Forum » Hlajenje in modifikacije » Matrox Orbital LCD
Matrox Orbital LCD
hmale ::
Hello to all my friends at Slo-Tech!!
I have just posted an article about the Matrix Orbital LCD. This is a modders favorite.
I hope you like it
http://www.extrememhz.com/molcd-p1.html
Cheers!
I hope you like it
Cheers!
morphling1 ::
Very nice indeed. I haven't notice the price for display, you said it was quite expensive. How much exactly ?
hmale ::
My friend Morph!
This one is about $70.00 plus accessories and shipping (total of appr $95.00).
The thing that is nice about this one is that it gives the user choices as to color. We chose the "Ice Blue" display model. Pretty cool I think.
Cheers!
Cheers!
morphling1 ::
Ouch, 95$ for everything, so is that virtualy just plug&play except for some cutting, or does that involve some soldering (no problem though)
Is there any way to connect display inside the case or you must take the cable to the back of the case ?
What about Crystal fontz are they any cheaper?
Thanks for info
Thanks for info
hmale ::
This unit is as close to plug and play as it gets. There is no soldering involved. With all the software that is customized for the Matrix Oribital, it is a no brainer to install and get up and running very quickly.
After the unit is installed in the case bezel, all that is done is run a db9 to db9 cable to theback of the case and you are in business.
I have priced the Crystal Fontz and they seem to run between 10% and 20% cheaper.
morphling1 ::
Thanks for that informations. One day, one day , when I get new case I'll be getting something like that, but for now it's just not worth to put something that nice on my case
CHAOS ::
morphling1: Would this software work with our LCDs? The one made by the tutorials which were posted here on the forum.
'They have computers, and they may have other weapons of mass destruction.'
morphling1 ::
btw. I just browsed through few of those threads, this Lcd's are quite cheap here and the software should be compatible between most of them.
You can try matrix orbital software here: http://www.matrixorbital.com/downloads....
or Crystalfontz here : http://www.crystalfontz.com/software/
Hmm lcd diplay on Antec front panel door , yeah that would look just great
hmale ::
Sorry Chaos.
I am not familiar with the work that has been done with other LCDs. I would hate to steer you in the wrong direction.
Thanks to all the nice people at Slo-Tech!
Cheers!
Cheers!
| » | Nov članek: "All your firmware are belong to us" (strani: 1 2 3 )Oddelek: Novice / Nova vsebina | 20340 (17180) | arrigo |
| » | Water-Cooled Dual AthlonsOddelek: Hlajenje in modifikacije | 3245 (2839) | Sergio |
| » | A.I. (strani: 1 2 )Oddelek: Loža | 6603 (5648) | Thomas |
| » | Water Block/Heater CoreOddelek: Hlajenje in modifikacije | 3145 (2460) | DrSergioDJ |
