Severna Koreja grozi z jedrskim orožjem
18 / 40
Pa si mi vzel ves veselje:D
  • spremenil: Gregor P ()
Dober intervju.
http://www.vox.com/2016/9/9/12863700/no...
)...)To find out, I got in touch with Jeffrey Lewis, director of the East Asia Nonproliferation Program at the Middlebury Institute of International Studies at Monterey. Lewis is an honest-to-goodness expert on North Korea’s nuclear program, so what he has to say carries real weight.
They’re trying to imagine this era where they can use nuclear weapons early regionally, and we’re going to be like, "We’ve got to stop, because otherwise LA is going to be next." So if we can head off the ICBM program, then things are going to be a lot more stable.
People hope that you’re going to be able to use sanctions to put political pressure on a government. But, hey, we’ve tried that with North Korea, and that’s not worked.
So what we’re left with is to negotiate. And that’s hard, because they’re unpleasant — an ugly, ugly, ugly government. Nobody wants to sit down to a state dinner with Kim Jong Un while people in North Korea are starving. But the reality is that there’s not any other way to get them to not build this stuff other than to persuade them not to.
And this is a huge problem: The North Koreans have always been super clear that they’re willing to trade away stuff that they haven’t done yet for promises of a better relationship, but they’re not willing to trade away stuff that they have done.
So 20 years ago, when we were talking with them about a missile deal — that was a great deal. They’d built hardly any of these things, so locking them in place — even though we couldn’t get rid of the last few missiles — would have been amazing.
But we were, like, total dicks about it. We were like, "No, no, it has to be everything." And they said, "Okay, we’ll build some more stuff."
Making a deal with North Korea is going to require accepting that they have a certain amount of nuclear capability that will threaten South Korea and Japan. That will be a political nightmare. Think about how bad the Iran debate was, and now try to imagine cutting a deal in which Kim Jong Un gets to keep his nuclear weapons.
Južna Koreja je zamenjala ploščo, po novem obljubljajo, da bodo Pjongjang zravnali z zemljo, če si bo Severna Koreja upala preveč.
http://www.bbc.com/news/world-asia-3733...
Ali bo to imelo kakšen rezultat ali ne še ni jasno, ampak gotovo je, da je sprememba pristopa edina logična zadeva. Pristopi z izboljšanjem vezi, gospodarskim sodelovanjem in pomočjo režimu niso delovali, zato je smiselno poskusiti še kaj takega. Mogoče jih bo streznilo, situacije pa tako ali tako ne more poslabšati.
Dvomim da bo to pomagalo. Sistem ima trdno vajeti v svojih rokah. Dokler se ne bo vojska uprla, bo tako. Ampak vojska se ne bo uprla, ker imajo ključni ljudje oprane možgane in privilegije ter se zavedajo, da v drugem sistemu lahko te privilegije zgubijo.
Edino kar še preostane je upor ljudstva, kar pa zna biti zelo krvavo.
Te grožnje J Koreje pomagajo utrjevati oblast S Koreje, ker imajo oblastniki še dodatno potrditev za strašenje ljudstva pred zunanjim sovražnikom. Čeprav je pa vprašanje, koliko pravih info. pride do ljudi.
Prave informacije znajo tu režimu prej škoditi. Severnokorejska vojska ni sposobna furati vojne več kot 2-3 dni, potem obstane zaradi pomanjkanja goriva in rezervnih delov.
poweroff ::
Kar pomeni, da so lahko še bolj odločeni jedrsko orožje uporabiti.
sudo poweroff
poweroff je izjavil:
Jedrsko orožje jim lahko pomaga samo čisto na začetku. V prvih 24 urah (morda še prej) bo južnokorejsko letalstvo, s podporo USAF, že stolklo vse, kar v Severni Koreji spominja na raketo ali raketno izstrelišče. Neumni pač niso ane.
Saj zato pa pravim, koliko pravih info pride do ljudi. Ker režim servira cenzurirane, prilagojene info.
Sem pred nekaj časa gledal dokumentarec, kjer bivši S korejec "izvaža" radijske sprejemnike v S Korejo, da bi ljudje pri poslušanju tujih radijskih programov prišli do pravih info.
Močno dvomim, da bo prišlo do neposrednega spopada, predvsem s strani J Koreje. Gre pač za napenjanje mišic.
Moč S Korejske vojske je v številčnosti vojakov in opreme, vprašanje je pa usposobljenost. Kljub temu pa so zmožni narediti kar nekaj škode, ker se vedno najde nekaj "naspidiranih" junakov, kateri imejo poleg tega še nekaj sreče.
ziga1990 ::
^^Že samo nobena stran ni toliko neumna:
-Severna Koreja ima jedrsko orožje samo zato, da Južno sosedo in zaveznike prestraši in poskrbi, da nebojo kaj poskušali narediti.
-Južna Koreja pa ni toliko neumna, da bi udarila prva, ker ko je Severno Korejska vojska uničena imajo prevelik problem kaj narediti z njo jo pustiti pri miru ali se združiti
ziga1990 je izjavil:
Tako, ja. Glavna obramba Severne Koreje ni jedrsko orožje in ni njihova armada, temveč na desetine milijonov sestradanih beguncev - Sirija x3 in Južna Koreja mora to urediti večvidel sama.
  • spremenil: Smrekar1 ()
papasmrk ::
Pa saj ni nujno, da se S. Koreja združi z J. Korejo. Lahko bi z vojaško intervencijo uničili vodstvo in potem bi uvideli, da je mali debelinko navaden človek, ki lula, kaka in tudi krvavi. Si pa ne predstavljam kakšno bi bilo stanje v S. Koreji, če bi kači odrezali glavo... Pa tudi kakšne vojaške baze pod USA poveljstvom bi razpizdile Kitajsko.
ziga1990 ::
Smrekar1 je izjavil:
dodaj še to da imajo skoraj vsi Severno Korejci oprane možgane.
  • spremenilo: ziga1990 ()
Saj, zato Sirija x3. Tudi v takem primeru bi videli teroriste in samomorilce med hordami. Večina bi bila sicer zadovoljna z nekaj hrane in streho nad glavo, tako da večina ne bi bila problem, bi bilo pa med njimi proporcionalno približno toliko teroristov kot jih je med begunci in migranti iz Sirije.
papasmrk je izjavil:
Problem je v tem, da imaš elito, ki živi od režima in ga ne bi hotela uničiti. Ta elita ima pod sabo tudi vojsko, ki je vsaj v določenem delu namenjena zatiranju uporov. Tudi če ti uspe to uničiti (pričakuj >100 000 mrtvih) ti še vedno ostane razbita, izčrpana, nerazvita in hudičevo nestabilna država. Hitro bi dobili novo Somalijo.
Starodavni ::
oh ja, sam da bi bila ta država še hujši problem, ker se nahaja med Kitajsko in J. Korejo, gvišno bi morale številne države intervenirati, da bi tole državo S. Korejo kolikor toliko stabilizirali.
Samo eno je pa jasno, do Reunifikacije ne sme priti in nikoli je ne bo, ker so razlike med obema korejama enostavno prevelike in je bolje, da ostaneta državi ločeni.
Primer nemške reunifikacije je bil dovolj zgovorna svarilna zgodba, pa so bile tu ekonomske razlike mogoče 10 kratnik bolj razvite države, v primeru obeh korej pa je tu vsaj 42 kratnik razlike. Nepremostljiva ovira.
Jaz bi raje videl, da bi S. Koreja ubrala kitajski model razvoja, kar bi pomenilo mehkejši režim in večjo ekonomsko odprtost ter vlaganje.
SAmo to tudi pomeni, da bi ljudje dobili dostop do številnih informacij, ki jih zaradi te izolacije nimajo in bi ta režim, tudi če bi postal mehak hitro spodneslo stran.
Še bo zanimiv razvoj dogodkov v S. Koreji v bližnji in daljni prihodnosti.
maco-maco ::
Kaj?
Samuel ::
noticably not worth noticing.
  • spremenil: Samuel ()
Samuel je izjavil:
Evidentno se nekaj kuha.
Kitajska je poslala 150 tisoč vojakov na mejo s Severno Korejo.
Američani pošiljajo okrepitve.
Severna Koreja se pa v svojem svetu pripravlja nov jedrski poizkus.
Kaj se kuha..a Severna Koreja morda ne sme izvajati jedrskih poskusov na svojem ozemlju?
dice7 ::
Tista ameriska letalonosilka je menda rutinska plovba.
ziga1990 ::
dice7 je izjavil:
niti ne baje da so letalonosilko preusmerili naj gre proti korejskem polotoku
dice7 ::
http://www.c7f.navy.mil/Media/News/Disp...
Pravijo da so imeli neke rutinske operacije v kitajskem morju nakar so sli v juzno korejo, verjetno po zaloge
konspirator ::
Nekaj takega so govorili tudi par dni preden so napadli Irak 2003.
mislim, da bodo, če planirajo kakšen napad bodo še počakali, da n korea pokaže kakšen icbm.
  • spremenil: mtosev ()
Samuel ::
Severna Koreja redno pošilja preko Japonske svoje izstrelke. Ker, pač, zakaj pa ne.
Počasi prihaja čas, da se odstrani vodstvo Severne Koreje, potem pa jo naj Kitajska postavi nazaj na noge.
dvomim, da bo kaj šlo. kitajska noče par miljonov beguncov da pride iz koreje na kitajsko. so proti temu.
WarpedGone ::
Po moje bo ZDA izvedla hitro deratizacijo, nato pa bo kitajska okupirala in de-fakto aneksirala S korejo.
Done.
Zbogom in hvala za vse ribe
Samuel ::
mtosev je izjavil:
saj zato pa imajo tistih 150k vojakov na svoji meji.. da nihče ne pride na kitajsko stran
Samuel je izjavil:
In? Če ICBM (in tukaj gre za ICBM brez bojne glave) leti nad višino nacionalnega zračnega prostora ali pade v mednarodne vode je vse skladno z mednarodnim pravom pa magari se Američani in Japonci mečejo na trepalnice. Če pa to nekdo smatra za grožnjo potem so ZDA zadnje, ki lahko komu solijo pamet, saj s svojimi vojaškimi ladjami in letali redno paradirajo okrog držav, ki jim to ni všeč.
ziga1990 ::
Hehe baje, da je jedrska bomba že v tunelu samo še vprašanje časa kdaj bo počilo trenutno se predvideva da bo počilo v soboto.
Jaz pa mislim, da ZDA in Južna koreja ne upata dejansko napasti Severne koreje in samo žugata z orožjem.
konspirator ::
Napasti v kakšnem smislu/obsegu ?
Shitload BGM-109 / GBU-43/B / AGM-158, b52 masovno bombardiranje, invazija iz morja (preko dmz bi šlo težko, iz Kitajske itak da ne) , emp/nukice na Pjongjang/ostala relevantna mesta ?
počaki, da naredijo icmb z nuke warheadom. tedaj bi jaz tudi napado. da bi oni norec imel icmb je nedopustno.
WarpedGone ::
Napadit je nujno, še preden norec pride do NICMB.
Ampak stvari se da ohladit tudi na klasičen način ... afganistan je ravnokar spoznal mamo vseh bomb:
mtosev je izjavil:
Ti ne veš, da si živ..kaj šele, da bi kakšni državi solil pamet ali sme imeti jedrsko orožje ali ne. Z drugimi besedami - govori zajec sovi, da ima velika ušesa 8-)
norci ala kim joung un nimajo kaj početi s jedrskim orožjem. dobro, da adolf nikoli ni prišo do takšnega orožja, ker sveta več ne bi bilo.
naj se on lepo igra s svojimi igračami. nukice niso za nestabilno psihično bolane ljudi kot je un.
zmaugy ::
@Fritz: a ni tukaj resolucija UN, ki prepoveduje S. Koreji razvijati balistične rakete in jedrsko orožje?
https://en.m.wikipedia.org/wiki/List_of...
Če bo kakšna ameriška akcija, potem bo verjetno šlo za zelo posebna precizna orožja ali celo za precizno uporabo jedrskega orožja.
  • spremenilo: zmaugy ()
ziga1990 ::
^^ kakšna akcija saj niso nori, če napadejo bo severna koreja odgovorila in bo grdo postalo
zmaugy ::
Če bo kakšna akcija, bo takšna, da S Koreja ne bo mogla več odgovoriti - razen konvencionalno.
Trump je omenjal podmornice v enem od zadnjih intervjujev glede S Koreje. Po mojem imajo Kitajci določen rok, do katerega se morajo hard ball zmeniti s S Korejo, po mojem je ta rok povezan s časom plovbe in razporeditve ameriške bojne skupine, ki gre tja.
loleki. Spet sanjate o jedrskih spopadih... Kitajska ne rabi ničesar od Amerike sprejeti. Amerika gre lahko samo iz globalnega trga in sporazuma ztao pa mate praktično 180 stopinski obrat vsega kar je Donald nakladal..
ziga1990 ::
saj konvencialno je hudič saj ima SK topništvo usmerjeno proti Seoul-u kjer živi cca 10 milijonov ljudi in ni možnosti da spraviš ljudi v zavetišča pred prvo pošiljko
me zanima s čem bodo odgovorili. amerika jih lahko v enemu tednu oneosposobi. tam ljudi umirajo od lakote. bi rad vido, da so se pripravljeni boriti za una.
Aston_11 ::
Ti je ziga odgovoril. Seul je (pre)blizu...
mtosev je izjavil:
amerika jih lahko v enemu tednu neosposobi.
Pravljice.
  • spremenil: Aston_11 ()
zmaugy ::
Kim bo izvedel jedrski poskus ob obletnici starega fotra. Donald bo spet šokiran. Za razliko od Sirije, Rusija v S Koreji nima osebja.
Trump je kontrol frik in misel, da bi en smešno postrižen smrkavc lahko v roku kakšnega leta metal rakete na ZDA, je prehuda zanj. Če ne bo šlo zlepa, bo šlo zgrda. In za Korejce ga po mojem Bk.
jest10 ::
mtosev je izjavil:
me zanima s čem bodo odgovorli. amerika jih lahko v enemu tednu neosposobi. tam ljudi umirajo od lakote. bi rad vido, da so se pripravljeni boriti za una.
Enem tednu? Uau ejga. S Koreji je dovolj nekaj ur, da sesuje Seul. Pa ne samo z granatmai, ampak tudi s kemičnimi pošiljkami.
Edina totalno nerealna opcija, da se to prepreči, je par nukic na mejo.
zmaugy je izjavil:
Ne, gre za resolucije, s katero se kaznuje S. Korejo zaradi jedrskih poskusov in poskusov z ICBM, saj ji izdelavo le teh ne morejo prepovedati, še posebej zato, ker je S. Koreja izstopila iz pogodbe o neširjenju jedrskega orožja. Zadeva je sporna še iz naslova tega, da isti vatli niso v veljavi za druge države - predvsem Izrael.
ZDA trenutno nimajo nobene podlage za napad na S. Korejo in če mislijo, da bo Kitajska to le gledala ob strani, se hudičevo motijo, ne glede na to, da je debelinko pain in the ass tudi zanje. O uporabi jedrskega orožja pa sploh ne bi govoril, saj lahko to potegne za seboj nepredvidljive posledice. Smisel jedrskega orožja je ravno v tem, da ga nikoli ne uporabiš, saj je preveč destruktivno, ob zadosti velikem arzenalu pa zagotavlja medsebojno uničenje.
In če smo že pri tem, komu bi zaupali jedrsko orožje...ali bi ga vi zaupali človeku, ki ne ve zakaj ima njegova država drugi največji jedrski arzenal na planetu in sprašuje svetovalce zakaj za vraga ima zelo drago jedrsko orožje, če ga 'ne more' uporabiti 8-)
jaz vem, da rusi in tud nor trump ne bodo prvi uporabili nukice. un pa je dovolj nor, da mu tudi to hodi po glavi. zlo nevarno.
mtosev je izjavil:
Dobro, da ravno ti veš. Ker po tvojem pisanju človek ne more ugotoviti a si star 12 let ali se le tako 'preprost'.
Sicer je pa Bukowskijev Čarli svoje dni ugotovil naslednje:
"The problem with the world is that the intelligent people are full of doubts, while the stupid ones are full of confidence."
  • spremenilo: Fritz ()
WarpedGone ::
In ti si seveda poln dvomov.
Not.
imagodei ::
mtosev je izjavil:
Za koga pa so?
- Hoc est qui sumus -
zmaugy ::
"U.S. May Launch Strike If North Korea Reaches For Nuclear Trigger"
http://www.nbcnews.com/news/world/u-s-m...
Master_Yoda ::
The U.S. is prepared to launch a preemptive strike with conventional weapons against North Korea should officials become convinced that North Korea is about to follow through with a nuclear weapons test, multiple senior U.S. intelligence officials told NBC News.
Torej par ljudi mora biti "prepricanih" da bo Kim Jong Un izvedel test, in to bo dovolj za napad. Po moznosti isti folk, ki je bil preprican da ima Iraq orozje za mnozicno unicevanje ?
dice7 ::
Dovolj je ze da Ivanka kaksno solzico potoci
18 / 40
So Kim Jong Una pospravili? (strani: 1 2 )
Oddelek: Problemi človeštva
5623031 (16568) ADIJOOO
FBI: Imamo dokaze za vpletenost Severne Koreje v vdor v Sony
Oddelek: Novice / Varnost
3013484 (10966) srus
severna korea ''grozi'' z napadom na washington dc (strani: 1 2 3 )
12034371 (31851) Osprey
Poslovil se je Kim Jong Il (strani: 1 2 3 )
10626118 (22722) Double_J
Iran - naslednja tarča zahodnih imperialistov? (strani: 1 2 3 4 )
15555038 (52281) Mipe
