Prepakiranje 3gp v avi/mkv
boogie_xlr ::
Eno quick vprašanje (in verjetno quick odgovor). Rad bi prepakiral iz 3gp v avi oziroma mkv container. Ali je to možno brez recodanja in če kdo priporoča kakšen free programček za to.
popster ::
pomojem bo treba naredit encoding-decoding, durgače pa lakho probaš z vlcjim, ima convert funkcijo.
Mavrik ::
Nobenega kodiranja ne bo potrebno narest. Remuxat moraš samo stvar.
Če imaš ffmpeg, potem sam napišeš "ffmpeg -i VID_karkoli.3gp -vcodec copy -acodec copy VID_karkoli.mkv
Ne pa basat tega v avi.
boogie_xlr ::
Mavrik je izjavil:
Sem sprobal, dobil sem pol mega manjši file, ki je pa nažalost non-playable. Ima 3gp kakšne posebnosti, ki ne spadajo v mkv?
Source:
General
Complete name                    : D:\slike\VID_20111028_175144.3gp
Format                           : MPEG-4
Format profile                   : Base Media
Codec ID                         : isom
File size                        : 5.02 MiB
Duration                         : 12s 544ms
Overall bit rate                 : 3 356 Kbps
Video
Format                           : AVC
Format/Info                      : Advanced Video Codec
Format profile                   : Baseline@L3.1
Format settings, CABAC           : No
Format settings, ReFrames        : 1 frame
Format settings, GOP             : M=1, N=31
Codec ID                         : avc1
Codec ID/Info                    : Advanced Video Coding
Duration                         : 12s 427ms
Bit rate                         : 3 029 Kbps
Width                            : 720 pixels
Height                           : 480 pixels
Display aspect ratio             : 3:2
Frame rate mode                  : Variable
Frame rate                       : 30.000 fps
Minimum frame rate               : 17.854 fps
Maximum frame rate               : 102.273 fps
Standard                         : NTSC
Color space                      : YUV
Chroma subsampling               : 4:2:0
Bit depth                        : 8 bits
Scan type                        : Progressive
Bits/(Pixel*Frame)               : 0.292
Stream size                      : 4.49 MiB (89%)
Title                            : VideoHandle
Language                         : English
Audio
Format                           : AAC
Format/Info                      : Advanced Audio Codec
Format profile                   : LC
Codec ID                         : 40
Bit rate mode                    : Constant
Bit rate                         : 96.0 Kbps
Channel(s)                       : 1 channel
Channel positions                : Front: C
Sampling rate                    : 16.0 KHz
Compression mode                 : Lossy
Stream size                      : 147 KiB (3%)
Title                            : SoundHandle
Language                         : English
Result:
General
Unique ID                        : 85048024880080323625453509249662891892 (0x3FFBA75E4E79FAEB9A0B894BDF86B774)
Complete name                    : D:\slike\VID_20111028_175144.mkv
Format                           : Matroska
Format version                   : Version 2
File size                        : 4.64 MiB
Overall bit rate                 : 3 101 Kbps
Writing application              : Lavf53.18.0
Writing library                  : Lavf53.18.0
Video
Format                           : AVC
Codec ID                         : V_MPEG4/ISO/AVC
Width                            : 720 pixels
Height                           : 480 pixels
Frame rate                       : 90 000.900 fps
Standard                         : NTSC
Color space                      : YUV
Bit depth                        : 8 bits
Language                         : English
HANDLER_NAME                     : VideoHandle
Audio
Format                           : AAC
Format profile                   : LC
Codec ID                         : A_AAC
Delay relative to video          : -76ms
Language                         : English
HANDLER_NAME                     : SoundHandle
YouTube nativni video format
152389 (2018) Ijus
Občasno štekanje pri predvajanju preko HDMI
Oddelek: Zvok in slika
474227 (3183) sejmon
HD ali FULL HD KAMERA
286399 (5423) JOKER
Kupil bi Satelitsko. (strani: 1 2 )
5018978 (17438) mumbo
wmv - video in zvok nista usklajena
61509 (1454) #000000
