Brink in open GL 3.1
jakob98 ::
Mogoče ima kdo od vas izkušnje iz igre Brink kako bi se dala ta zadeva fixati ? Konzola mi izpise tole :
------ Initializing File System ------
Loaded pak000.sdpk2
Loaded pak001.sdpk2
Loaded pak002.sdpk2
Loaded pak003.sdpk2
Loaded pak004.sdpk2
Loaded pak005.sdpk2
Loaded pak006.sdpk2
Loaded zzzenglish000.sdpk2
Loaded zzzenglish001.sdpk2
Loaded zzzenglish002.sdpk2
Loaded zzzenglish003.sdpk2
Loaded zzzenglish004.sdpk2
Loaded zzzenglish005.sdpk2
Loaded zzzenglish006.sdpk2
Current search path:
D:\Steam\userdata\83555554\22350\local/base
C:\Users\Jakob\AppData\Local\Splash Damage\Brink/base
d:\steam\steamapps\common\brink/base
zzzenglish006.sdpk2
zzzenglish005.sdpk2
zzzenglish004.sdpk2
zzzenglish003.sdpk2
zzzenglish002.sdpk2
zzzenglish001.sdpk2
zzzenglish000.sdpk2
pak006.sdpk2
pak005.sdpk2
pak004.sdpk2
pak003.sdpk2
pak002.sdpk2
pak001.sdpk2
pak000.sdpk2
file system initialized.
Loaded 3781 manifest elements in 10 ms - 192Kb
Discarded 0 manifest elements
Max filename length: 0 characters
Brink 1.0.23504.48064 win-x86 Jun 29 2011 15:04:59
couldn't exec 'brinkconfig.cfg'
couldn't exec 'autoexec.cfg'
Vendor: 0000 Device: 0000
3010 MHz Intel CPU with MMX & SSE & SSE2 & SSE3 & HTT
2 logical cores
2 physical cores
HT disabled in hardware
3584 MB System Memory
64 MB Video Memory
Initializing performance queries
Detected
2 3.01 GHz CPU
3584 MB of System memory
64 MB of Video memory on an optimal video architecture
This system qualifies for Low quality.
Winsock Initialized
Found interface: {C9AF82EE-0BE2-4994-8D1B-368B100EB0E2} Realtek RTL8102E/RTL8103E Family PCI-E Fast Ethernet NIC (NDIS 6.20) - 92.53.145.25/255.255.255.0
Sys_InitNetworking: adding loopback interface
--- Loading sequence: init ---
sound index file 'generated/preload/sound/pc/english/init.soundpreload' is zero length
------- Initializing render context --------
Initializing OpenGL subsystem
...calling LoadLibrary( 'wtsapi32.dll' ): succeeded
...initializing Windows Terminal Server API
...registered window class
...registered fake window class
...calling LoadLibrary( 'opengl32' ): succeeded
...initializing QGL
GL_VENDOR: Microsoft Corporation
GL_RENDERER: GDI Generic
GL_VERSION: 1.1.0
idFile_AsyncPermanent::Write: failed to write to c:\users\jakob\appdata\local\splash damage\brink\base\diag.txt
FATAL ERROR: The current video card / driver combination does not support OpenGL 3.1 or newer.
Shutting down OpenGL subsystem
...releasing DC
...resetting display
...shutting down QGL
...unloading OpenGL DLL
...unloading Windows Terminal Server API DLL
  • spremenil: Mavrik ()
BALAST ::
Daj povej še katero grafično kartico imaš v računalniku?
Senitel ::
64 MB Video Memory
Uf... Neki pošteno antičnega?
jakob98 ::
V računalniku imam grafično artico ; NVIDIA GeForce 9800 GT (Prerelease - WDDM 1.1)
Senitel ::
Pa imaš dejansko gonilnike za to grafično naložene (katero verzijo)?
jakob98 ::
nimam ker jih na spletu nenajdem (niso pravi)
Senitel ::
Prenosnik?
jakob98 ::
ne , na novo sm si nalozu vlke komp pa mi negre starih drajverjov naložit
mogoc bi mi lahko preko team wiwerja prisu pogledat ?
  • spremenilo: jakob98 ()
Senitel ::
Ja potem tle izbereš svojo konfiguracijo in snameš dol driverje.
jakob98 ::
product pa serial newem kolk mam :/
Senitel ::
Pa saj ne rabiš serijske za driverje namestit...
jakob98 ::
Hvala ¨ igrica dela 100% !
macgajver ::
Da ne odpiram nove teme sem sprobal brink je free vikend na steamu špil je zelo švoh.
tenstan krompir je pa zakon
No sound (Wolfenstein...)
Oddelek: Igre
152594 (2430) Slo-One
Problem z nvidio
171903 (1651) lanicorec
Gentoo install (strani: 1 2 )
Oddelek: Operacijski sistemi
526467 (5887) HerrBaron
Problem z zagonom iger RTCW in MOHAA
Oddelek: Igre
153124 (2808) Flay
Wolfenstein in XP???! :o(
61488 (1390) zrebec
