Ubuntu 10 - ugasniti touchpad
bajsibajsi ::
Ima kdo kako idejo kako v Ubuntu 10 popolnoma izklopiti touchpad? Brez da namescam Gpointing settings ali kako drugo aplikacijo.
Imam tukaj kaj narobe?
#! /bin/sh
### BEGIN INIT INFO
# Provides: touchpad
# Required-Start: $remote_fs $syslog $all
# Required-Stop:
# Default-Start:
# Default-Stop: 2
# Short-Description: Disables the touchpad
### END INIT INFO
PATH=/sbin:/usr/sbin:/bin:/usr/bin
TOUCHPAD=”AlpsPS/2 ALPS DualPoint TouchPad”
. /lib/init/vars.sh
. /lib/lsb/init-functions
case “$1″ in
start)
xinput set-int-prop “$TOUCHPAD” “Device Enabled” 8 1
restart|reload|force-reload)
rmmod psmouse && modprobe psmouse
stop)
xinput set-int-prop “$TOUCHPAD” “Device Enabled” 8 0
echo “Usage: $0 start|stop” >&2
exit 3
esac
kanzyani ::
ti bi kaj takega prišlo prav?
bajsibajsi ::
Bom preveril, hvala.
edit/
o ja to bo super, da se ne zafrkavam s kodo. :)
Dnsmasq problem
Oddelek: Omrežja in internet
131500 (1127) BlaY0
Linux Ubuntu - kako ustvarim bližnjico, kako naložim Flash?
Oddelek: Operacijski sistemi
101504 (1290) SkyEye90
Linux Synaptics touchpad driverji
121543 (1420) preem
Gentoo - problemi z framebuffer in ifconfig (strani: 1 2 )
676247 (5571) Zaibatsu
IPv6 on Linux RH9
182749 (2298) Gandalfar
