Forum » Pomoč in nasveti » garmin oz navigacija na Lg -ju
Alessio983 ::
hay
mene zanima če ima kdo LG telefon , in na njem garmin ali katerikoli drug gps ...
Namreč kupil semLG gc900 ki ima gps , samogarmina ne gre gor naložit
LuGi ::
Uporabljas lahko samo Google Maps... nažalost.
"LG Viewty Smart has a couple of shortcomings, which put off a lot of people. First of all, it comes with an older version of Google Maps, that can't use My Location service. Second, and most important, the new Google Maps and most of the Java software turned fully incompatible with the Arena's GPS."
User interface: S-Class Touch UI
No voice-guided GPS navigation software available
Na tega nebos spravil Garmina, iGo itd.. prodaj in kupi drugega če zelis uporabljati gps.
Puzo ::
Sej ima GPS neke vrste. A-GPS (Assisted GPS), kar pomeni, da ko zaženem google maps te najde kje si, pač ni tistega konstantnega premikanja kot "smo" navajeni pri Garminu in podobnih.
ASUS M2N-e | AMD Athlon 64 X2 6000+ Dual-Core
Crucial Ballistix DDR2-1000 | nVidia 8800GTS
| » | [android] aplikacija za GPS koordinateOddelek: Programska oprema | 5437 (3128) | otago |
| » | Avto brez navigacije (strani: 1 2 )Oddelek: Na cesti | 25111 (21453) | Mavrik |
| » | Nokia E66/E71 (strani: 1 2 )Oddelek: Mobilne tehnologije | 12937 (7120) | MrAs |
| » | GPS navigacija na računalnikuOddelek: Programska oprema | 2372 (2272) | St235 |
| » | Kateri mobitel z GPS in WLAN?Oddelek: Kaj kupiti | 3943 (3449) | dmk |
