settlers 7 error
settlers 7 error
avatar_7 ::
Zanima će ve kdo kaj pomeni ''the application was unable to start correctly(0xc0000005). Click OK to close the application.''
to mi ven vrze ko sem instaliral igro in vse naredil po navodilih, pa mi vseeno ne gre..
hvala za pomoč:)
sirotka ::
-it probably means that you're using AVG antivirus. AVG seems to be the only antivirus which finds trojan in the crack and blocks access to the application. Disabling AVG antivirus didn't work for me, but after I uninstalled it, and reinstalled Settlers 7, game runs great!
St235 ::
Če imaš original igro, kar močno dvomim, preveri če imaš zadnje gonilnike za grafično in uradne popravke igre.
Prižgal PC in manjka večino ikon! Kaj se je zgodilo?
151299 (1066) Excavator
Comodo firewall cmdagent.exe poraba CPU
Oddelek: Programska oprema
174486 (4312) BlackMaX
Mobilci in programska zaščita zanje
Oddelek: Mobilne tehnologije
165253 (4838) Chev
Varnost
81539 (1292) zee
Kateri antivirusni program naj izberem
4910155 (9102) bluefish
