Samomor?
Samomor?
Hux ::
Kaj menite je siol naredo samomor? Dans so mi dvignili na 1Mbit vceraj se vse vredu dans pa to.
C:\>ping -n 30 www.siol.net
Pinging hestija.siol.net [193.189.160.170] with 32 bytes of data:
Reply from 193.189.160.170: bytes=32 time=108ms TTL=126
Reply from 193.189.160.170: bytes=32 time=120ms TTL=126
Reply from 193.189.160.170: bytes=32 time=110ms TTL=126
Reply from 193.189.160.170: bytes=32 time=19ms TTL=126
Reply from 193.189.160.170: bytes=32 time=40ms TTL=126
Reply from 193.189.160.170: bytes=32 time=90ms TTL=126
Reply from 193.189.160.170: bytes=32 time=80ms TTL=126
Reply from 193.189.160.170: bytes=32 time=160ms TTL=126
Reply from 193.189.160.170: bytes=32 time=140ms TTL=126
Reply from 193.189.160.170: bytes=32 time=130ms TTL=126
Reply from 193.189.160.170: bytes=32 time=100ms TTL=126
Reply from 193.189.160.170: bytes=32 time=39ms TTL=126
Reply from 193.189.160.170: bytes=32 time=60ms TTL=126
Reply from 193.189.160.170: bytes=32 time=50ms TTL=126
Ping statistics for 193.189.160.170:
Packets: Sent = 30, Received = 30, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 19ms, Maximum = 160ms, Average = 97ms
R0K ::
Nisi edini. Poznam dva primera pri kterih je tut delal dan, dva pol pa ne več.
Hux ::
HEh kak mislis dan dva pol pa nic vec ?:D
Fora je da so nove igre izsle dans na crni sceni ne in zgleda da jih to dosti ve lol
C:\>ping -n 10 www.siol.net
Reply from 193.189.160.170: bytes=32 time=18ms TTL=126
Reply from 193.189.160.170: bytes=32 time=22ms TTL=126
Reply from 193.189.160.170: bytes=32 time=20ms TTL=126
Packets: Sent = 10, Received = 10, Lost = 0 (0% loss),
Minimum = 18ms, Maximum = 22ms, Average = 19ms
  • spremenilo: Hux ()
Hux ::
kolk tolk se normalizira zaj pri 100 poskusih.
Packets: Sent = 100, Received = 100, Lost = 0 (0% loss),
Minimum = 17ms, Maximum = 36ms, Average = 20ms
Hux ::
Ok zaj je spet vredo vse se bolse.
Reply from 193.189.160.170: bytes=32 time=17ms TTL=126
Minimum = 17ms, Maximum = 20ms, Average = 18ms
PaJo ::
Hux2> Kaj ti res nimas kaj bolj pametnega za pocet kod non-stop prverjat tvojo ADSL linijo ali kaj?? Namrec jaz mislim da ce bos en dan mel malo vecji ping pac ne bos umrl, ali pa da te v parih dneh ne bodo priklopli na boljsi link, bos verjetno tudi prezivel. Daj umiri se eno malenkost:D
Ne se preveč sekirat, rajši uživat:)
ABX ::
Fetish na ADSL?
Hux ::
heh pa ce je blo vse vredi z 512 pol pa me na 1Mbit dajo pa 100 pinge. Sem sel na siol CS server pin pinga 150 lol. To so bli ocitno porodni krci.
Preveliki pingi (strani: 1 2 )
Oddelek: Omrežja in internet
5212227 (11634) [L4M3RZ] - TinLaDeN
ADSL iz 512/128 na 1024/128 (strani: 1 2 3 4 … 10 11 12 13 )
60741183 (24265) RedOS
ADSL ping?
443764 (2778) zile
Pingi in ADSL
294635 (3997) matter
ADSL vs kabel
373190 (2409) Jinxy
