Forum » Programiranje » [c#] Cudna napaka pri vpisu vrstice (row) v bazo
KernelPanic ::
Spostovani!
Spet bi rabil pomoc, in sicer pri sledeci kodi:
1) Ce tabelo izpraznim na serverju, se izvede stavek
2) Ce tabela ze vsebuje record, se izvede stavek
void saveParametersToDatabase()
System.Console.WriteLine("Entering saveParametersToDatabase()"); // test code
DataRow drStatusTargetRow;
float fNumber = 0;
bool bOk = false;
int iNumberOfRows = this.m_datasetPinus.ACCULOAD_STATUS.Count;
UInt32 iValue = 0;
if (iNumberOfRows > 0)
// table is not empty, access 0-th record, alter it and save it back to db table
drStatusTargetRow = this.m_datasetPinus.ACCULOAD_STATUS.Rows[0];
else
// table is empty, add a record
drStatusTargetRow = this.m_datasetPinus.ACCULOAD_STATUS.NewRow();
} // if
// **** TRANSFER VALUES TO RECORD
drStatusTargetRow[AccuLoadIIIMonitor.TableStatus.FieldNames.
FIELD_SLAVE_ADDRESS] = this.m_aiAcculoadIIISlaveAddresses[0];
bOk = this.m_CoreFunctions[0].readFlowRateAverage(ref fNumber);
if (!bOk)
fNumber = 0;
FIELD_FLOW_RATE_AVERAGE] = fNumber;
bOk = this.m_CoreFunctions[0].readTemperature(ref fNumber);
if (!bOk)
fNumber = 0;
FIELD_TEMPERATURE] = fNumber;
bOk = this.m_CoreFunctions[0].readPresetVolume(ref iValue);
if (!bOk)
fNumber = 0;
FIELD_PRESET] = iValue;
FIELD_ARM_PARKED] = this.m_ssDigitalIO5.m_bState;
FIELD_GROUNDING] = this.m_ssDigitalIO7.m_bState;
FIELD_OVERFILL] = this.m_ssDigitalIO1.m_bState;
FIELD_CONDITIONS_PLC] = this.m_ssDigitalIO9.m_bState;
FIELD_ESD] = this.m_ssDigitalIO4.m_bState;
FIELD_ALARM_PRESENT] = this.m_bwParams.m_bAlarmCondition;
FIELD_PRODUCT_FLOWING] = this.m_ssProductFlowing.m_bState;
FIELD_TIMESTAMP] = DateTime.Now; // saves timestamp
// **** END OF TRANSFER VALUES TO RECORD
// table is not empty, save changed in SAME row
int iRowsAffected = this.m_taStatus.Update(this.m_datasetPinus);
else
// table empty, save now row
this.m_datasetPinus.ACCULOAD_STATUS.Rows.Add(drStatusTargetRow);
this.m_datasetPinus.ACCULOAD_STATUS.AcceptChanges();
System.Console.WriteLine("Exiting saveParametersToDatabase()"); // test code
} // saveParametersToDatabase()Namrec, naloga je, da tabela vsebuje le en record (prebrani podatki iz naprave), zato funkcija preveri, ce je tabela prazna, vstavi nov record, ce ni prazna, spremeni 0-ti record in ga nazaj shrani v tabelo. Vendar se zgodi sledece:1) Ce tabelo izpraznim na serverju, se izvede stavek
this.m_datasetPinus.ACCULOAD_STATUS.Rows.Add(drStatusTargetRow);in nato AcceptChanges(), kar je ok, vendar zapisa ni v tabeli.2) Ce tabela ze vsebuje record, se izvede stavek
int iRowsAffected = this.m_taStatus.Update(this.m_datasetPinus);in nato spet AcceptChanges(), vendar tu v konzoli pride do sledece napake:A first chance exception of type 'System.Data.SqlClient.SqlException' occurred in System.Data.dllMi lahko kdo pomaga prosim???
Step into: Stepping over method without symbols 'System.ComponentModel.BackgroundWorker.WorkerThreadStart'
Step into: Stepping over method without symbols 'System.Runtime.Remoting.Messaging.StackBuilderSink.AsyncProcessMessage'
Step into: Stepping over method without symbols 'System.Threading.ThreadPoolWorkQueue.Dispatch'
| » | [c#] Vprasanje glede eventovOddelek: Programiranje | 1966 (1680) | Looooooka |
| » | c# - mssql kombinacija / problem pri zapisu row-a v bazoOddelek: Programiranje | 2190 (1999) | darkolord |
| » | [c#] Vprasanje glede BackGroundWorker classa in spreminanja gui elementaOddelek: Programiranje | 1099 (1025) | Ericssony |
| » | [c#] Vprašanje glede release verzije aplikacijeOddelek: Programiranje | 1987 (1811) | Ericssony |
| » | Tezava pri instanciranju class-aOddelek: Programiranje | 1797 (1668) | KernelPanic |
