Forum » Operacijski sistemi » Ubuntu 10 - ugasniti touchpad
bajsibajsi ::
Ima kdo kako idejo kako v Ubuntu 10 popolnoma izklopiti touchpad? Brez da namescam Gpointing settings ali kako drugo aplikacijo.
Imam tukaj kaj narobe?
#! /bin/sh
### BEGIN INIT INFO
# Provides: touchpad
# Required-Start: $remote_fs $syslog $all
# Required-Stop:
# Default-Start:
# Default-Stop: 2
# Short-Description: Disables the touchpad
### END INIT INFO
PATH=/sbin:/usr/sbin:/bin:/usr/bin
TOUCHPAD=”AlpsPS/2 ALPS DualPoint TouchPad”
. /lib/init/vars.sh
. /lib/lsb/init-functions
case “$1″ in
start)
xinput set-int-prop “$TOUCHPAD” “Device Enabled” 8 1
restart|reload|force-reload)
rmmod psmouse && modprobe psmouse
stop)
xinput set-int-prop “$TOUCHPAD” “Device Enabled” 8 0
echo “Usage: $0 start|stop” >&2
exit 3
esac
#! /bin/sh
### BEGIN INIT INFO
# Required-Stop:
# Default-Start:
# Default-Stop: 2
### END INIT INFO
. /lib/init/vars.sh
case “$1″ in
start)
stop)
exit 3
esac
bajsibajsi ::
Bom preveril, hvala.
edit/
o ja to bo super, da se ne zafrkavam s kodo. :)
edit/
- spremenilo: bajsibajsi ()
| » | Dnsmasq problemOddelek: Omrežja in internet | 1500 (1127) | BlaY0 |
| » | Linux Ubuntu - kako ustvarim bližnjico, kako naložim Flash?Oddelek: Operacijski sistemi | 1504 (1290) | SkyEye90 |
| » | Linux Synaptics touchpad driverjiOddelek: Operacijski sistemi | 1541 (1418) | preem |
| » | Gentoo - problemi z framebuffer in ifconfig (strani: 1 2 )Oddelek: Operacijski sistemi | 6246 (5570) | Zaibatsu |
| » | IPv6 on Linux RH9Oddelek: Omrežja in internet | 2749 (2298) | Gandalfar |
