Sandy bridge
Sandy bridge
15 / 19
Evo cist en hiter test med PCIe x16 in x8, Crysis. Vse nastavitve enake, razlika samo v PCIe sirini.
TimeDemo Play Started , (Total Frames: 2000, Recorded Time: 111.86s)
!TimeDemo Run 0 Finished.
Play Time: 40.88s, Average FPS: 48.93
Min FPS: 31.92 at frame 1953, Max FPS: 63.69 at frame 1003
Average Tri/Sec: -46291320, Tri/Frame: -946097
Recorded/Played Tris ratio: -0.97
!TimeDemo Run 1 Finished.
Play Time: 38.04s, Average FPS: 52.58
Min FPS: 31.92 at frame 1953, Max FPS: 65.99 at frame 126
Average Tri/Sec: -49145336, Tri/Frame: -934624
Recorded/Played Tris ratio: -0.98
!TimeDemo Run 2 Finished.
Play Time: 37.93s, Average FPS: 52.72
Min FPS: 31.92 at frame 1953, Max FPS: 70.00 at frame 73
Average Tri/Sec: -49239760, Tri/Frame: -933925
!TimeDemo Run 3 Finished.
Play Time: 37.93s, Average FPS: 52.73
Average Tri/Sec: -49301380, Tri/Frame: -935005
TimeDemo Play Ended, (4 Runs Performed)
Play Time: 41.76s, Average FPS: 47.89
Min FPS: 12.85 at frame 172, Max FPS: 61.70 at frame 125
Average Tri/Sec: -45297092, Tri/Frame: -945871
Play Time: 38.26s, Average FPS: 52.27
Min FPS: 12.85 at frame 172, Max FPS: 63.93 at frame 125
Average Tri/Sec: -48836004, Tri/Frame: -934308
Play Time: 38.21s, Average FPS: 52.34
Min FPS: 12.85 at frame 172, Max FPS: 64.47 at frame 125
Average Tri/Sec: -48831856, Tri/Frame: -933026
Play Time: 38.16s, Average FPS: 52.40
Average Tri/Sec: -48988468, Tri/Frame: -934818
Zanimivo je, da je povprecje skoraj enako, ampak min pa max pa kar odstopata precej.
IvoJan ::
Dejansko je najboljse gledat min fps, tu pa je razlika kar opazna.
MajstrZvasi ::
Jaz furam gtx480 v drugem pcie slotu na x8 2.0 če ima še kdo 480 lahko narediva 3dmark11 ki je res noro zahteven pa se vidi koliko je razlike v GPU scoru.
Zanimivo da so min fpsji toliko manjši.
Pjača je kurba kurbe mamo pa rad.
Tilen ::
Lahko, da je bil le en spike. Naredi 3 teste, če imaš čas.
IvoJan ::
Spike pri istem fremu pri treh ponovitvah? I dont think so
Tilen ::
Se pardoniram. Nisem pozorno pogledal testov. :8) Dejstvo je, da če bi pogosto prihajalo do tako velikih dropov bi bil average nižji.
  • spremenil: Tilen ()
galu ::
Tisri ko mate x8 mode, probajte malce zvišat frek. vodila (iz 100MHz, na npr. 110-115MHz) in če gre, za malenkost višat voltažo. Bi blo zanimivo videt, kaj bi naredil OC-jan x8 slot proti x16 :)
Tako to gre.
bender123 ::
Pozdravljeni, mene pa zanima, če je že kdo imel težave z praksi DMR oz. anti piracy modulom,
nikjer nism zasledil kaj v praksi točno sploh ta DMR pomeni, zanima me namrec zato,
ker kupujem i7 2600K, se pa med drugim okvarjam z video editingom....
Hvala za odgovor,
PNG ::
To je samo zaščita proti piratiziranju video vsebine, ki si jo ti IZPOSODIŠ preko spleta, kar v Sloveniji sploh nimamo.
GrimReaper ::
Zdej pa bodo počas še ASUS plate:
http://pricaraj.si/si/page/detail/gitm/...
kmetek ::
AVTERA ima vse že na zalogi.
IvoJan ::
Avtera je draga :)
klinker ::
kmetek ::
mamo mi dobre cene ;)
barakus ::
Pismo so drage te palte :/
V AT pa 153EUR... :|
klinker ::
Dr_M je izjavil:
Jps...se splaca organizirat kake skupinske nakupe tu na forumu, se sigurno vedno kdo najde.
kmetek ::
Za 30EUR razlike se pa res ne splača, četudi je pttja recimo 5EUR po osebi je to skoraj 160EUR in razlika pade na dobrih 20EUR, ne hvala....za garancijo pa potem na lastne stroške gor pošiljat.
Pač večji trg a ne, 4x večji....
klinker ::
Za eno komponento se strinjam...ce pa narocis vecino sistema se pa kar pozna na koncni ceni.
kmetek ::
True.
Katero matično je že en tukaj zelo hvalil iz hoh.de?
klinker ::
sabertooth :D
kmetek ::
GrimReaper je izjavil:
Če grem primerjat PRO/Sabertooth/Deluxe.
Prednosti PRO napram Sabertooth:
-Bluetooth
-12+2 faz
-USB 3.0 bracket, škoda sicer ker ni za spredaj, kar bo problem ko pridejo USB 3.0 ključi, ampak se da modificirat da daš na ploščico kjer pride disketnik
-2x PCI, če imaš recimo PCI brezžično mrežno in zvočno kar pride prav. Je pa nasploh boljši razpored rež, kar se mene tiče že kar idealni.
Za Sabertooth je že zgoraj napisano, v glavnem so to termalni senzorji in Thermal Armor, MemOK! in Anti Surge ma tut PRO.
Minus je 8+2 faz, kolk se to v praksi pozna sicer ne morm rečt.
Deluxe je IMO najboljša, ampak zarad visoke cene pomoje ne bo tolk popularna.
Prednosti:
-boljše hlajenje napajalnega dela z dodatnim hladilnikom povezanim s heatpipom
-LAN2, Realtek
-Realtek ALC889 zvočna, če je kej boljša od 892 sicer ne vem
-16+2 faz
-ASUS Q-Code (numerični prikaz napak)
-CMOS Switch na backpanelu
-Power-on switch
-Reset switch
-6 SATA kablov, ostale imajo 4
-Front Panel USB 3.0 Box
Imaš pa potem še EVO, ki ima kar nekaj od tega kar ima Deluxe.
Imajo pa vse plate Q-Slot, Q-DIMM in Q-LED, prvi dve sta v bistvu samo izboljšavi za čim lažjo menjavo grafičnih kartic in ramov, Q-LED so pa 4 ledice da lahko takoj vidiš katera komponenta je problematična.
Q-Slot
Q-DIMM
Q-LED
lep opis, katera 1155 ima sploh PCIE 2X16 ?
Polne hitrosti Gigabyte GA-P67A-UD7, ASUS Maximus IV Extreme in ASUS P8P67 WS Revolution.
kmetek ::
uf 250EUR + :P
klinker ::
Maximus: 4 x PCIe 2.0 x16 (single @x16, dual @x8, triple @x8, x16, x16 )
Revolution: 2 x PCIe 2.0 x16 (@ x16 or x8), 2 x PCIe 2.0 x16 (@ x8)
Sabertooth: 2 x PCIe 2.0 x16 (single at x16 or dual at x8/x8 mode)
UD7:
1. 2 x PCI Express x16 slots, running at x16 (PCIEX16_1, PCIEX16_2)
* For optimum performance, if only one PCI Express graphics card is to be installed, be sure to install it in the PCIEX16_1 slot; if you are installing two PCI Express graphics cards, it is recommended that you install them in the PCIEX16_1 and PCIEX16_2 slots.
2. 2 x PCI Express x16 slots, running at x8 (PCIEX8_1, PCIEX8_2)
* The PCIEX8_1 slot shares bandwidth with the PCIEX16_1 slot and the PCIEX8_2 slot with PCIEX16_2. The PCIEX16_1/PCIEX16_2 slot will operate at up to x8 mode when the PCIEX8_1/PCIEX8_2 is populated.
  • spremenilo: klinker ()
MajstrZvasi ::
Jaz sem danes dobil v roke 2500k. Zaenkrat nimam pojma kako tole deluje s turbotom itd samo v biosu sem prestavil na performance ASUS EZ MODE in cpuz mi kaže 4ghz. Zdej nevem ali to samo eno jedro laufa na toliko ali vsa kako je to kdo ve povedat? Plata je http://www.asus.com/product.aspx?P_ID=Q... Vse druge nastavitve v biosu so avto. Slikca cpuZ
M-XXXX ::
Vsa
detroit ::
Kaj imaš pa to za eno cpu pahljačo?
Skero
MajstrZvasi ::
Drugače računalnik ni moj je pa v naši hiši jas imam še vedno dobrega starega q9450.
Hlajen je s temle http://www.mimovrste.com/artikel/220002...
Jaz sem hotel hladilnik s simpl montažo pa sem ga potem dobesedno najebal s tem Scythe Ninja 3.
Sicer ne paše to v to temo ampak če se slučajno kdo loti montirat tale hladilnik mu dam en zelo dobrodošel nasvet ker dugače si lahko vse lase populiš z glave. Govorim za podnožje 1155, 1156 Greš v trgovino s šraubi in vzameš 4 šraube fi5 približno 4cm dolge in po celi dolžini navoj nato še 4 matice fi5 in magari nekaj podložk montaža preprosta ko keks. Če pa se lotiš s tistim kar dobiš zraven moraš bit res ninja da ti uspe.
detroit ::
a zato tak ima ninja edition. Pač vsak ne more tega če si pa 30let v japanu pa nindža po rodu pa np:D
Skero
MajstrZvasi ::
U napaka 4 matice so še za ninje rabiš jih minimalno 8. Se oproščam. Drugače mi je pa zanimivo pri sandy bridge kako preprosto je navijanje res vsak amater ki ima 2minute časa se lahko poloti. Pač nastaviš množilnik in frekvenco ramov ki jo želiš vse pustiš na avto in stvar se sama navija najhuje od vsega je da teče pri 1600mhz pri majhni voltaži in se nato ob obremenitvi frekvenca poviša a ne tudi voltaža ta se povečuje skladno s obremenitvijo procesorja tole so res poštimali v piko. Včasih smo se matrali z vodnim pa še potem se je vse grelo in cpu je letel veš čas na isti frekvenci sedaj se že kar samo vse rihta no vsaj tja do 4ghz kar sem probal za višje overclocke nevem a gre isto moram še probat ko bo čas.
detroit ::
še nisem navijal oz klikal gumbke.. Mi vse dela na super high ok lažem dragon age ta nov mi na super high dela shitty, na high pa VSE do konca ostalo pa lajk 100 fps....mogoče res margarine zmanjkuje grafični pri 1gb...
Skero
MajstrZvasi ::
Sem si danes vzel čas in poiskal še udobno frekvenco in voltažo za 24/7. Sandy bridge je res fletna stvarca hiter hladen in malo štroma porabi.
Idino ena reč me malo moti, če ve kdo za rešitev bi bil zelo hvaležen. Namreč asuska p8p67 mi teži za ram 1.65v 1600mhz računalnik laufa in ekran je mrtev niti v post ne gre potem ga resetiram in ob zagonu računalnika napiše overclocking failed potem ga moram ponovno resetirat in rač dela normalno ram 1600mhz tudi potestiral sem ga z prime95 intelburn testom memtestom vse deluje brezhibno stabilno. Računalnik lahko tudi resetiram nobenega problema ta težava se pojavi samo če ga ugasnem in potem ponovno prižgem. Poizkusil sem s posodobitvijo biosa in ne pomaga. Škoda mi je da bi ram delal na 1333mhz če komot na 1600mhz.
  • zavaroval slike: kuglvinkl ()
GrimReaper ::
Kaj je zdej z menjavo plat, je že kdo dobil B3 ploščo? Sam čakam da jih Mlacom dobi, ne vem kaj čakajo, ker ostali jih majo že več kot en teden.
Cico ::
Tudi jaz čakam na zamenjavo pri Mlacomu in pravijo, da čakajo na pošiljko iz tujine, ker je tam daljša garancija. Boli me garancija, hočem plato...
Plata gre k vragom:
Cico je izjavil:
Boli me plata, hočem garancijo...
Fixed 8-)
J-ronimo ::
Se kr pridružujem čakalni vrsti za menjavo plate pri Mlacomu.
Cico ::
D3m je izjavil:
Plata gre k vragom:
Cico je izjavil:
Fixed 8-)
Če bom v takem ciklusu menjal plate, kot sedaj, na 4 mesece, potem garancije ne nucam večje kot 2 leti, a ne?
Sej, če jih vzamejo pri našem dobavitelju plošč, nekaj garancije pa je... Še dobro, da računalnika ne potrebujem pod nujno!
st0jko ::
Jaz sem pri mylemon narocil in placal novo plato, ko prispe zamenjam in pošljem staro nazaj. Dobim vrnjen denar. Tako dobim novo plato in nisem brez računalnika 1teden+. win-win.
keks?
TeraTM ::
kupil deluxe pri dinokompu, in vidim da jih že imajo... butasto se mi pa zdi, da je potrebno čakati da un pošlje v tujino, tam pa nazaj B3 verzijo. Naj mi da iz svoje trgovine, pa to jaz njim, in naj potem oni čakajo na novo...
PNG ::
TeraTM - samo da tega nihče ne prakticira...
TeraTM ::
ja vem..:P
feedback03 ::
No, samo za info, kolikor sem zasledil v nemških & avstrijskih trgovinah bi naj v naslednjih 1-3 tednih v prodajo prišle plošče s Q67 čipovji =)
MajstrZvasi ::
A vam ni dost 4 x SATA 6.0Gb/s connectors.
GrimReaper ::
Mlacom ima sedaj na strani ASUS plošče.
Cico ::
In na žalost v povprečju 20€ dražje kot pri dinocompu.
BALAST ::
Štajerci znajo hitro zrihtat, medtem ko so vse trgovince v Ljubljani omejene samo na 2 uvoznika.
GrimReaper ::
No pa je šel SATA2 kontroler, grem v BIOS, spremenim neko voltažo in pri zagonu sistema napiše BOOTMGR is missing, resetiram in vidim da ne zazna SSD-ja in optične enote ki sta na portih 1 in 2 (oz. 0 in 1), ugasnem, sprobam še porta 3 in 4, priklopim SSD na Marvell.
Tolko o treh letih.
Tilen ::
Jah, katero voltažo si pa spremenil?:)
Na 3,4 prav tako ni delovalo? Kakšnen je pa sedaj performance na Marvellu?
V treh letih obstaja 5% možnost. To tudi pomeni, da ti lahko prvi teden vse odpove. Si še vedno v teh 5%.
 EVIL!!!
EVIL!!!
Katero ploščo za i7 2600k?
253576 (2992) PNG
Gaming PC (strani: 1 2 )
5219356 (18205) Sharky
Nakup proc + matična + rami (strani: 1 2 )
7016149 (15215) mihco
Nov Računalnik 1155 Sandy Bridge (strani: 1 2 3 4 )
15933129 (30044) jazbec
Intelov Sandy Bridge je tu! (strani: 1 2 )
Oddelek: Novice / Procesorji
5113740 (10910) Tilen
