Forum » Pomoč in nasveti » drivers audigy player full instalation
DocRob ::
Pozdravljeni! Podrobno sem si prebral litanije kako si ne znamo poiskati gonilnikov vendar moj audigy se vedno ne dela. Kupil sem si kartico, na zalost brez cd-ja ki se sedaj
že en mesec praši
na polici namesto da bi se grela v computru. Na žalost na natu ne najdem driverjev, največ kar sem si presnel je upgrade. Če ima kdo link mu bom neskončno hvaležen, pripravljen pa sem tudi kupit cd z driverji. Hvala lepa. Docrob@email.si
že en mesec praši
McNato ::
Download od Compaqa
Unpack the apps and driver with WinZip, WinRAR or any other unziping tool you have to a new folder
ocen that done you need to del the CTOem.cfg which in the folder called ?:\Audio\Setup\ now your ready.
Uninstall the previous package from the Add/Remove Programs now it take a few reboot doing this from
Add/Remove Programs ocen that done and what ever you do, do not canel hardware wizard let find
nothing then install the new package.
| » | OC GURU bios updateOddelek: Pomoč in nasveti | 2761 (2628) | 4ever |
| » | Zvočna ne dela na XP-jihOddelek: Pomoč in nasveti | 1537 (1485) | mitja01 |
| » | Logitech MouseWare bug (?)Oddelek: Pomoč in nasveti | 2602 (2198) | Swiwer |
| » | Win XP - messengerOddelek: Programska oprema | 1591 (1443) | IgiS |
| » | RA2 preko dveh modemov?!Oddelek: Igre | 1795 (1690) | bastadu |
