Nokia e63 odštevalnik časa
zerdoner ::
Živjo...
Zanima me če se da dobiti za omenjeni telefon kakšen program, da bi imel gor odštevalnik časa?
denabiker ::
ena od mnogih:
HANDY CLOCK
Application features:
World clock view to check the time in five world cities at once.
Day-night map reflects what part of the day is in the city you need.
Alarms view to set up different alarms: once, next 24 hours, daily, weekly, and workdays.
Timer helps you to do something within a certain period of time.
Stopwatch to measure the time interval and notes the result.
Time log tracks the project's time even if Handy Clock is not running. Export Time report to Microsoft Excel is also available.
Calendar view to see 2 months at the moment
Calendar screensaver
zerdoner ::
Sem si naložu in je super zadeva...vendar imam samo poskusno 14dnebvno različico...ima mogoče kdo kakšen crack ali serijsko
denabiker ::
saj imaš tudi takšne timerje free, poišči na google, ali pa si dol potegni magari eggtimer, ki je tudi free. nastaviš čas in ti odšteva...
na ovi poglej, tam je tudi precej programov free
poglej tule še:
http://www.symbian-freeware.com/
http://www.symbian-freeware.com/tag-tim...
Free CAD programi
Oddelek: Programska oprema
4012995 (2799) d4vid
Samoa in Tokelau preskočila 30. december (strani: 1 2 )
5119930 (11716) manishasingh
Applove budilke ob premiku ure spet zvonile napak (strani: 1 2 )
9728325 (25639) Aston_11
Nokia N95 8GB rotateMe
Oddelek: Mobilne tehnologije
151574 (1338) js osebno
James bond 007 - podnapisi za vseh 20 filmov
203548 (3238) ferdo
