I/O errors
I/O errors
anin ::
Ojla!
Imam manjši problem z peko DVD-jev. S pomočjo dvd shrinka si ustvarim iso datoteko, ki jo potem želim zapeči na dvd. Do tukaj deluje vse ok, napaka pa se pojavi, ko bi to računalnik dejansko moral izvesti. Datoteko sem probala zapeči že z dvd decryptorjem, nerotom in img burnerjem, vendar mi noben od teh ni naredil totalno ničestar. Vsak od teh treh programov mi javlja I/O error. Zanima me kako naj to napako odpravim, saj mi je do predkratkim vse delovalo.
Če bo v kakšno pomoč img burner mi v log-u napiše tole:
I 20:02:57 ImgBurn Version 2.5.5.0 started!
I 20:02:57 Microsoft Windows XP Professional (5.1, Build 2600 : Service Pack 2)
I 20:02:57 Total Physical Memory: 3.144.812 KB - Available: 2.429.848 KB
I 20:02:57 Initialising SPTI...
I 20:02:57 Searching for SCSI / ATAPI devices...
I 20:02:57 -> Drive 1 - Info: Optiarc DVD RW AD-7203S 1.06 (G:) (ATA)
I 20:02:57 Found 1 DVD±RW/RAM!
I 20:03:31 Operation Started!
I 20:03:31 Source File: H:\TTW SP12\STEP_UP_3.ISO
I 20:03:31 Source File Sectors: 2.285.939 (MODE1/2048)
I 20:03:31 Source File Size: 4.681.603.072 bytes
I 20:03:31 Source File Volume Identifier: STEP_UP_3
I 20:03:31 Source File Volume Set Identifier: 00220DB6DVDSHRNK
I 20:03:31 Source File Implementation Identifier: DVD Shrink
I 20:03:31 Source File File System(s): ISO9660; UDF (1.02)
I 20:03:31 Destination Device: [2:1:0] Optiarc DVD RW AD-7203S 1.06 (G:) (ATA)
I 20:03:31 Destination Media Type: DVD-R (Disc ID: MCC 03RG20) (Speeds: 4x; 6x; 8x; 12x; 16x; 18x; 20x)
I 20:03:31 Destination Media Sectors: 2.297.888
I 20:03:31 Write Mode: DVD
I 20:03:31 Write Type: DAO
I 20:03:31 Write Speed: MAX
I 20:03:31 Link Size: Auto
I 20:03:31 Lock Volume: Yes
I 20:03:31 Test Mode: No
I 20:03:31 OPC: No
I 20:03:31 BURN-Proof: Enabled
I 20:03:31 Write Speed Successfully Set! - Effective: 27.700 KB/s (20x)
I 20:03:31 Filling Buffer... (40 MB)
I 20:03:32 Writing LeadIn...
W 20:04:24 Failed to Write Sectors 0 - 31 - Reason: Program Memory Area Update Failure
W 20:04:24 Retrying (1 of 20)...
W 20:04:25 Retry Failed - Reason: The request could not be performed because of an I/O device error.
W 20:04:25 Retrying (2 of 20)...
I 20:04:28 Writing LeadIn...
W 20:04:46 Failed to Write Sectors 320 - 351 - Reason: No Seek Complete
W 20:04:46 Retrying (1 of 20)...
W 20:04:46 Retry Failed - Reason: Write Error
W 20:04:46 Retrying (2 of 20)...
W 20:04:46 Retrying (3 of 20)...
W 20:04:46 Retrying (4 of 20)...
W 20:04:46 Retrying (5 of 20)...
W 20:04:46 Retrying (6 of 20)...
W 20:04:46 Retrying (7 of 20)...
W 20:04:46 Retrying (8 of 20)...
W 20:04:46 Retrying (9 of 20)...
W 20:04:46 Retrying (10 of 20)...
W 20:04:46 Retrying (11 of 20)...
W 20:04:46 Retrying (12 of 20)...
W 20:04:46 Retrying (13 of 20)...
W 20:04:46 Retrying (14 of 20)...
W 20:04:46 Retrying (15 of 20)...
W 20:04:46 Retrying (16 of 20)...
W 20:04:46 Retrying (17 of 20)...
W 20:04:46 Retrying (18 of 20)...
W 20:04:46 Retrying (19 of 20)...
W 20:04:46 Retrying (20 of 20)...
E 20:04:56 Failed to Write Sectors 320 - 351 - Reason: No Seek Complete
I 20:04:56 Synchronising Cache...
W 20:05:02 User opted to skip the 'Close Track/Session/Disc' functions.
E 20:05:02 Failed to Write Image!
E 20:05:02 Operation Failed! - Duration: 00:01:31
I 20:05:02 Average Write Rate: 0 KB/s (0.0x) - Maximum Write Rate: 0 KB/s (0.0x)
amigo_no1 ::
Lahko da je laser zanič.
Drugače bere ploščke ok ?
  • spremenilo: amigo_no1 ()
anin ::
Običajne cd-je z glasbo mi bere in kopira uredu, dvd mi tudi lepo prebere in prekopira na disk.
Kako instalirati ubuntu brez usbja/cdja/dvdja
172718 (2466) AC_DC
Huh počitnice so tu! ...kaj pa zdej?
81946 (1568) vrtnyka
Zanimiv server LOG
Oddelek: Omrežja in internet
142412 (1980) TheHijacker
simetričen datum
91266 (1063) CaqKa
