Forum » Operacijski sistemi » Ubuntu 10.10, kako uporabiti nokio C6 za dostop na net ?
l0g1t3ch ::
Torej na win samo namestim pc/ovi suite aplikacijo od nokie in že sem na netu. Kaj rabim narediti na Ubuntu 10.10, da bo to delalo ?
Moj telefon je Nokia C6-00.
Namestil sem aplikacijo wvdial ampak nevem kaj naj vnesem v conf fajl. Mi lahko kdo pomaga z nastavitvami za simobil operaterja. Hvala.
- spremenilo: l0g1t3ch ()
l0g1t3ch ::
Moj wvdial.conf
tole pravi wvdial ob poskusu povezave in tu obvisi v nedogled
tole pa pravi ifconfig
[Dialer Defaults] Init1 = ATZ Init2 = ATQ0 V1 E1 S0=0 &C1 &D2 +FCLASS=0 Modem Type = USB Modem Baud = 460800 New PPPD = yes Modem = /dev/ttyACM0 ISDN = 0 ; Phone = <Target Phone Number> ; Password = <Your Password> ; Username = <Your Login Name> [Dialer C6] Modem = /dev/ttyACM0 Modem Type = USB Modem Baud = 460800 Init = AT+CGDCONT=1,"IP","internet.simobil.si",,0,0 username = simobil password = internet Phone = *99#
buntu@ubuntu:~$ sudo wvdial --config /etc/wvdial.conf C6 [sudo] password for buntu: --> WvDial: Internet dialer version 1.60 --> Cannot get information for serial port. --> Initializing modem. --> Sending: AT+CGDCONT=1,"IP","internet.simobil.si",,0,0 OK --> Sending: ATQ0 V1 E1 S0=0 &C1 &D2 +FCLASS=0 OK --> Modem initialized. --> Sending: ATDT*99# --> Waiting for carrier. ATDT*99# CONNECT ~[7f]}#@!}!} } }2}#}$@#}!}$}%\}"}&} }*} } g}%~ --> Carrier detected. Waiting for prompt. ~[7f]}#@!}!} } }2}#}$@#}!}$}%\}"}&} }*} } g}%~ --> PPP negotiation detected. --> Starting pppd at Tue Jun 7 04:40:45 2011 --> Pid of pppd: 16532 --> Using interface ppp0 --> pppd: ?w? ?u? --> pppd: ?w? ?u? --> pppd: ?w? ?u? --> pppd: ?w? ?u? --> pppd: ?w? ?u? --> local IP address 46.122.68.129 --> pppd: ?w? ?u? --> remote IP address 10.6.6.6 --> pppd: ?w? ?u? --> primary DNS address 80.95.224.44 --> pppd: ?w? ?u? --> secondary DNS address 80.95.224.45 --> pppd: ?w? ?u?
buntu@ubuntu:~$ ifconfig
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:16436 Metric:1
RX packets:19 errors:0 dropped:0 overruns:0 frame:0
TX packets:19 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:1240 (1.2 KB) TX bytes:1240 (1.2 KB)
ppp0 Link encap:Point-to-Point Protocol
inet addr:46.122.68.129 P-t-P:10.6.6.6 Mask:255.255.255.255
UP POINTOPOINT RUNNING NOARP MULTICAST MTU:1500 Metric:1
RX packets:4 errors:0 dropped:0 overruns:0 frame:0
TX packets:5 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:3
RX bytes:64 (64.0 B) TX bytes:97 (97.0 B)
Zvezdica27 ::
lp,
meni je uspelo na E72 preko gnome-ppp (ki pa je samo GUI za wvdial ... ali sem to pol dodal, ne vem, se ne spomnim več). ne vem točno po katerih navodilih sem delal, morda
http://mynewn95.blogspot.com/2008/06/us...
ali
http://manish-chaks.livejournal.com/770...
http://hatzimihailm.blogspot.com/2010/0...
ne vem, eni vodiči pišejo skripte in vse živo, jaz pa vem da je bilo pri meni silno enostavno, telefon mora biti v PC suite mode. Poglej kaj ti manjka glede na ta dva vodiča, ki sem ju našel v 1 min (init3 ti manjka, nisem pa stručko, če je ključen). Se pa ne spomnim več, ker 10.04 je šel na 10.10 in pol nazaj, GPRS pa skor da ne rabim in trenutno nimam nastavljeno. Lahko pa probam še enkrat, recmo v parih dneh.
zz
ali
zz
| » | TuŠmobil internet preko računalnikaOddelek: Pomoč in nasveti | 3250 (3163) | jl |
| » | Mobitel InternetOddelek: Omrežja in internet | 2200 (1924) | popster |
| » | Ubuntu in adslOddelek: Operacijski sistemi | 2752 (2468) | gregs |
| » | PPP: Input/output errorOddelek: Omrežja in internet | 1939 (1777) | b |
| » | [pppoe povezava] Couldn't increase MRU/MTU to 1500Oddelek: Operacijski sistemi | 2104 (1958) | NeOman |
