Laserski tiskalnik
Laserski tiskalnik
cvetkob ::
Dober večer,
nujno bi potreboval pomoč, pri laserskem tiskalniku.
Imam naslednji problem:
ko printam mi čez list sprinta 4 črne črte vodoravno, menjal sem toner, kaj bi bilo lahko narobe?
Se da kje toner oprati (tako kot pri kartušah?), nikjer nisem najdel nobene rešitve, prosim za njo, saj bi si nujno mogel sprintati dosti listov.
Imam pa Xerox phaser 3117.
Gapi ::
razvijalna enota je čista ??
No person is rich enough,to buy back his past.
bobby ::
kakšno sliko lahko dodaš?
razvijalna enota se pri tem modelu menja skupaj s tonerjem.
Bias ::
- imaš kompatibilen toner?
- so črte črne ali pušča prazno/belo sled?
- oprati se definitivno ne da!!!
cvetkob ::
 slika 1
slika 1
 slika 2
slika 2
črte so vidne 4 so čez cel list (list sta obe sliki skupaj)
  • spremenil: cvetkob ()
Symptom: horizontal streaks on the page. If you see a regular horizontal line on your output, it's probably caused by an irregularity in one of the many rollers that the paper must pass by on its journey from the paper cartridge to the output bin.
To identify the roller, you'll need to measure the distance between the lines. If the horizontal lines are always spaced the same distance apart, then that distance is the circumference of the bad roller.
Use the following numbers as a handy-dandy key. Just measure the distance between the regular horizontal lines with a ruler, and then read off the name of the bad roller. Whether or not you want to try to replace the problem child is up to you; getting to some of those rollers is a bit hairy. In my experience, however, the most common distance is 3.75 inches: the circumference of the photosensitive drum.
cvetkob ::
predlog?
Zamenjava tonerja?
Aja hvala Okapi
Bo palček Xerox uspešno prevzel velikana HP inc.?
4914927 (12354) MrStein
laserski printer "paca"
132109 (1780) [D]emon
tp-link TL-WA730RE kot Wireless Range Extender
Oddelek: Omrežja in internet
315990 (4671) Mikec17
Glasbeni izrazi v angleščini
Oddelek: Sedem umetnosti
177347 (6961) embe
invertiran zvok
232537 (2144) CaqKa
