Ubuntu 10.10, kako uporabiti nokio C6 za dostop na net ?
l0g1t3ch ::
Torej na win samo namestim pc/ovi suite aplikacijo od nokie in že sem na netu. Kaj rabim narediti na Ubuntu 10.10, da bo to delalo ?
Moj telefon je Nokia C6-00.
Namestil sem aplikacijo wvdial ampak nevem kaj naj vnesem v conf fajl. Mi lahko kdo pomaga z nastavitvami za simobil operaterja. Hvala.
  • spremenilo: l0g1t3ch ()
l0g1t3ch ::
Moj wvdial.conf
[Dialer Defaults]
Init1 = ATZ
Init2 = ATQ0 V1 E1 S0=0 &C1 &D2 +FCLASS=0
Modem Type = USB Modem
Baud = 460800
New PPPD = yes
Modem = /dev/ttyACM0
ISDN = 0
; Phone = <Target Phone Number>
; Password = <Your Password>
; Username = <Your Login Name>
[Dialer C6]
Baud = 460800
Init = AT+CGDCONT=1,"IP","internet.simobil.si",,0,0
username = simobil
password = internet
Phone = *99#
tole pravi wvdial ob poskusu povezave in tu obvisi v nedogled
buntu@ubuntu:~$ sudo wvdial --config /etc/wvdial.conf C6
[sudo] password for buntu:
--> WvDial: Internet dialer version 1.60
--> Cannot get information for serial port.
--> Initializing modem.
--> Sending: AT+CGDCONT=1,"IP","internet.simobil.si",,0,0
OK
--> Sending: ATQ0 V1 E1 S0=0 &C1 &D2 +FCLASS=0
OK
--> Modem initialized.
--> Sending: ATDT*99#
--> Waiting for carrier.
ATDT*99#
CONNECT
~[7f]}#@!}!} } }2}#}$@#}!}$}%\}"}&} }*} } g}%~
--> Carrier detected.  Waiting for prompt.
--> PPP negotiation detected.
--> Starting pppd at Tue Jun  7 04:40:45 2011
--> Pid of pppd: 16532
--> Using interface ppp0
--> pppd: ?w? ?u?
--> pppd: ?w? ?u?
--> pppd: ?w? ?u?
--> pppd: ?w? ?u?
--> pppd: ?w? ?u?
--> local  IP address 46.122.68.129
--> pppd: ?w? ?u?
--> remote IP address 10.6.6.6
--> pppd: ?w? ?u?
--> primary   DNS address 80.95.224.44
--> pppd: ?w? ?u?
--> secondary DNS address 80.95.224.45
--> pppd: ?w? ?u?
tole pa pravi ifconfig
buntu@ubuntu:~$ ifconfig
lo        Link encap:Local Loopback
          inet addr:127.0.0.1  Mask:255.0.0.0
          inet6 addr: ::1/128 Scope:Host
          UP LOOPBACK RUNNING  MTU:16436  Metric:1
          RX packets:19 errors:0 dropped:0 overruns:0 frame:0
          TX packets:19 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:0
          RX bytes:1240 (1.2 KB)  TX bytes:1240 (1.2 KB)
ppp0      Link encap:Point-to-Point Protocol
          inet addr:46.122.68.129  P-t-P:10.6.6.6  Mask:255.255.255.255
          UP POINTOPOINT RUNNING NOARP MULTICAST  MTU:1500  Metric:1
          RX packets:4 errors:0 dropped:0 overruns:0 frame:0
          TX packets:5 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:3
          RX bytes:64 (64.0 B)  TX bytes:97 (97.0 B)
Zvezdica27 ::
lp,
meni je uspelo na E72 preko gnome-ppp (ki pa je samo GUI za wvdial ... ali sem to pol dodal, ne vem, se ne spomnim več). ne vem točno po katerih navodilih sem delal, morda
http://mynewn95.blogspot.com/2008/06/us...
ali
http://manish-chaks.livejournal.com/770...
http://hatzimihailm.blogspot.com/2010/0...
ne vem, eni vodiči pišejo skripte in vse živo, jaz pa vem da je bilo pri meni silno enostavno, telefon mora biti v PC suite mode. Poglej kaj ti manjka glede na ta dva vodiča, ki sem ju našel v 1 min (init3 ti manjka, nisem pa stručko, če je ključen). Se pa ne spomnim več, ker 10.04 je šel na 10.10 in pol nazaj, GPRS pa skor da ne rabim in trenutno nimam nastavljeno. Lahko pa probam še enkrat, recmo v parih dneh.
zz
TuŠmobil internet preko računalnika
53251 (3164) jl
Mobitel Internet
Oddelek: Omrežja in internet
72200 (1924) popster
Ubuntu in adsl
Oddelek: Operacijski sistemi
202753 (2469) gregs
PPP: Input/output error
91939 (1777) b
[pppoe povezava] Couldn't increase MRU/MTU to 1500
122104 (1958) NeOman
