Forum » Kaj kupiti » Silent gaming PC do 1500€
Stak ::
A kdo ve kaj je najbolje dati med vent in ohišje, ko ga privijačiš - guma silikon?
- spremenil: Stak ()
Pipi Castro ::
Evo dve konfiguraciji (AMD in INTEL):
AMD KONFIGURACIJA
NZXT Whisper PC Tower Case - black = 124.90 EUR
Corsair HX850W 850W PC Power Unit = 157 EUR
ASUS Crosshair III Formula - Socket AM3 = 159 EUR
AMD Phenom II X4 955 - 3.2 GHz = 136.90 EUR
*Corsair Hydro series H50 = 74.90 EUR
OCZ Black Edition Ready Dual Channel 2 x 2 GB, 1600Mhz = 124.90 EUR
SAPPHIRE TECHNOLOGY Radeon HD 5870 Vapor-X - 1 GB = 369 EUR (tišja, zaradi Vapor-X venta)
Samsung SpinPoint F3 1TB = 77 EUR
Intel X25-V Solid State Disk (SSD) - 40 GB RAID0 = 232 EUR
ASUS DRW-24B1ST 24x Internal DVD?RW Rewriter = 29.90 EUR
SKUPAJ: 1 484,91 EUR + 11,99 EUR(poštnina)= 1 496.90 EUR
INTEL KONFIGURACIJA
ASUS Maximus III Formula - 1156 Socket - P55 = 209.90 EUR
Intel Core i5-750 - 2.66 GHz = 189 EUR
OCZ Obsidian Low Voltage 2 x 2 GB DDR3-1600 = 109.90 EUR
2x Intel X25-V Solid State Disk (SSD) - 40 GB RAID0 = 232 EUR
SKUPAJ: 1 573,50 EUR + 11,99 EUR(poštnina)= 1 585.49 EUR (lahko vzameš cenejši napajalnik)
Vse sestavljeno v: http://www.pixmania.si/
LP, Castro
*Dokupi dva tiha ventilatorja ju daj na radiator PUSH-PULL funkcijo in ventilatorja bosta delovala očitno tišje.
AMD KONFIGURACIJA
INTEL KONFIGURACIJA
LP, Castro
- spremenil: Pipi Castro ()
matej_jack ::
Jaz bi samo prispeval en AMD konfig, čisto iz firbca (upam, da se vse ujema)
AGT:
1x Gigabyte GA-890GPA-UD3H 125,10EUR
1x AMD Phenom™ II X4 965 "Black Edition" 173,53EUR
1x A-Data PC3-16000 "XPG™ Extreme" KIT 4096MB 2000 MHz DDR III 161,42EUR
1x Sapphire Radeon HD 5870 "Vapor-X" 1024MB GDDR 5 PCI-Express™ 16x 412,98EUR
1x Western Digital WD1001FALS "Caviar(R) Black™" 1000GB 7200RPM 32MB Serial ATA II 92,33EUR
1x Intel(R) X25-M SSD "Postville" 80GB 0RPM 0MB Serial ATA II 228,68EUR
1x Antec TruePower NEW 650 104,93EUR
1x Antec Nine Hundred Two Črna 108,96EUR
1x NEC AD-7241S LightScribe™ Črna 24,89EUR
1x Scythe Mugen 2 Rev.B 37,40EUR
Skupaj 1.470,22EUR
AGT:
Skupaj 1.470,22EUR
janezek67 ::
Sicer izgleda v redu imam pa nekaj pripomb:
1. Pri komponentah si kupoval najdražje, če bi hotel zares super performance, bi za ta denar lahko sestavil tudi kakšno I7 mašino, ki bi bila hitrejša.
2. Mislim, da tvoja plata ne podpira 2000 Mhz ramov, zato so ti hitri rami overkill za to plato, vzemi kakšne cenejše.
3. Če nimaš zares velikega monitorja, 5870 grafične kartice ne rabiš, ker boš za polovico cene shajal ravno tako dobro z HD 5850. Za igre tudi ni nujno, da imaš SSD disk - ker da jih boš nanj instaliral, bo kmalu premajhen, kupil pa si si tudi precej hiter WD disk
4. Tudi pri napajalniku lahko precej prišparaš, pa ne bo dosti slabši.
5. Nekateri s plitvimi žepi bi za gaming za 3x manj kupili tole
http://www.mimovrste.com/artikel/274008... .
Pa bodo ravno tako s precejšnjim zadovoljstvom igrali vse špile (dobro Direct 11 verjetno ne, teh naslovov ne bo veliko), pri vsakdanjem delu razlike skoraj ne bodo občutili, pri obdelavi kakšnega videa pa bi se ti celo smejali, ker ima Nvidia podporo za CUDA (2x hitrejše delovanje).
Da ne bo pomote - tvoj računalnik je seveda precej boljši od tistega Maona. Še huje pa je, da je precej precej dražji.
- spremenil: janezek67 ()
Pipi Castro ::
No saj, če vzame HD5850 ima že 100€ manj. Po mojem mnenju pa se za 1500€, ki jih je pripravljen dati res splača SSD. SSD v RAID0 ima
371 MB/s sequential read hitrosti, ko pa ima kakšen WD velociraptor 120 MB/s...pa, če še upoštevamo, da ima SSD veliko hitrejši dostopni čas...Pri napajalniku lahko res prišpara, vendar naj ne špara preveč. Saj cenejši so glasni in kot je on zapisal želi silent gaming PC. No, če pa hoče imeti podporo CUDA pa si še vedno lahko nabavi GTX470, vendar potem ne more sanjati o silent gaming PC-ju.
Seti5000 ::
Amdja ne bi, sem imel amd, za njem pa sedaj core 2 duo, pa ne bi šel nazaj - pač kogar kača piči...
CUDA pa ne vem zakaj bi rabil. Edino phizix je pri nvidii nekaj kar bi lahko bilo uporabno, sam mislim da bo ati 5870 čist ok za par let.
EDIT: pa verjetno ne bo šlo za 1500 čez... mal bo overbudget :/
- spremenil: Seti5000 ()
Pipi Castro ::
Potem pa vzami malo slabši napajalnik
-ENERMAX PRO82+ 625W PC POWER MODULE 118 EUR (ENERMAX ima zelo tihe napajalnike)
-CORSAIR 650HX 650W PC POWER SUPPLY 103.33 EUR (imaš že na 1531.82 EUR)
Pa še po možnosti cenejše ohišje
-NZXT M59 Classic Series PC Tower Case = 59.90 EUR (Ni ravno tako tiho kot Whisper, a preglasno pa spet ni)
-LANCOOL DRAGON LORD K62 = 89 EUR (kvalitetne izdelave)
SKUPAJ: 1510.59 EUR z ENERMAX in LANCOOL, vzameš CORSAIR napajalnik in si na 1495.59 EUR
Seti5000 ::
Radeon HD 5870 Vapor-X hmm ja, če bi prej vedel...
napajalnik tudi že imam... še malo pa bo vse, kot božična jelka, sam še darila dam spodaj :)
Seti5000 ::
Hvala vsem za ideje, tukaj pa je končni rezultat:
Drugače je računalnik neslišen v idlu (vsaj jaz ne slišim nič na 1m), pri gamingu pa zmerno glasen (še vedno 2x manj kot prejšnji PC) - me veri hepi.
- zavaroval slike: bluefish ()
Seti5000 ::
i7 930 | asus p6x58d premium | patriot ddr3 6gb 1600 viper II | ati hd5870 | x-750 seasonic | fractal define r2 | ssd intel x25-v 40 gb | 2x wd 1tb green raid 1
+ scythe mugen 2
Define R2 http://www.demise-pc.si/product_info.ph... , pa nekaj dni se čuti vonj po bitumnu, samo potem je ok.
+ scythe mugen 2
snela ::
lepa sestava
Si zadovoljen z ohisjem (zvok, uporabnost)?
- spremenil: snela ()
Seti5000 ::
sem, zelo.
sam prej sem imel neko noname kišto, če bi katerokoli drugo ohišje vzel, bi bilo bolje
| » | Gaming Computer! (strani: 1 2 )Oddelek: Strojna oprema | 11916 (10452) | jazbec |
| » | Nakup novega računalnika - ramiOddelek: Kaj kupiti | 8036 (7705) | bojinjo457 |
| ⊘ | Računalnik do 2000€ (strani: 1 2 3 )Oddelek: Kaj kupiti | 28552 (27206) | M-XXXX |
| » | Gamerski računalnik za 1200 € (strani: 1 2 )Oddelek: Kaj kupiti | 8507 (6749) | solatko |
| » | Računalnik do 1700€ (strani: 1 2 )Oddelek: Kaj kupiti | 13577 (12361) | Pipi Castro |
