ang:
On my Iphone are e-mails saved, which came from another e-mail server and i need them.
As soon as i would connect the Iphone to the Internet, i would try to connect to the old server and would do a update – which means my e-mails would be gone – becasue the postbos is empty ( it was cleared when i left there)
I need this e-mails on normal outlook in order to use and read them again.
Still i can read them – on the Iphone – so i rather have them to read as to loose them.
Za pomoč se vnaprej zahvaljujeva,
HVALA!
HVALA!
KoMar- ::
Verjetno lahko v nastavitvah izklopi samodejno sinhronizacijo ali pa spremeni naslov strežnika, da se ne bo moglo povedat in vse pobrisat.
Milan3 ::
Pozdravljeni,
na Iphone 4 sem naložil nov iOS 7 in sedaj dela zelo počasi, včeraj pa se je izklopl WiFi in sedaj ne morem vklopiti gumba, kod da je mrtva funkcija. Ima kdo kak nasvet?
hvala
hvala
blackbfm ::
za normalno delovanje ios7 moraš priklopit na komp in dat restore > set up as new phone..seveda bodo šli vsi podatki..aja telefon bo še vedno štekal :)
- spremenilo: blackbfm ()
| » | Prodajam Renault Megane l 2003 in dobim zanimivo ponudboOddelek: Loža | 8572 (7102) | Go-ahead |
| » | E-mail teroristi na FinskemOddelek: Loža | 1405 (1273) | G-man |
| » | Ponudniki dostopa do interneta lahko berejo pošto svojih uporabnikovOddelek: Novice / Zasebnost | 3633 (3633) | [-=Jaka=-] |
| » | Slovenska e-vlada na SlashdotuOddelek: Novice / Omrežja / internet | 3605 (3605) | Ikarus |
