Hofer ponudba
Hofer ponudba
Stara mama, ime "grški jogurt" je zaščiteno, prav tako recept8ura, ostali pa delaj nekaj približno temu in se ne rabijo držati "grške" recepture, zato tudi odstopanja.
Strained yogurt @ Wikipedia
Primer za UK:
Greek yogurt is protected under UK law as a geographical indication, meaning it can only legally be labeled as "Greek yogurt" if produced in Greece using traditional straining methods. This protection stems from a 2013 English High Court ruling in Fage UK Ltd & Another v Chobani UK Ltd & Another, where Mr Justice Briggs ruled that the term "Greek yogurt" carries goodwill and is associated in the public mind with products made in Greece.
Še dodatek:
Labeling Changes: In response to legal and regulatory shifts, many brands outside Greece--such as in Australia and Ireland--now label their products as "Greek-style yogurt" to avoid misleading consumers. This reflects the legal requirement that the term "Greek yogurt" implies origin from Greece, not just a production method.
  • spremenilo: fikus_ ()
stara mama ::
Ja itak, o čem pa govorim? :)
No, tisti iz hoferja je dejansko iz grčije!
Ekologija™ in Trajnost™
Ali ima Hoferjev 10g proteinov na 100g?
kixs ::
Kolikor sem sam gledal, nima noben grski jogurt 10g beljakovin. Imajo okoli 6g.
Ce hoces mlecne beljakovine, potem vzami skuto, ki ima okoli 13g. Ali pa obogaten jogurt z beljakovinami. Ampak to lahko tudi sam naredis, ce vrzes notri se merico beljakovin v prahu.
stara mama ::
Magic1 je izjavil:
varianta z 2%mm ima 8g/100
Grški tip jogurta imajo 4-5g/100g. Mleko ima 3.3g. Grški pa imajo kar okoli 8-10g. Ne bi imelo smisla le 6g.
kixs ::
Js sem gledal z 10% mascobe.
cortez ::
V poslovalnicah Hofer ni več mogoče kupiti tobačnih izdelkov. Pri Hoferju so te navedbe potrdili ter navedli, da so bili tobačni izdelki v trgovinah Hofer na voljo le do razprodaje zalog, predvidoma do konca jeseni 2025.
vir : https://www.zurnal24.si/slovenija/sok-z...
kixs je izjavil:
Posneta skuta, skyr, grški jogurt z manj maščob, lahka mocarela. Vse to so fina in zdrava živila.
EU_zamašek- ::
cortez je izjavil:
To bi moralo biti povsod. Vedno gnečo delajo, pa potem prodajalke brskajo na x koncev da se prebijejo do točno določene škatlice.
Te škatle bi trebalo prepovedat. Namenske trafike, tisti, ki hoče kaditi, naj si zvija.
To da Hofer umika prodajo tobačnih izdelkov me prav nič ne moti, ker tak ne kadim.
stara mama ::
Če tako meniš, je treba to zapisat v zakon!
Sicer pa kaj bo pol petrol prodaju za vikend zvečer, če ne cigaret?
Sej skoz jokajo, da od primarne dejavnosti ne morjo živet!
ZveeZ ::
stara mama je izjavil:
Dokler mi ni potrebno placevati goriva na blagajni, si lahko kadilci dajo duska z nabavo cigaret:))
mtosev je izjavil:
Pa tudi če bi kadil, te to ne more motiti. Greš pač po čike drugam.
BuDi79 ::
mtosev je izjavil:
- Če umakne kokakolo, povejo ljudje, da jih res ne moti ker tega ne pijejo.
- Če umakne čokolino, povejo ljudje, da jih res ne moti ker tega ne jejo.
- Če umakne barcafe, povejo ljudje, da jih res ne moti ker pitje kave škodi, pa "daj dva evra več pa kupi illy".
- Če umakne zelenjavo, povejo ljudje, da jih res ne moti ker imajo vrt oz. visoko gredo.
- Če umakne mleko, povejo ljudje, da jih res ne moti ker ga kupujejo (pravega!!) pri kmetu, ki ga osebno poznajo.
- Če umakne kruh, povejo ljudje, da jih res ne moti ker kruh pečejo doma.
lepo je enim.
In to tudi povejo.
Kot vegani.
Čeprav mene v bistvu bk. kaj kdorkoli od vas osebno je/pije/goji/ima navade/bolezensko stanje.
  • spremenilo: BuDi79 ()
FUCK OFF ::
estons je izjavil:
Danes zjutraj lokalni Lidl nabito poln, opravili nakup fasunge, spotoma zavili še v lokalni Hofer po eno specifično zadevo... Mesto duhov, 2 kupca in 2 prodajalki v celi trgovini. Super jim gre ta nova strategija.
Hmmmm, Hofer it is then. Hvala za info.
  • spremenilo: FUCK OFF ()
BuDi79 je izjavil:
mtosev je izjavil:
lepo je enim.
In to tudi povejo.
Kot vegani.
Pa ta cela tema je samo o tem kaj kdo kupuje v Hoferju. Če te bk, kaj potem delaš v njej.
Je pa zanimivo, da se nisi obregnil prvo v tiste, ki se pritožujejo, da česa ni. Ker oni so začeli.
BuDi79 je izjavil:
mtosev je izjavil:
Hofer je diskontna trgovina in kar se mene tiče lahko ima blagovne znamke, a le če so te tudi dejansko cenejše kot sicer v ostalih trgovinah. Drugače me (v Hoferju) ne zanimajo.
Cene imajo take, kot jih je folk pripravljen plačat. Lahko celo višje kot v klasičnih trgovinah.
Problem blagovnih znamk je, da ponavadi sploh niso cenejše. Sploh če drugje ponujajo 50 of za dva kosa ali več in podobno.
In potem se ljudje začnejo spraševati, če je tukaj res kaj ceneje.
Če pa ponujajo svoje kemične smeti in 100x premrznjeno meso po kvazi ugodnih cenah, folk ne more primerjave narediti. In se mu dejansko zdi ugodno.
Cigarete nimajo kaj iskat v trgovinah z zivili.
Bravo hofer.
feryz je izjavil:
Ampak ti si res triggered s tem Hoferjem. Po moje nam je že vsem jasno, move along.
kuglvinkl ::
IL_DIAVOLO je izjavil:
Bravo hofer.
Se strinjam, to nej spizdi v trafike, cajtng itak nihce vec ne kupuje.
Korzo23 ::
točno to, čike v trafike 8-)
solatjek ::
Danes pridem v Hofer, sicer smo kar redno kupovali v Hoferju. Večino robe, ki jo običajno vzamemo, so umaknili, prestavili so vse, kar se je prestaviti dalo. Odšli s skoraj praznim vozičkom, tu nimamo več česa kupit.
Ah daj no, saj sodeluješ v tej temi. Menda ti je bilo jasno kaj so umaknili preden si šel pogledat.
Pa to traja že 2 meseca, zgleda niste tako redno kupovali.
solatjek je izjavil:
Trgovec vedno laže. Če nekaj trdi, potem je to treba vzeti z rezervo. Kot v tem primeru.
https://www.facebook.com/HOFERSLO/posts...
Trdijo tudi, da so najboljši, najcenejši, najkakovostnejši itd. Kot kupec imaš samo eno nalogo, to je da ne padaš na te fore.
AI-SLOP ::
starfotr je izjavil:
[Trgovec vedno laže. Če nekaj trdi, potem je to treba vzeti z rezervo. Kot v tem primeru.
Res, nisem zasledil ničesar od tega... Daj tole 'najboljši, najceneši, najkakovostnejši, vsi-ostali-nam-zavidajo' malo podokumentiraj.
Meni je malo žal za Hofer, je na idealni sprehajalni razdalji, zdaj pa nekaj brezveze komplicirajo z izgubami, država nič ne krije, si nič ne izposodi in založi kot za zavode in plače, FFS? :D Se res zdi, da je nekaj spremembe in da je več popuščenih cen kot je bilo - verjetno res te njihove znamke, ja.
Je pa manj gužve po drugi strani. Po navadi je izdelkov iz posebne ponudbe zmanjkalo že do 9h.
Kaj pa naj komentiram? Poglej si objave na spletu, v reklamah, v trgovini. Pa boš videl, da so vedno naj naj. Boljše od konkurence in vseh ostalih. To velja na splošno za vse trgovce, ne konkretno za aldi.
delavec44 je izjavil:
V naslovu teme je napisano Hofer ponudba, ne Klub ljubiteljev Hofer trgovine.
AI-SLOP ::
Dokumentiraj, ne bom si iskal objav na spletu, v reklamah, v trgovini. Ne spomnim se izraza, da so naj naj in da bi to sami rekli. Ne rečem, mogoče si samo zamešal z nekom drugim, ki je omenjal, da nam vsi zavidajo, da smo najboljši, da nam zavidajo vse države in si premostil na Hofer... Saj mogoče imaš prav, ja, če nam vsi zavidajo, ker smo po mnenju vladajočih politikov najboljši in nam vsi zavidajo, da si naredil preskok tudi v Hofer. No, jaz nisem, žal, nisem najboljši, niti naredil tovrstnega miselnega preskoka :D
feryz je izjavil:
Ja, ampak ne moreš vedeti kaj ponuja, če praviš da ne kupuješ tam. Razen, ko te tamala pregovori. Zgleda za otroke je kul, kako si že napisal, same kemikalije in 100x zmrznjeno meso.
Ko boš pa lahko kaj objektivno napisal brez pretiravanja, pa seveda dobrodošlo.
Günther ::
Sedaj pa je Hofer zares odpovedal sodelovanje s slovenskimi kmeti.
Hofer umika izdelke slovenskih kmetov
Sindikat kmetov pravi eno, Hofer pravi drugo. Smo že obdelali v tej temi, v prispevku ni nič novega.
Kmetje so pezdeti. Vsa jajca imajo v eni košari in sedaj nekaj jokcajo?
Dodaten žebelj v njihovo krsto je izjava, da naj znižajo trošarine na gorivo. Kaj bi še radi? Že tako legalno kurijo kurilca.
Tako, da en sam jok jok jok. Tudi, če bi jim po nekem naključju namesto dreka v štali letele zlate palice iz njihovih goved bi se pritoževali.
AI-SLOP ::
Kaj hočeš, niso tako sposobni kot 105% forumašev. Saj se jim bo zaplenilo, če bo prišlo do kakšne zaostritve, ne bi bilo prvič. Še menda precej glasnih forumašev jih direktno sovraži ob podpori nekaterih moderatorjev, tako da, starfotr, nisi prvi.
Ne glede na to, da se ukvarjajo s hrano ki je zelo pomembna zadeva, to ne spremeni dejstva da so omejeni in da se obnašajo kot 3 letni otroci.
AI-SLOP ::
Kaj pa dejansko pričakuješ od nazadnjaškega kmeta, ki je v trn v peti vladajoči kasti? Da bo na nivoju ekstremno sposobnih in produktivnih slo-tech forumašev?
Toliko se menda znajdejo, da dobijo državne (!) subvencije za 150kEUR vreden traktor, menda petega v vrsti - kot delovno sredstvo, da se malo vozijo, ker na 2HA menda tega še obrniti ne moreš brez manevriranja.
No, če slučajno nimajo posesti v bližini mesta, ki jo drago prodajo, ko jim politiki (!) omogočijo zazidljivost, glede na sosednjo temo bi si morali takšnih samo želeti - nekako jih pa ni, FFS! :D
  • spremenilo: AI-SLOP ()
Pričakoval bi, da so združeni in da sodelujejo.
Zadruge so si uničili zaradi neumnih potez kmetov samih. Sodelujejo pa itak ne, ker drugače ne bi vsak kmet imel cele hale trakotorjev in priključkov za vsako opravilo.
Zato je edino pravilno, da se jih postavi pred dejstvo: vzemi ali pusti.
Tu je Hofer verjetno imel tudi cenovni pritisk.
AI-SLOP ::
Kaj pričakuješ ti (ali jaz, ftm), navadno nima zveze z realnostjo in raznimi Mercosurji.
Spet pišeš nekaj na pamet!
Tako kot celo SLO se je tudi zadruge "lastninilo". Večina je propadlo, sedanje pa imajo "Zadruga" samo v imenu, dejansko so pa trgovine s kmetijskim, gradbenim, vrtičkarskim...., materialom.
Danes bil v Hoferju in vzel 6 pločevink coca cole. Na srečo imajo še vedno colo.
ZveeZ ::
So police ze kj bolje zalozene? Ze dolgo nisem bil tam.
Police so bile polne.
alešhojs ::
V ponedeljek spet šel po fasungo v Hofer, kot že zadnjih nekaj let. Ni čokolina, ni radenske, ni delamarisa, ni argete, ni milke, ni jebenih aiwaves čigumijev, ki jih ima že vsaka druga kebabdžinica. Jebite se. Prej sem lepo dobil vse na enem mestu, zdaj pa pač ne mislim hodit zarad tega v tri različne trgovine. Bo pač Hofer ob eno stranko.
Rio Mare konzerve so v mojem Hoferju imeli.
alešhojs je izjavil:
In to nisi vedel že pred 3 tedni?
https://slo-tech.com/forum/t494699/p871...
energetik ::
estons je izjavil:
Kva je fora tega pomanjkanja v Hoferju zadnje tedne? Zadnjič sem pobral zadnje kose 3,5% mleka, 1/4 polic je povsem praznih. Od rib dobiš morda samo še pakiranega lososa, drugo je samo zmrznjeno. In še je takih zadev.
Še Špin postaja bolje založen kot Hofer.
vires in numeris
kixs ::
Kolikor gledam nas Hofer. So ga spet nafilal. Izdelke od brandov pa imajo samo se stare zaloge. Ko bo slo, verjetno ne bo vec.
212 / 221
