Janković gre na volitve, nastaja nova stranka
imagodei ::
Gregor P je izjavil:
Ustrezen pokop umrlih (pri nas zločinsko namerno pobitih in zmetanih v zamolčana brezna) je neko temeljno kulturno dejanje sodobne civilizacije; brez tega, vsaj tako vodilni svetovni filozofi, preprosto ne gre.
In kdo to odkritim žrtvam povojnih pobojev odreka? Takoj pred sodnika z njim!
- Hoc est qui sumus -
Lepo videti, da si nekateri le želijo pravne države in sodobne kulturne družbe.:)
  • spremenil: Gregor P ()
USS Liberty ::
Sej to je realno glupo. Folk za hrano nima, mi pa "ko krti" prekopavamo Slovenijo. Samo zato, da nabiramo municijo za politične opolskeže. Fuj, nekrofili.
sej ni treba nč prekopavat. En Mujo, ki gradi cesto, zapiči lopato v zemljo, ali pa en kmet malo zaorje njivo, pa kosti ven skočijo. Cela Slovenija je ena evropska Kampučija posejana s kostmi... kot iz tistega fima "Polja smrti"...
http://en.wikipedia.org/wiki/USS_Liberty_%28AGTR-5%29
Tko to je, če maš strateško lego.
gendale ::
glavni problem povojnih pobojev je da je enim uspelo pobegnit v argentino in sedaj delajo sranje z odkopavanjem 70 let starih kosti
http://pastebin.com/QiWny5dV
Double_J ::
Piše se leto 2027...:P
The sons of ousted Slovenian leader Zoran Janković were killed by U.S. troops in the northern city of Slovenj Gradec after a tipster betrayed their hideout, the commander of U.S. ground forces in Slovenia said Tuesday.
The bodies of Jure and Damjan Janković were identified from "multiple sources," Army Lt. Gen. Ricardo Sanchez told reporters in Ljubljana. "The bodies are in a condition where you could identify them.
"They resisted the detention and the efforts of the coalition forces to go in there and apprehend them, and they were killed in the ensuing gunfight and the attacks that we conducted on the residence."
Dve šivanki...
djordjevic ::
Disturbed minds ...
... se strinjam zelo neokusno; predstavljal si, da si njihov oče, ko tole bereš:(
random ::
Zakaj bi se kdorkoli odlocu za opcijo katere podporniki pisejo taksne idiotizme kot so v postu Double_J-a?
WarpedGone ::
Samorefleksija ne sploh?
Zbogom in hvala za vse ribe
djordjevic ::
Sori, samo tako daleč se pa še niti največji antijanševiki niso spustili, da bi spisali zgodbico, kako neke posebne enote daljnega leta 2030 prerešetajo mladega Črtomira, ker je njegov oče že 20 let največji tiran na tem kosu Evrope. Mislim, peezda, no. ;((
WarpedGone ::
Seveda ne, primerjava cele familije z Goeblesevo je čisto nekaj drugega. Kja pa grimsovi mladoletni otroci vejo kaj je to blo.
Označevanje s princem teme, fašistom/fašisti seveda tudi. To je konstruktivno in objektivno poročanje.
Tabletka je zelo grenka, ko jo moraš enkrat sam pogoltnit, to pa ja.
Fašizem ni nek nedefiniram pojem. Če je Janez Janša tako nepreviden, da zmore izjavljati fašistične opazke na tiskovnih konferencah, si je za to oznako kriv predvsem sam.
WarpedGone ::
Sej, ko faše janša, je kriv janša. Ko faše janković, je kriv janša.
Za bruhat ste.
Double_J ::
To je sarkazem, morda pa se Saddam Husein res ne bi odločil za despotski način vladanja, če bi to že prej prebral. Ker tole je v resnici njegov primer...;)
Dve šivanki...
Buggy ::
bolano..in cisto po principu JJ-jevcev ja
leiito ::
negot je izjavil:
Virant je zet Mihe Brejca, po logiki nekaterih je ZJ trojanski konj samega JJ,lp:))
Džizija so domačini opazili kako se v lahnem drncu vzpenja proti vrhu Trojan. V kratkem pogovoru z domačini je pojasnil, da je sicer v fazi razmisleka, a si je veeeno vzel čas za nekaj besed o programu 3x500* in domać krof (po poročanju Sveta na Kanalu A ga je dal nekaj tudi na zob, pa ne krofa), potem pa se je v elegantnem kasu spustil nazaj v dolino.
Uzdaj se use, ti si svoje trojansko kljuse press.
*a.k.a. 500 je socialna, 2x €500 mininalna penzija, 3 x €500 min plača, če bo zmanjkalo bo dal pa iz svojega žepa, ker davki bodo za vsaj pol manjši.
Brane2 ::
leiito je izjavil:
Super.
Ko je delal za LJ, je naj* NLB itd. Me prav zanima, kdo bo naj* ko se bo zagnal za SLO... >:D
Double_J ::
Komentar je zato, ker je Janković rekel da gre na volitve zato, da se nobeden ne bo spravljal na njegove sinove.
Pod Saddamom se tudi nobeden ni spravljal. Samo da Saddamova sinova nista nič rekla, ubij tega kot Jankovićeva. Sabo sta nosila pištoli in sta kar tako za čisto zabavo koga ustrelila sredi kakšne zabave. Končalo pa se je tako, da so se nakoncu američani morali spraviti nanju, ker se nobeden drug ni mogel.
Dve šivanki...
Ramon dekers ::
no njuna sinova lažje primerjaš z Gadafijevima. Sicer pa dobra zgodba, človek se ne bi čudil če bi jih kje u Romuniji, Bolgariji zasačili pri kakšnem "poslovanju" in bi šla oba ali eden od botrovih sinov na hladno. Sicer pa bil bi že skrajni čas.
Brane2 ::
Sploh pa sedaj, ko ju naravnost vabijo novi zapori: KLIK!
>:D
  • spremenil: Brane2 ()
Double_J ::
Čakaj ti malo, oče je zaenkrat samo župan. Če bo predsednik vlade, bo ego narastel...
Dve šivanki...
LordTado ::
On bo mandatar zato da jima nardi svoj zapor blizu doma:)
Se razume z plačilom za prestajanje kazni.
Sploh pa ni slaba ideja,naj sprejmejo zakon da bo vsak lahko zaporno kazen prestajal doma,pol pa komot sprejmejo piratski zakon,ker bo tako dovolj prostora.:)
  • spremenil: LordTado ()
leiito ::
Možno je pa seveda tudi, da ima prav David Icke, in da so itak vsi v Bidermajer Grupi in je vse to levo, desno, Janko, Metka, samo šou za maso, da imamo občutek demokracije, v bistvu se pa na tajnih srečanjih grupe zmenijo vse.
Kakorkoli obrneš se skupine odločajo namesto nas, zato ker mi pač nimamo časa za to, zato tudi imamo stranke, liste itd.
msjr ::
leiito je izjavil:
Ja seveda! Saj se tako ali tako vsi parlamentarci poznajo iz Kumrovca in podobnih šol. Divide et impera. Dvojni j-ji in razne letalonosilke pa nasedajo, če lahko izpostavim največje gorečneže.
Ramon dekers ::
sam predlagam ZJ. naj najema Ceasar Milana, menim da mu bo le ta pomagal pri vzgoji njunih sinov, za kaj več ni upanja.
tsh2 ::
je bilo pa zanimivo videti kako radikalno je direktor pediatrične klinike Kenda obtoževal sds in navijal za jankovića. to kaže na to, da so v sloveniji direktorji raznih državnih družb močno politično kadrovani. pa tudi tisti direktor mercatorja ki naj bi ga nastavil janša je prišel podpreti jankovića. to se nekako se ne ujema s teorijo, da ga je janša nastavil, potem ko je odstavil jankovića, ne?
  • spremenilo: tsh2 ()
noraguta ::
mah kokr kol, Janezu je v času konjunkture ratal met clo neki presežka v državnem proračunu , Zoki je pa bil tud takrat minusu.
noraguta> Zoki je pa bil tud takrat minusu.
Big surprise there, ja. Če ti en Janša izmakne 50 milijonov evrov, pa si potem v minusu za dobro polovico tega, se mi to zdi kar uspeh.
noraguta ::
jype je izjavil:
kje mu jih je že izmaknil? to je tud en urban mit.
noraguta> kje mu jih je že izmaknil? to je tud en urban mit.
Preberi spremembe ZFO, ki jih je sprejela Janševa vlada, pa izračunaj sam.
jype, in kot dober gopodarsvenik, manager itd, je delal kot da se ni nič spremenilo. Aja sej res morda pa je zaradi tega tak minus salbih 800€ na vsakega Ljubljnčana zapolsenega in to ne v gopodarstvu. Še sreča da imamo grešnega kzla, Janšo za vse utopije.
noraguta ::
ja ker je Lj izgubila priviligiran položaj, naj bi jo ukradli ... še vedno pa pobira znaten del državnega proračuna prek institucij katere gostuje.
noraguta> ja ker je Lj izgubila priviligiran položaj, naj bi jo ukradli
Ja, tako je.
Mr.B> in kot dober gopodarsvenik, manager itd, je delal kot da se ni nič spremenilo.
Ne, zrihtal je financiranje drugače in pokril večino minusa. Kaj si pa ti naredil?
Buggy ::
kako zvizgajo zdej panicni in histericni deskoti in obmetavajo s tako prezvecenimi in trivialnimi skoraj otroskimi ocitki...
ste pred casom kej spremlajli limonado, kjer imate vasega lepotca in alfa samca JJ na zatozni klopi?
....tega svetnika pravicnosti in nehinavscine ter oceta kulturnega dialoga in konstruktivizma.
Meni je za poscat, ko poslusam tele domobrancke od NSi-ja zadnje case...pa se Grimsek in Cernjac sploh ne razocarata...res je malce panike na desni kajneda se cuti ja ...da o zaigrani uzaljenosti JJ-ja sploh nebi:D
res ste bogi...po eni strani si zelite zmage, ker ste tako zatirani po drugi se je pa istocasno bojite kot hudic krize , ker vas bo to v teh casih pokopalo.
  • spremenil: Buggy ()
Ramon dekers ::
Buggy sedaj smo država z mafijo, če pride zj na oblast bomo mafija z državo. Verjetno je bolje da pride princ teme na oblast kot Kučanov vajenec.
Sicer pa stalno spremljamo limonade, od tiste kako ima dva sinčka ki lahko delata kar hoče do tega kako boter dela super duper posle za Ljubljano. Janša pa je kriv za vse. Še dobro da je Zj tako iznajdliv da je vse projekte speljal kljub temu da mu je JJ izmaknil denar.
GEEE jaz mislim da je vse te projekte plačal kar iz svojega žepa oz za začetek izvedbe tako kot Tomaž Drolec. :))on bi bil bolj primeren za kakšnega vodja unicef programa, se mi zdi da je za LJ. kar predober, ko bo pa na državnem nivoju, bo pa vse prodal samo da nas bo lahko rešil.
Keyser Soze ::
Tele tvoje enovrstičnice, s temi smajliji, so nekje na nivoju osnovnošolskega otroka, ki se je dodobra naučil izrazat čustva. A znaš morda še kaj več povedat al je to vse kar lahko pričakujemo od tebe?
Ne me žlajfat s temi moralnimi nauki tule. Ker ste najbolj nemoralni ravno tisti, ki kopljete tele kosti vsepovprek. Eni Štrousi zmešani vsi po spisku.
Če bi bili moji sorodniki tam notri pokopani (so jih samo postrelili in jih pustili gnit na prostem - "talevi" in "tadesni" - odvisno po kateri strani žlahte gledaš) bi želel, da se tam naredi obeležje oz. zadevo zapečati - recimo Barbara rov. Nisem ene sorte fanatičen revanšist, katerih nam ne primankuje na tem forumu, da bi na vsak način želel obračunat z nasprotno opcijo s kostmi svoje žlahte. Pa ležijo po Sloveniji tako eni kot drugi. Kot sem rekel, fuj nekrofili, se naslajajo nad najdenimi trupli in se kitijo z njimi, kot z nekimi trofejami. Jako vam je važen dostojen pogreb ja, tole vam verjame samo še kakšna boga boječa upokojenka. Vsak kolčkej racionalno razmišljujoč posameznik te bo vprašal po zdravju če ga boš prosil za par 100 tisočakov, da prekoplješ grobišča zato, da boš štel kosti oz. ugotavljal "usmerjenost" pokopanih, medtem ko bi lahko tale sredstva porabil precej bolj racionalno. Sploh sedaj ko vsi jambrajo, kakšna kriza je.
OM, F, G!
djordjevic ::
Nimam kaj dodati.
noraguta je izjavil:
Mhm, fiktiven plus, ki ga je parlament 'potrdil' po izsiljevanju ob ratifikaciji pristopa Hrvatov k Natu. ;((
Morda če bi si vsaj ogledal moje komentarje tu na forumu, niti jih ne rabiš prebrati, bi uvidel, da ne pišem zgolj samo enovrstičnic, ponavljati pa se ves čas tudi ne mislim:|
Če ti ne razumeš, zakaj je potrebno primerno poskrbeti za trupla žrtev zločinskih pobojev, katerih kosti pridejo praktično ob "vsakem prekopavanju" na dan (gradnje avtoceste, infrastrukture ipd.), torej jih niti ne rabiš posebej iskati, potem ti pač ni pomoči.
Keyser Soze ::
Hvala za še en medel odgovor z velikim poudarkom na moralnem žlajfanju. A ste res tolk zlajnani, da druzga kot folku metat pod nos, da oni tega ne razumejo, ne znate?
Well, help me understand tvojo neizmerno filozofijo oz. veliki moralni nauk. Do takrat pa, glede na to kakšna je praksa v tej državi, kar se tiče izkopov tehle množičnih ali malo manj množičnih grobišč, lahko samo in zgolj molčiš o kakršnikoli moralni odgovornosti nas živečih do mrtvih. So veliko na boljšem, če počivajo tam kjer so, kot če na njih spustimo razne Dežmane, Štrovse, Ference in podobne jastrebe, ki so začutili "zlato jamo" v vseh teh slovenskih "jamah".
OM, F, G!
WarpedGone ::
Tolk o tem kako niso važna imea ampak dejanja.
TOlk prozorni ste, da je nevarnost da se kdo zaleti v vas ...
jype
, kaj je panika, sej res tistih 800€ na ljubljanča si pozabil.
Keyser Soze ::
WarpedGone je izjavil:
Če mačku stopiš na rep zamjavka? V tem primeru mjavka bolj kot ne WarpedOne, ker se mu zdi da hodim po "desničarskih repih". Na žalost so trenutno najbolj medijsko popularni ravno tile šmorni. Z veseljem pa lahko butneš zraven kakšnega "levičarja" če boš za to mirno spal.
Bi njemu isto povedal, če bi imel možnost.
OM, F, G!
jrtjtejtt ::
seveda je potrebno primerno poskrbeti za grobišča. Tako, da se postavi obeležje napiše lepo gor za kaj se je šlo in rože menja vsak teden. Kaj več ni potrebnega niti primernega. To, da se stalno vrti po TV in politično izkorišča, pač ni skrb za mrtve.
Ti pa si pozabil, kakšne prihodke ima Ljubljana.
O.
random ::
Mr.B
Slovenci smo tako ze v dolgu 7500€ vsak (oz 10000€+ ce drzi 22miljard dolga). Ampak za 800€ vec ki sem jih dolzen kot ljubljancan, vsaj vem zakaj so se porabili. Za tistih 10k pa nazalost ne morem nic pokazat in recti, vidis to so nam zrihtali, lahko smo veseli.
Ramon dekers ::
Keyser Soze je izjavil:
saj ni problem Barbara Rov, problem je ker so zločinci na prostosti, in še nagrajeni za svoje delo. Namesto da bi Ribičića peljali na sodišče in po možnosti zaplinili smo ga nagradili, skupaj z Kučanom. To so cvetke ki jih nekateri ne dojamete.
Okapi je izjavil:
O.
kakšne? Vam je zato samovoljno povečal kazni? Komaj čakam da se vam še bolj povečajo prispevki, da bodo prihodki še večji. lol
Ramon dekers> Vam je zato samovoljno povečal kazni?
Ne, vam jih je - meni ne.
Ramon dekers> Komaj čakam da se vam še bolj povečajo prispevki, da bodo prihodki še večji. lol
Pa komaj čakaš, da še kaj zgradimo, lol.
Keyser Soze ::
Ramon dekers je izjavil:
Ja pa je problem Barbara rov, ipd. Ker se zlorablja za osebna obračunavanja. Bolj kot tile stari hropeži, ki živijo še poslednje svoje vzdihljaje, preden odidejo tja, kjer so njihove domnevne žrtve.
Takšni postopki proti tem t.i. vojnim sločincem so nesmisel. Totalni. Ker se zgolj in samo "rekla kazala" podprti. Ti boš vpil da so levi zločinci in da so obtožbe desnih politični konstrukt, nasprotni bodo pa vice versa vpili. In kam bomo prišli? Nikamor. Tako kot se danes sprehajajo med nami nagrajeni "levičarski zločinci", takisto je z "desničarskimi zločinci". Ni treba, da je človek medijsko odmeven, da je upravičen do obsojanja. Marsikdo ždi varno doma, za štirimi zidovi, pa ima mogoče isto ali še več masla na glavi.
Boš ti tisti, ki bo šel do njega, ga zvlekel iz bajte in pred sodišče?
Še postopki, ki so stari manj kot 10, 20 let so prakitčno nerešljivi, balkanski zločinci za še bolj evidentne zločine sedijo v čuzi gor v Haagu zavoljo dolgotrajnih postopkov. Redkokomu pa lahko nedoumno dokažejo svinjarije. Čeprav vsi "vemo" damo so bili krivi oni.
OM, F, G!
14 / 36
Volitve 2011 (strani: 1 2 3 4 … 29 30 31 32 )
Oddelek: Problemi človeštva
1588222393 (194415) Ziga Dolhar
