Ts in m2ts datoteke
Ts in m2ts datoteke
mariosala ::
Mene zanima kako spraviti več ts ali m2ts datotek v enem filmu spraviti v samo eno datoteko brez izgube kvalitete. Sem ze iskal po netu pa neuspesno ali je program placljiv ali pa ne podpira teh datotek. Rabim to zaradi gledanja preko predvajalnika in podnapisi(srt)delujejo samo pri eni datoteki.
  • polepsal: KoMar- ()
Desty ::
Skupaj lahko daš z Microsoft Windows Live Movie Maker. Vem, da tudi Premiere podpira te datoteke, samo če rabiš samo za to, se ne splača nameščat.
KoMar- ::
Desty, tip je napisal "brez izgube kvalitete", torej Movie Maker odpade.
20sdfj093f ::
TS = transport stream, in če pravilno razumem Marjo govori o remuxanju?
NazgulRR ::
MakeMKV?
MakeMKV is your one-click solution to convert video that you own into free and patents-unencumbered format that can be played everywhere. MakeMKV is a format converter, otherwise called "transcoder". It converts the video clips from proprietary (and usually encrypted) disc into a set of MKV files, preserving most information but not changing it in any way. The MKV format can store multiple video/audio tracks with all meta-information and preserve chapters. There are many players that can play MKV files nearly on all platforms, and there are tools to convert MKV files to many formats, including DVD and Blu-ray discs.
http://www.makemkv.com/
DVD predvajalnik z mkv podporo?
223621 (3437) floyd1
Blue-Ray predvajalnik LG BD390, BD 570, BD590
204425 (3213) bogdanv
Katere programe bi moral imeti vsak uporabnik računalnika?
204522 (3784) energetik
dvd v mkv - kateri program?
Oddelek: Zvok in slika
123608 (2625) papasmrk
Kako konvertati mkv v bluray?
62314 (2101) naret
