Kateri televizor?
Kateri televizor?
GenZNPC ::
Invictus je izjavil:
GenZNPC je izjavil:
Bo treba najprej zacet snemat filme v HFR+HDR+4K
Ali pa narediti res dober čip za upscaling ;).
Butbutbut, to ni native;)
skibidi
Nič bat, takoj ko bodo kamere za 4k+HDR+HFR, bodo zunaj porniči v tem formatu...
Tomson ::
GenZNPC je izjavil:
Uff ta LG ma Dolby Vision podporo, kar bi naj pomenilo 12bitov napram HDR10.
Je to tako?
LG UH770, kot niti drugi TVji nima 12bitnega panela. Pravzaprav ne podpira niti WideColoGamut ...
Dolby Vision films are mastered in up to 12-bit colour, whereas HDR 10 is mastered for 10-bit colour, hence the name.
Note: Current TVs max out at 10-bit color, but sending a 12-bit signal helps to allow processing (like white balance adjustments) to be enabled without adding banding.
GenZNPC ::
Torej fajn za PC ali pac?
skibidi
Tomson ::
A 10-bit display is only useful if you are watching a 10 bit content, which is really rare. Currently, almost everything is 8 bit, including Windows or game consoles. HDR takes advantage of 10-bit, and so getting a TV that supports 10-bit color is only important if you intend to watch HDR videos.
For computers, only specific, professional graphics cards are guaranteed to be able to output a 10-bit signal. The Nvidia Quadro and the AMD Firepro lines both support 10-bit, so if you need that capability with your PC, you should get one of those. Some people claim to be able to force 10-bit with regular high-end graphics cards, but this is unofficial, so your mileage may vary.
  • spremenilo: Tomson ()
GenZNPC je izjavil:
http://www.rtings.com/tv/reviews/by-usa...
knap ::
zanimiva zadeva:
Hisense H65M7000 4K UHD TV Review - You won't find better for the price
https://www.avforums.com/review/hisense...
Ocena 9/10
Se to dobi pri nas?
Cena?
andrej69 ::
knap je izjavil:
zanimiva zadeva:
Ocena 9/10
Se to dobi pri nas?
Cena?
http://www.makspro.si/index.php/avdio-v...
Dami ::
Ma kdo kako informacijo, če bojo pri nas trgovci (bigbang predvsem) tudi imeli "black friday" akcijo?
andrej69 ::
Dami je izjavil:
https://www.bigbang.si/black-friday
GenZNPC ::
Tomson je izjavil:
Glede tega ni panike, Maxwell in Pascal podpirata 10bitov, kakor tudi je ze ene par iger z HDR.
Celo pa na PS4 Pro/xbs jih je ze kr nekaj.
skibidi
[SkA] ::
Tudi na običajnem PS4, Uncharted 4 npr., uspešno preklopi moj tv v HDR način (1080p).
  • spremenil: [SkA] ()
Wolfie ::
Pozdravljeni!
Iščem 40" TV za okoli 300 € in me zanima, kaj je v tem segmentu "best buy". Kolikor sem spremljal tale forum sta v ospredju Samsung J5100 in Philips 4201. Sam sem našel še Sharp 40CFE4042E ter Sony KDL40RD450B. Trenutno predvsem kolebam med Samsungom in Sonyjem in bi bil vesel mnenj glede najboljše izbire.
Btw, a se sploh splača počakati na božični čas za morebitne popuste. Predvidevam, da ta segment (okoli 300 €) ne bo deležen kakšnih dodatnih popustov in bi raje morda izkoristil ta vikend (black friday in cyber monday).
Že vnaprej hvala za mnenja.
Han ::
Počakaj na petek/ponedeljek, morda bodo še malo znižali ceno Samsungu 40K5502, ki je precej boljši od J5100.
Blazz ::
4knative je izjavil:
Za tiste kateri imate ks7000. Na mimovrste bodo imeli v black friday akciji 6pack sekundno lepilo.
ne rabmo, hvala
Dami je izjavil:
obiskat bigbang.si je pretežko :)
  • spremenil: Blazz ()
mjaa ::
Kakšna so pa kaj mnenja glede LG 43LH630V ali Philips 43PUH6101? Išče se namreč 43" do tam okoli 400 EUR.
roko11111 ::
umrl mi je TV v spalnici(32" LG 6 let star) in ker večjega nimam kam dati bi prosu za kak nasvet za novega, torej 32", fajn da ma full hd, 300 do max okol 350€.
nekak mi najbolj diši Samsung, mogoče tudi kaj drugega, samo Phillipsa ne. kaj pravite na tela dva spodi, a mi lahk kir puve kaka je razlika?
še nekaj, a je sploh kak TV da ima samo WiFi + web browser in brez Smart TV?
OK.d ::
LPOK.d
NejcSSD ::
Tale se mi zdi dober za nekaj postov nazaj
Wrop ::
A kdo sploh opazi razliko v sliki med 8 bit in 10 bit panelom?
Dami ::
roko11111 je izjavil:
Če ima tv web browser, je že kr "pameten" :)
GenZNPC ::
Wrop je izjavil:
V prihodnosti, ko bos gledal HDR vsebino in potem pogledal nazaj 8 bitnega. Bos ja.
skibidi
boyc ::
V tem istem letaku iz leclerca je tudi Vox TV 102cm,po osnovnih specifikacijah zelo podoben ostalim Samsungom in LG. Pa me zanima vase mennje oz. ce ima kdo izkusnje s to znamko.Kje se lahko pojavijo vidne razlike, da bi ta slabsi od Samsunga ali pa LG z enakimi specifikacijami?
4knative ::
Ma kdo ta kitajski OLED, imenovan ULED, znamke Hisense?
bojanpo ::
Predvidevam da ciljas na h65m7000?
Lahko si tukaj preberes user review-e.
https://www.avforums.com/threads/hisens...
roko11111 ::
mi lahk kir pomaga a lahko montiram tale TV http://www.makspro.si/index.php/avdio-v... na stenski nosilec ki ga že imam in sicer https://www.nakupovanje.net/izdelki/avd...
nism zihr ker nosilc je raven, ta TV pa mnde uzadi ni raven, 4 šraufe mam pa dolge 1,5cm in nism zihr če bom lahk prišraufau. sm kontaktiru tut Samsung že sam še niso odgovoril...
Han ::
Temu Samsungu so priloženi plastični distančniki (tulci), ki omogočijo poravnavo za stenski nosilec. Zato potrebuješ daljše vijake, dolge ca. 5 cm. Premer navoja je 6 mm.
  • spremenil: Han ()
konspirator ::
Ta bo jutri znižan na 200 iz 260 (black friday)
https://www.bigbang.si/tv-sprejemniki/3...
roko11111 ::
aha ok hvala Han. sm vidu včeraj tete tulce ja pa nism bil zihr da služijo temu namenu.
JanezH ::
klemen1313 ::
če ima kdo minuto časa, bi prosil za en nasvet.. :) Kupujem nov TV.. Pa bi rad čim več za svoj denar, itak :) Odločil sem se nekako za 55".. Najbolj zanimiv mi je bil Sony KD-55XD8577S.. Ki naj bi bil top v tem cenovnem razredu. Je to res? Zanima me pa samo kakšna alternativa temu TVju.. Po možnosti par 100€ cenejša.. :) Hvala že v naprej vsem..
Tomson ::
V tem cenovnem rangu je na prvem mestu defenitivno Samsung 55KS7002, omenjeni Sony je dobra alternativa, a z IPS panelom. Še ena dobra VA alternativa je malenkost večji in dražji Panasonic 58DX750. Od cenejših alternativ pa je najboljša izbira Hisense H55M7000 za 1.070€.
mAXTER ::
Zanima me če je za tale Sony KD-49XD7005 dobra cena 570€?
_njc ::
Tudi mene to zanima. Za starše iščem načeloma nek Full HD TV, za gledanje TV programov, občasno kakšen 1080p film in risanke za vnuke. Velikosti 42"-55", budget do 600€.
puginho ::
Za Sonya 4K pa 49 inčev je to nora cena
Živjo,
Če mogoče kdo kje zasledi katerega od teh TV-je po "črni" ceni prosim za link...
UE55KS7000
LG55UH850V
LG55UH8507
tonis ::
Zdravo,
kupujem 55'' tv (4K), gledam modele do 850€ z DDV, predvsem Samsung in LG.
Vem da za ta denar ne dobim "top shit" produkta, vseeno pa bi vas prosil za malce pomoči, kateri model nudi najboljšo sliko?
Gor bo priklopljen Amis STB, za razne video vsebine pa soliden tv box (android) - s tem želim povedat, da TV bo bolj ali manj samo za prikaz slike.
Hvala.
elmofud ::
Fantje, Unieuro ima 3 dni Black Friday akcijo in ima na vse blago 25% popust. Cena za LG 55B6V je tako neverjetnih 1485 eur.
Je kdo ze narocal tam? Kako se izbere prevzem v poslovalnici? V online shopu imajo le opcijo dostave na dom, seveda na italijanski naslov.
Tomson ::
tonis je izjavil:
Zdravo,
kupujem 55'' tv (4K), gledam modele do 850EUR z DDV, predvsem Samsung in LG.
Hvala.
Najboljša opcija v tem cenovnem razredu je Philips 55PUS6501/6551. Alternativa Samsung 55KU6072/6099, če te ne moti "judder", ki je na vseh KU modelih prisoten. Še malo slabša alternativa je Sony 55X7005. LG nima nič pametnega oz. vrednega nakupa v tem cenovnem rangu, prvi dober model je 55UH770, ki pa je dražji. Še ena dobra alternativa, sicer letnik 2015, brez HDR podpore, a overall precej dober TV je Panasonic 55CX670 za cca. 750EUR ...
djpiky ::
Fantje,
ta vikend kupim tv. Kaj priporočate? Velikost 65', cena do 1300€.
Je tole vredno nakupa?
https://www.bigbang.si/tv-sprejemniki/6...
Vid09 ::
elmofud je izjavil:
Jaz sem kupil v Unieuro prav ta TV pred dobrim mesecem. Takrat je bil 1.580 EUR.
Nakup je sila enostaven. Na spletu naročiš, izbereš poslovalnico v ITA, kjer ti ga bodo dostavili (v naši bližini sta kar dve - sam sem izbral Monfalcone - Tržič): https://www.unieuro.it/online/negozi/Un... Ko roba pride, te obvestijo in potem plačaš na licu mesta. Easy. Nekatere prodajalke znajo tudi slovensko.
Samo kupi! Božanski TV. Ne bo ti žal. :)
dorma ::
Pozdravljeni,
Do sedaj sem imel plazmo lg 50..bila je res odlična slika... Kateri tv 55 ali 58,60, naj kupim do 1200 eur in bo slika temu primerna, kot so bile na plazmi...predvsem želim naravne barve.. Sem gledal oled ampak cene mi niso preveč všeč..Hvala za odgovor!!! Lep dan še naprej!!
p0ki ::
Po izmeri prostora ki je na voljo za Tv sem ugotovil da je najvecja mozna sirina Tvja 107cm, budget je tam do 800e. Kaj priporocate? Igral se bo ps4 in gledalo se bo filme ter sport
"As far back as I can remember, I always wanted to be a gangster"
moped1 ::
Glede na to, da nisem ravno podkovan z italjanščino, me zanima ali je možno videti zaloge na spletni strani za posamezne poslovalnice Unieuro...predvsem te v naši bližini (Furlanija). Resno se zanimam za LG 55B6V. Če bi zadevo imeli na zalogi, bi se kar odpeljal do poslovalnice in nabavil. Sem pa iz Gorenjske pa da se ne bi zastonj vozil 170km daleč... Tudi LG 55UH750V, ki bi bil za mamo, je zelo ugoden, glede na naše cene.
Vid09 ::
moped1 je izjavil:
Moja izkušnja je sledeča. Ko kupiš na spletu tudi izbereš način dostave. Ena od možnosti je bila tudi dostava v trgovino, ki jih ima Unieuro po celi Italiji. Da je TV prišel do trgovine pa je trajalo cca. 1 teden. Ali so ga že imeli prav v tisti trgovini ne vem. Morda bo najbolje, če pokličeš trgovino. Tista v Monfalcone ima tudi prodajalke, ki govorijo slovensko.
moped1 ::
Vid09 je izjavil:
moped1 je izjavil:
Ima TV mogoče meni tudi v slovenščini? TV si naročil preko spleta plačal pa v trgovini...to se verjetno izbere na koncu naročila ob izbiri trgovine v katero naj ga dostavijo?
moped1 ::
Tudi sam ima probleme pri naročilu...nikjer ne najdem dostave v trgovino, samo na naslov v Italiji.
krho ::
Res je.. Edino, kar lahko izbereš je SPEDIZIONE A DOMICILIO, aka dostava na dom. Nisem se šel pa registrirat, da bi preveril, če slučajno potem lahko spremeniš način dostave.
  • spremenil: krho ()
4knative ::
Je kdo tu gor, ki je dobil LG 55B6V za 1799eur v akciji na electronic4you.si?
tonis ::
Tomson je izjavil:
Zdravo,
Hvala za odgovor tako tebi kot tudi še enemu uporabniku, ki je odgovoril preko ZS.
Oba sta me usmerila proti Philipsu in verjetno bom res šel v to smer.
Sem pa našel še en model (55PUS6561), ki ima ambilight na 3 stranicah, cenovno pa smo tam tam.
Na mimovrste je 830€ link
..tako da najverjetneje bo to moj naslednji TV. ustavite me, če se narobe odločam :)
Hvala.
174 / 223
