Forum » Strojna oprema » celeron 2 stepping
celeron 2 stepping
matevzm ::
Potem pa tak vpasaj...
Celeroni 2 so bili do septembra cB0, potem pa cC0. Mislim, da drugega prej ni bilo.
RookY ::
Kje se vidi, kateri stepping ima procesor?
Samo po datumu proizvodnje, ali pa obstaja tudi kakšna oznaka na proc., oz. škatli od proca.?
Juhu juhu spet bom bruhu
matevzm ::
For desktop Celeron processors, the primary difference between the cB0 and the new cC0 stepping is a voltage change from 1.65v to 1.70v. A vast majority of mtherboards "auto-select" voltage and the processor will be run automatically at 1.70 volts. In cases where voltage selection is required, the processor should be set to 1.70 volts. Please note that the CPUID for the new cC0 stepping is 0686h and will require a new BIOS update, available from your motherboard manufacturer.
Brand & Core Speed Package Product Code cC0
MM# Initial S-Specs
Celeron™ Processor 700 MHz FC-PGA BX85026F700128
831581 S-L4P2
Celeron™ Processor 667 MHz FC-PGA BX85026F667128
831582 S-L4NZ
Celeron™ Processor 633 MHz FC-PGA BX85026 F633128
831583 S-L4NY
Celeron™ Processor 600 MHz FC-PGA BX80526F600128
831584 S-L4NX
Celeron™ Processor 566 MHz FC-PGA BX80526F566128
831175 S-L4NW
MM# Initial S-Specs
831581 S-L4P2
831582 S-L4NZ
831583 S-L4NY
831584 S-L4NX
831175 S-L4NW
MadMax ::
Kirga hudicha mam pa pol jaz??
827531 SL3W8 (C600@900, 1.5V@1.75V - lahko dela 2 setija pa se kak benchmark povrh, pa MP3 spilajo... pa se mi kar noce sesut
matevzm ::
Kateri stepping imas je preprosto ugotoviti. Eno je, da pogledas default voltazo procesorja. Za cB0 600 je bila 1.5V , pri novem steppingu je 1.70V. Drug nacij ne WCPUID, ki ti pove CPUID, ce je nov, je 0686h, za stare pa je 0683h. To je za 600Mhz, za 633 so cifre sledece: stari 1.65V, novi 1.70V. CPUID je isti pri 600 in 633.
luni ::
pa v par dneh sestavljanja kompov sem ugotovil se eno finto: cC0 celeroni (BOX verzije, OEMov v Jerovsku sploh nisem videl) imajo v vrecki eno nalepko, na kateri pac pise Intel Celeron pa to... pac da jo nalimas na racunalnik in pol vsi vejo kaj mas not... no, sej nalepko majo td drugi celeroni, ampak pri cC0 je zadeva na rjavem papirju, na cB0 pa na belem... sama nalepka je popolnoma enaka, le papir, na katerega je nalepljena je v enem primeru bel v enem pa rjav... ta metoda ugotavljanja je v mojem primeru drzala 100% (saj sem preveril se SSpec kode in voltazo), ampak kdo ve kdaj se bo Intel odlocil za spremembo barve papirja
Artificial Intelligentia
matevzm ::
Kot kaze je Intel precej strikten pri teh zadevah, v dokumentu o spremebah stepping je bilo tudi tole:
2. Boxed Processor Carton Material Change:
Beginning September 18, 2000, Intel will change the material used for all boxed processor cartons from 24-point to 20-point paperboard stock. The lighter weight carton material meets all Intel workmanship standards and is not expected to impact the carton’s functional or product protection characteristics. Additionally, the new carton material should result in reduced packaging waste. Please note that this change does not affect carton graphics.
Sicer ne spremljam natancno, a verjetno bodo najavili, ce bodo spreminjali pakiranje. Ce poznas pakiranje za cB0, potem ni panike.
| » | Intel Celeron II, 633 MHzOddelek: Pomoč in nasveti | 2801 (2542) | Spajky |
| » | Katera PIII dualproc plata?Oddelek: Kaj kupiti | 1680 (1401) | bastadu |
| » | celeron?!?Oddelek: Navijanje | 1813 (1630) | smash_u |
| » | Celeron2 600@900?Oddelek: Navijanje | 3092 (2487) | FireSnake |
| » | Alien-w, luni,Oddelek: Navijanje | 1826 (1622) | BlackAdder |
