Forum » Operacijski sistemi » [pppoe povezava] Couldn't increase MRU/MTU to 1500
NeOman ::
imam tezavo pri vzpostavitvi pppoe povezave na debianu. in sicer, po koncani "pppoeconf", ko pozenem stvar ("pon dsl-provider") pogledam log ("plog") nakar ugotovim, da povezava ni uspela. razlog: couldn't increase MRU/MTU to 1500.
pomoc prosim... sem ze poskusav rocno spremenih
etc/ppp/options nastavim:
mtu1500
mru1500
a stvar se vedno ne dela, smlk.
mtu1500
mru1500
Matri[X] ::
Pri pppoe ne mores imeti MTUja 1500 zaradi overheada pppoe protokola (enkapsulacija ppp v ethernet okvirje). MTU za pppoe je ponavadi 1492.
NeOman ::
no namucil sem se in mountal floppy v ukazni vrstici in dobil naslednje:
ifconfig:
eth0 Link encap:Ethernet HWaddr 00:08:A1:2C:EF:79
inet addr:192.168.0.1 Bcast:192.168.0.255 Mask:255.255.255.0
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:28 errors:0 dropped:0 overruns:0 frame:0
TX packets:120 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:1794 (1.7 KiB) TX bytes:4594 (4.4 KiB)
Interrupt:10 Base address:0xec00
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
UP LOOPBACK RUNNING MTU:16436 Metric:1
RX packets:32 errors:0 dropped:0 overruns:0 frame:0
TX packets:32 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:2680 (2.6 KiB) TX bytes:2680 (2.6 KiB)
ppp0 Link encap:Point-to-Point Protocol
inet addr:xxx.xxx.xxx.xxx P-t-P:213.250.19.90 Mask:255.255.255.255
UP POINTOPOINT RUNNING NOARP MULTICAST MTU:1492 Metric:1
RX packets:14 errors:0 dropped:0 overruns:0 frame:0
TX packets:3 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:3
RX bytes:642 (642.0 b) TX bytes:54 (54.0 b)
plog:
Mar 29 16:40:14 lamer pppd[1671]: Couldn't increase MRU to 1500
Mar 29 16:40:15 lamer pppd[1671]: CHAP authentication succeeded
Mar 29 16:40:15 lamer pppd[1671]: peer from calling number xx:xx:xx:xx:xx:xx authorized
Mar 29 16:40:15 lamer pppd[1671]: not replacing default route to eth0 [192.168.0.1]
Mar 29 16:40:15 lamer pppd[1671]: Cannot determine ethernet address for proxy ARP
Mar 29 16:40:15 lamer pppd[1671]: local IP address xxx.xxx.xxx.xxx
Mar 29 16:40:15 lamer pppd[1671]: remote IP address 213.250.19.90
Mar 29 16:40:15 lamer pppd[1671]: primary DNS address 193.189.160.11
Mar 29 16:40:15 lamer pppd[1671]: secondary DNS address 193.189.160.12
kako mru povecat na 1500, smlk?
ifconfig:
plog:
NeOman ::
ko pa poskusam pingat karkoli ni localhost al pa moj dodeljen ip se pa ustavi... tudi ko hocem nastavit apt-get na FTP ne razresi naslova.
Matri[X] ::
Ali paketi sploh zapustijo tvoj racunalnik ko poskusas pingat?
Ali imas vklopljen firewall?
Ali se ti ob vzpostavitvi povezave doda default gateway?
- spremenil: Matri[X] ()
NeOman ::
sem uredil, problem je bil v skripti "pppoeconf", rocno sem nastavil vse potrebno in stvar tece
. ker sem linux n00b pa je hudo verjetno da zastavim se kaksno vprasanje.
btw: tole pisem iz linuxa ;)
- spremenil: NeOman ()
| » | Suse 10.2 in internet konekcijaOddelek: Pomoč in nasveti | 1441 (1336) | znovak |
| » | Ubuntu in povezava v internetOddelek: Operacijski sistemi | 1813 (1526) | Blinder |
| » | Ubuntu in nedelujoč netOddelek: Operacijski sistemi | 2318 (2134) | Pyr0Beast |
| » | Ubuntu in adslOddelek: Operacijski sistemi | 2767 (2483) | gregs |
| » | PPP: Input/output errorOddelek: Omrežja in internet | 1949 (1787) | b |
