Forum » Operacijski sistemi » SuSe Linux + Win 7
SuSe Linux + Win 7
trulex ::
Na računalniku sem imel naložen že suse linux in kasneje naložil win 7 in tak je seveda zbrisal iz gruba možnost da bi bootu linux. Iz /boot/grub/menu.lst sem v program EasyBCD pod možnost neogrub v nastavitve skopiral vsebino datoteke in ko hočem zagnat mi napiše "try hd(0,0): EXT2: " in ne morem nič drugega kot ugasniti računalnik.
Datoteka menu.lst
Winsi so na C, na H so podatki, ostali trije so od linuxa.
Datoteka menu.lst
# NeoSmart NeoGrub Bootloader Configuration File
# This is the NeoGrub configuration file, and should be located at C:\NST\menu.lst
# Please see the EasyBCD Documentation for information on how to create/modify entries:
# http://neosmart.net/wiki/display/EBCD/
# Modified by YaST2. Last modification on Fri Oct 15 21:32:56 CEST 2010
timeout 10
gfxmenu (hd0,0)/boot/message
default 0
###Don't change this comment - YaST2 identifier: Original name: linux###
title SUSE Linux Enterprise Desktop 11 SP1 - 2.6.32.23-0.3
root (hd0,0)
kernel /boot/vmlinuz-2.6.32.23-0.3-pae root=/dev/disk/by-id/ata-SAMSUNG_HM641JI_S25YJ1MZ800594-part1 root=/dev/disk/by-id/ata-SAMSUNG_HM641JI_S25YJ1MZ800594-part1 splash=silent resume=/dev/disk/by-id/ata-SAMSUNG_HM641JI_S25YJ1MZ800594-part2 LOCAL_BOOT=yes acpi_osi="!Windows 2009" showopts vga=0x314
initrd /boot/initrd-2.6.32.23-0.3-pae
###Don't change this comment - YaST2 identifier: Original name: failsafe###
title Failsafe -- SUSE Linux Enterprise Desktop 11 SP1 - 2.6.32.23-0.3
root (hd0,0)
kernel /boot/vmlinuz-2.6.32.23-0.3-pae root=/dev/disk/by-id/ata-SAMSUNG_HM641JI_S25YJ1MZ800594-part1 root=/dev/disk/by-id/ata-SAMSUNG_HM641JI_S25YJ1MZ800594-part1 splash=silent resume=/dev/disk/by-id/ata-SAMSUNG_HM641JI_S25YJ1MZ800594-part2 LOCAL_BOOT=yes showopts ide=nodma apm=off acpi=off noresumeselinux=0 nosmp noapic maxcpus=0 edd=off vga=0x314
title Recovery
rootnoverify (hd0,2)
chainloader +1Winsi so na C, na H so podatki, ostali trije so od linuxa.
- zavaroval slike: bluefish ()
Bug ::
ellow
Uporabi Live Ubuntu CD, potem pa:
lp,
bug
sudo su apt-get install grub grub root (hd0, 7) //če je /boot particija /dev/sda8 setup (hd0) quit reboot
lp,
bug
Before you speak, ask yourself:
Is it kind, is it necessary, is it true, does it improve the silence?
- spremenil: Bug ()
trulex ::
Hvala razsvetli me še zakaj uporabim ubuntu cd in komando root (hd0, 7) (preden začnem delat)?
jinzo ::
Ubuntu pač kot ena izmed možnosti, vsak LiveCD bo deloval.
root(hd0,7) določi root/osnovno particijo na katero se naj nastavi grub (/boot) particija.
| » | dual boot xp/ubuntuOddelek: Operacijski sistemi | 2271 (2152) | misek |
| » | Kako instalirati Linux in xp?Oddelek: Operacijski sistemi | 2699 (2620) | Blinder |
| » | gnu grubOddelek: Operacijski sistemi | 1582 (1535) | Loaded |
| » | Multi-boot problemOddelek: Operacijski sistemi | 1702 (1617) | CCfly |
| » | Suse 9.0 (strani: 1 2 )Oddelek: Operacijski sistemi | 6330 (5616) | moj_nick |
