Forum » Omrežja in internet » Kako izklopiti avtomatski refresh v IE???
kuntek ::
Neka stran se avtomatsko refresira vsakih 10s kar pa mene zelo moti
. Ali je možno avtomatski refresh kako izklopiti? Stran bi rad refreshiral sam z gumbom za to.
Gandalfar ::
ah nasu
To disable automatic redirection in Internet Explorer:
Click Tools > Options.
Click the "Security" tab.
Scroll down to the Miscellaneous section (should be about halfway and will have blue IE icons).
Where it says "Allow META REFRESH", select Disable.
SubOrbit ::
gandalfar: ja, to deluje, ce je refresh/redirect podan z META tagom, ce je pa v igri kak javascript pa ne dela...
potem pac ugasnes scripting...
| » | razložitev nekaterij elementov v visual studio 05Oddelek: Programiranje | 2600 (2405) | darkolord |
| » | FPS in Hz na monitorju v igrah (strani: 1 2 )Oddelek: Igre | 6034 (5426) | BigWhale |
| » | VB6 problemOddelek: Programiranje | 1214 (1106) | Skoky |
| » | Vtis Gentoo Linux 1.4Oddelek: Operacijski sistemi | 1749 (1513) | Brane2 |
| » | eDonkeyOddelek: Pomoč in nasveti | 2079 (1176) | AIDS |
